Cannot use ParaView reader module library <PVFoam Reader>
Running OpenFOAM-v1912 on Windows7 when I try to run ParaFoam I get
The PV_PLUGIN_PATH environment value is not set then something about 327 What files do I need to modify and how do I modify them? |
- Are you able to execute `paraview` command instead? If so, please create a dummy file with a file extension `foam`, e.g. `a.foam`. Then within `paraview` fetch the file in order to load the case for visualisation. Hope it helps. |
