wamars |
June 23, 2020 09:01 |
Problem installation OpenFOAM 6
Hello to everyone,
I’m trying to install OpenFOAM 6 on Centos 7.8
I’m following the instruction in
https://openfoamwiki.net/index.php/I...7.5_.281804.29
However I get an error when executing the point 7, using the command:
source $HOME/OpenFOAM/OpenFOAM- 6/etc/bashrc WM_LABEL_SIZE=64 WM_MPLIB=OPENMPI FOAMY_HEX_MESH=yes
bash: _foamSource: Befehl nicht gefunden...
bash: _foamEval: Befehl nicht gefunden...
i think i should change something in the bashrc file in the $HOME/OpenFOAM/OpenFOAM-6/etc/
#----------------------------------*sh-*--------------------------------------
# \\ / F ield | OpenFOAM: The Open Source CFD Toolbox
# \\ / O peration | Website: https://openfoam.org
# \\ / A nd | Copyright (C) 2011-2018 OpenFOAM Foundation
# \\/ M anipulation |
# License
# This file is part of OpenFOAM.
# OpenFOAM is free software: you can redistribute it and/or modify it
# under the terms of the GNU General Public License as published by
# the Free Software Foundation, either version 3 of the License, or
# (at your option) any later version.
# OpenFOAM is distributed in the hope that it will be useful, but WITHOUT
# ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
# FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License
# for more details.
# You should have received a copy of the GNU General Public License
# along with OpenFOAM. If not, see <http://www.gnu.org/licenses/>.
# File
# etc/bashrc
# Description
# Startup file for OpenFOAM
# Sourced from ~/.profile or ~/.bashrc
# Should be usable by any POSIX-compliant shell (eg, ksh)
export WM_PROJECT=OpenFOAM
export WM_PROJECT_VERSION=6
# USER EDITABLE PART: Changes made here may be lost with the next upgrade
# FOAM_INST_DIR is the location of the OpenFOAM installation which defaults to
# the directory containing this file if sourced by a bash shell.
# Please set to the appropriate path if the default is not correct.
#[ "$BASH" -o "$ZSH_NAME" ] && \
#export FOAM_INST_DIR=$(cd $(dirname ${BASH_SOURCE:-$0})/../.. && pwd -P) || \
export FOAM_INST_DIR=$HOME/$WM_PROJECT
# export FOAM_INST_DIR=~$WM_PROJECT
# export FOAM_INST_DIR=/opt/$WM_PROJECT
# export FOAM_INST_DIR=/usr/local/$WM_PROJECT
# END OF (NORMAL) USER EDITABLE PART
# The default environment variables below can be overridden in a prefs.sh file
# located in ~/.OpenFOAM/$WM_PROJECT_VERSION, ~/.OpenFOAM,
# $FOAM_INST_DIR/site/$WM_PROJECT_VERSION or $FOAM_INST_DIR/site
#- Compiler location:
# WM_COMPILER_TYPE= system | ThirdParty (OpenFOAM)
export WM_COMPILER_TYPE=system
#- Compiler:
# WM_COMPILER = Gcc | Gcc48 ... Gcc62 | Clang | Icc
export WM_COMPILER=Gcc
unset WM_COMPILER_ARCH WM_COMPILER_LIB_ARCH
#- Memory addressing:
# On a 64bit OS this can be 32bit or 64bit
# On a 32bit OS addressing is 32bit and this option is not used
# WM_ARCH_OPTION = 32 | 64
export WM_ARCH_OPTION=64
#- Precision:
# WM_PRECISION_OPTION = SP | DP | LP
export WM_PRECISION_OPTION=DP
#- Label size:
# WM_LABEL_SIZE = 32 | 64
export WM_LABEL_SIZE=32
#- Optimised, debug, profiling:
# WM_COMPILE_OPTION = Opt | Debug | Prof
export WM_COMPILE_OPTION=Opt
#- MPI implementation:
# WM_MPLIB = SYSTEMOPENMPI | OPENMPI | SYSTEMMPI | MPICH | MPICH-GM | HPMPI
# | MPI | FJMPI | QSMPI | SGIMPI | INTELMPI
export WM_MPLIB=SYSTEMOPENMPI
#- Operating System:
# WM_OSTYPE = POSIX | ???
export WM_OSTYPE=POSIX
#- Floating-point signal handling:
# set or unset
export FOAM_SIGFPE=
#- memory initialisation:
# set or unset
#export FOAM_SETNAN=
# The old dirs to be cleaned from the environment variables
foamOldDirs="$WM_PROJECT_DIR $WM_THIRD_PARTY_DIR \
$HOME/$WM_PROJECT/$USER $FOAM_USER_APPBIN $FOAM_USER_LIBBIN \
$WM_PROJECT_SITE $FOAM_SITE_APPBIN $FOAM_SITE_LIBBIN"
# Location of installation
export WM_PROJECT_INST_DIR=$FOAM_INST_DIR
export WM_PROJECT_DIR=$WM_PROJECT_INST_DIR/$WM_PROJECT-$WM_PROJECT_VERSION
# Location of third-party software
export WM_THIRD_PARTY_DIR=$WM_PROJECT_INST_DIR/ThirdParty-$WM_PROJECT_VERSION
# Location of site-specific templates etc
# unset is equivalent to $WM_PROJECT_INST_DIR/site
if [ -d "$WM_PROJECT_SITE" ]
then
export WM_PROJECT_SITE
else
unset WM_PROJECT_SITE
fi
# Location of user files
export WM_PROJECT_USER_DIR=$HOME/$WM_PROJECT/$USER-$WM_PROJECT_VERSION
# Source initialization functions
. $WM_PROJECT_DIR/etc/config.sh/functions
# Add in preset user or site preferences:
_foamSource `$WM_PROJECT_DIR/bin/foamEtcFile prefs.sh`
# Evaluate command-line parameters and record settings for later
# these can be used to set/unset values, or specify alternative pref files
export FOAM_SETTINGS="$@"
_foamEval $@
# Clean standard environment variables (PATH, LD_LIBRARY_PATH, MANPATH)
foamClean=$WM_PROJECT_DIR/bin/foamCleanPath
#- Clean PATH
cleaned=`$foamClean "$PATH" "$foamOldDirs"` && PATH="$cleaned"
#- Clean LD_LIBRARY_PATH
cleaned=`$foamClean "$LD_LIBRARY_PATH" "$foamOldDirs"` \
&& LD_LIBRARY_PATH="$cleaned"
#- Clean MANPATH
cleaned=`$foamClean "$MANPATH" "$foamOldDirs"` && MANPATH="$cleaned"
export PATH LD_LIBRARY_PATH MANPATH
# Source project setup files
_foamSource $WM_PROJECT_DIR/etc/config.sh/settings
_foamSource $WM_PROJECT_DIR/etc/config.sh/aliases
# Source user setup files for optional packages
_foamSource `$WM_PROJECT_DIR/bin/foamEtcFile config.sh/mpi`
_foamSource `$WM_PROJECT_DIR/bin/foamEtcFile config.sh/paraview`
_foamSource `$WM_PROJECT_DIR/bin/foamEtcFile config.sh/ensight`
_foamSource `$WM_PROJECT_DIR/bin/foamEtcFile config.sh/gperftools`
if [ ! -z "$FOAMY_HEX_MESH" ]
then
_foamSource `$WM_PROJECT_DIR/bin/foamEtcFile config.sh/CGAL`
fi
# Clean environment paths again. Only remove duplicates
#- Clean PATH
cleaned=`$foamClean "$PATH"` && PATH="$cleaned"
cleaned=`$foamClean "$LD_LIBRARY_PATH"` && LD_LIBRARY_PATH="$cleaned"
#- Clean MANPATH (trailing ':' to find system pages)
cleaned=`$foamClean "$MANPATH"`: && MANPATH="$cleaned"
#- Clean LD_PRELOAD
if [ -n "$LD_PRELOAD" ]
then
cleaned=`$foamClean "$LD_PRELOAD"` && LD_PRELOAD="$cleaned"
export LD_PRELOAD
fi
# Cleanup environment:
unset cleaned foamClean foamOldDirs
# Unload initialization functions:
# Source the bash completion file:
[ "$BASH" ] && . $WM_PROJECT_DIR/etc/config.sh/bash_completion
Thanks.
