[OpenFOAM.org] Installation of OpenFOAM 7 on WSL
Like Tree1Likes
  • 1 Post By PositronCascade
Old   May 12, 2020, 05:53
Default Installation of OpenFOAM 7 on WSL
Martin
mahtin360 is on a distinguished road
just been trying to install OpenFOAM 7 on WSL. I cant get past the first step
sudo sh -c "wget -O - http://dl.openfoam.org/gpg.key | apt-key add -"
and get this error:
--2020-05-12 10:43:59-- http://dl.openfoam.org/gpg.key
Resolving dl.openfoam.org (dl.openfoam.org)... 35.179.33.128
Connecting to dl.openfoam.org (dl.openfoam.org)|35.179.33.128|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 1710 (1.7K) [application/pgp-keys]
Saving to: ‘STDOUT’
- 100%[=================================================>] 1.67K --.-KB/s in 0s
2020-05-12 10:43:59 (141 MB/s) - written to stdout [1710/1710]
gpg: can't connect to the agent: IPC connect call failed
EDIT:
Realized the Ubuntu version in Windows Store installed 20.4 LTS instead of 18.04 LTS . With 18.04 LTS this issue does not exist!
Regards,
Martin
mahtin360 is offline   Reply With Quote
Old   May 14, 2020, 05:32
Hasan Celik
PositronCascade is on a distinguished road
I think it is a bug of Windows Subsystem Linux for Ubuntu 20.04. I hope Microsoft will fix it soon. Till that time, I followed the issue reported here. It downgrades libc6. Otherwise, you may continue to use Ubuntu 18.04. I think the issue might be fixed with WSL 2.
First, I used these commands:
sudo add-apt-repository ppa:rafaeldtinoco/lp1871129
sudo apt update
sudo apt install libc6=2.31-0ubuntu8+lp1871129~1 libc6-dev=2.31-0ubuntu8+lp1871129~1 libc-dev-bin=2.31-0ubuntu8+lp1871129~1 -y --allow-downgrades
sudo apt-mark hold libc6
Then, I installed OpenFOAM v7 as guided on cfd.direct website:
sudo sh -c "wget -O - https://dl.openfoam.org/gpg.key | apt-key add -"
sudo add-apt-repository http://dl.openfoam.org/ubuntu
sudo apt-get update
sudo apt-get -y install openfoam7
I hope it works for you as well.
EDIT: as an update, this issue is fixed in Windows 10 2004.
Annier likes this.
PositronCascade is offline   Reply With Quote
Old   June 7, 2020, 12:25
Max_CFD is on a distinguished road
I had the same issue of Martin (I have to install OpenFoam 7 on Windows 10 using Ubuntu 20.04) and I have followed your method.
I get past the "sudo sh..." step but now I have some issues with the . $HOME/.bashrc step (https://openfoam.org/download/windows-10/, User Configuration, setp 2). I get this error:
-bash: /opt/openfoam7/etc/bashrc: No such file or directory
Did you have the same problem?
Regards,
Massimo
Max_CFD is offline   Reply With Quote
Old   June 7, 2020, 20:11
Hasan Celik
Originally Posted by Max_CFD View Post
Regards,
Massimo
If you installed OpenFOAM on that path, you need to use source command maybe, so try that way to check if it works:
source /opt/openfoam7/etc/bashrc when you start your terminal. Or by gedit/vim you can add those lines to the bottom of your .bashrc file. Or if you used developer version of it, you need source /opt/openfoam7-dev/etc/bashrc
Old   June 8, 2020, 02:47
I have just tried both commands but I recive the same message "No such file or directory".
I am going to unistall Ubuntu 20.04 ant try with Ubuntu 18.04 and see if I can solve the problem starting with a fresh new installation of OpenFoam7.
Thank you, best,
Massimo
Old   February 2, 2021, 18:35
Anil Kunwar
Annier is an unknown quantity at this point
sudo apt update
sudo apt-get update
I could successfully install openfoam7 in my computer.
Annier is offline   Reply With Quote
Map of the OpenFOAM Forum - Understanding where to post your questions! wyldckat OpenFOAM 9 March 30, 2017 05:19
[OpenFOAM.org] Installation notes: OpenFOAM 2.3.x (git repo) on OSX 10.9 opedrofunk OpenFOAM Installation 7 July 1, 2015 13:51
[Discussion] Restructuring the Installation page at openfoamwiki.net wyldckat OpenFOAM Installation 16 November 2, 2013 11:43
Trouble shooting about OpenFOAM installation in Ubuntu 12.04 Nait OpenFOAM Installation 2 December 12, 2012 10:20
Installation of OpenFOAM 1.7.1 to OprnSUSE 11.2 superfxfund OpenFOAM Installation 3 November 11, 2010 02:15
