[OpenFOAM.org] Missing mpi.h file error
Old   January 15, 2021, 04:09
Default Missing mpi.h file error
Ariful Islam Pranto
Pranto is on a distinguished road
I got following warnings
Warning in OpenFOAM-dev/etc/config.sh/settings:
     MPI_ARCH_FLAGS is not set. Example:
export MPI_ARCH_FLAGS="-DOMPI_SKIP_MPICXX"
MPI_ARCH_LIBS is not set. Example:
export MPI_ARCH_LIBS="-L$MPI_ROOT/lib -lmpi"
where should I put MPI_ARCH_FLAGS? Otherwise, it gives
 UPstream.C:30:10: fatal error: mpi.h: No such file or directory
Thanks in advance
Pranto is offline   Reply With Quote
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 ordinary OpenFOAM Installation 19 September 3, 2019 18:13
error compiling modified applications yvyan OpenFOAM Programming & Development 21 March 1, 2016 04:53
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 09:17
[swak4Foam] Error bulding swak4Foam sfigato OpenFOAM Community Contributions 18 August 22, 2013 12:41
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
