[OpenFOAM.org] Current directory is not $WM_PROJECT_DIR |
July 20, 2014, 05:36 |
zohreh imani nejad
Rep Power: 12 |
hi formers
i have of2.1.1 but now i want to install of2.3.0 i do all steps in the openFoam.com site but i have this error ./Allwmake: 4: ./Allwmake: wmakeCheckPwd: not found Error: Current directory is not $WM_PROJECT_DIR The environment variables are inconsistent with the installation. Check the OpenFOAM entries in your dot-files and source them. i read the page http://www.cfd-online.com/Forums/ope...oject_dir.html but i canot solve my problem thanks |
July 22, 2014, 04:32 |
zohreh imani nejad
Rep Power: 12 |
no one can help me?
July 23, 2014, 17:51 |
Rep Power: 12 |
Check what value is stored in the $WM_PROJECT_DIR.
echo $WM_PROJECT_DIR Make sure you do not have the line Code:
source $HOME/openfoam211/etc/bashrc If you do, you should change it to Code:
alias foam211='source $HOME/openfoam211/etc/bashrc' Code:
alias foam230='source $HOME/openfoam230/etc/bashrc' Once this is set up, you can run ./Allwmake after sourcing the openfoam230 bashrc. (The above assumes you installed OpenFOAM v2.3.0 in your user $HOME directory.) Hope that helps. |
July 24, 2014, 00:39 |
zohreh imani nejad
Rep Power: 12 |
hi
thanks for your attention when i run echo $WM_PROJECT_DIR i dont have any output in terminal .... just a blank line !!!! like bellow dell@ubuntu:~$ echo $WM_PROJECT_DIR dell@ubuntu:~$ i dont understand your meaning about local bashrc file i have two bashrc file : one in openFoam2.1.1 file and other in openFoam2.3.0 file in these basrc files i change end of it to : alias of230='source $HOME/openfoam230/etc/bashrc' alias of211='source $HOME/openfoam211/etc/bashrc' when i put ./Allwmake in terminal dell@ubuntu:~/OpenFOAM/OpenFOAM-2.3.0$ ./Allwmake i have this output : ./Allwmake: 4: ./Allwmake: wmakeCheckPwd: not found Error: Current directory is not $WM_PROJECT_DIR The environment variables are inconsistent with the installation. Check the OpenFOAM entries in your dot-files and source them. |
July 24, 2014, 10:28 |
Rep Power: 12 |
You need to add
alias of230='source $HOME/openfoam230/etc/bashrc' alias of211='source $HOME/openfoam211/etc/bashrc' Then, open a new terminal, type of230, and run ./Allwmake in the openfoam230 directory. |
July 24, 2014, 13:35 |
zohreh imani nejad
Rep Power: 12 |
tanks alot
i found that bashrc file |
September 1, 2018, 10:02 |
王莹
Rep Power: 8 |
September 1, 2018, 14:43 |
Emre
Rep Power: 10 |
I think you have to first check your .bashrc file in your home folder. It is a hidden file so you should enable 'Show hidden files' button if you use window manager. The file named .bashrc must have an ending like @cdm said:
September 1, 2018, 17:33 |
#9 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Adding to Emre's answer:
September 2, 2018, 01:20 |
#10 |
王莹
Rep Power: 8 |
Thank you Emre, actually I have added the lines to my .bashrc file as cdm suggested.
alias ofdev='source $HOME/OpenFOAM/OpenFOAM-dev/etc/bashrc' alias ofv30='source $HOME/OpenFOAM/OpenFOAM-v3.0+/etc/bashrc' But it still failed. When I typed 'alias' in terminal, it showed two aliases above haven't been defined... When I type 'echo $WM_PROJECT_DIR', my dir is still $HOME/openfoam/openfoam-dev(The version I have installed). There is a strange thing: I have install openfoam-dev in my computer before, but in the ending of my .bashrc files, no "source $HOME/OpenFOAM/OpenFOAM-dev/etc/bashrc" existed at first... |
September 2, 2018, 01:38 |
#11 | |
王莹
Rep Power: 8 |
Thank you Bruno, I have done things as cdm and Emre suggested:
“alias ofdev='source $HOME/OpenFOAM/OpenFOAM-dev/etc/bashrc' alias ofv30='source $HOME/OpenFOAM/OpenFOAM-v3.0+/etc/bashrc'” was added to my ./bashrc file. But it still failed. When I typed 'alias' in terminal, it showed two aliases above haven't been defined...In the link you gave me, I cannot find how to solve this problem. Here is some information I get after I added two aliases in ./bashrc 1.When I type 'echo $WM_PROJECT_DIR', my dir is still $HOME/openfoam/openfoam-dev (The version I have installed). 2.There is a strange thing: I have installed openfoam-dev in my computer before, but at the very beginning, no "source $HOME/OpenFOAM/OpenFOAM-dev/etc/bashrc" existed in the ending of my .bashrc files... Quote:
September 2, 2018, 09:23 |
#12 |
Bruno Santos
Rep Power: 128 |
Quick answer:
September 2, 2018, 09:32 |
#13 | |
王莹
Rep Power: 8 |
Thanks so much, Bruno! Now I have solved my problem and of v3.0+ is compiling in my book ^_^.
July 10, 2020, 10:30 |
#14 | ||
The specific error message is below. Thank you for your help! Quote:
July 11, 2020, 02:48 |
#15 |
Tu Can
Rep Power: 8 |
"~" is a syombol refer to "$HOME"
and "$HOME" is home directory of a user. "echo $HOME" will show what it is. mostly, "$HOME" refer to "/home/<your user name>/" specially, when user name is "root", "$HOME" refer to "/root/" seems like you are using "sudo" or login as root. It's not recommend. |
August 25, 2020, 03:42 |
#16 |
Ali Shayegh
Rep Power: 10 |
What does WM mean in the beginning of WM_PROJECT_DIR at all? Is it abbreviation for wmake?
September 6, 2020, 03:10 |
3.2.2.5 wmake environment variables
#17 |
Rahul Vadrabade
Rep Power: 8 |
Yes, More information is available at
https://cfd.direct/openfoam/user-gui...x10-730003.2.2 3.2.2.5 wmake environment variables |
September 6, 2020, 08:19 |
#18 | |
Ali Shayegh
Rep Power: 10 |
[swak4Foam] Installation Problem with OF 6 version | Aurel | OpenFOAM Community Contributions | 14 | November 18, 2020 16:18 |
Ansys Licence Serve on Ubuntu 16.04 LTS | david.pasquale | ANSYS | 2 | January 20, 2017 11:52 |
Error: Current directory is not $WM_THIRD_PARTY_DIR | lapsednun | OpenFOAM Installation | 1 | August 30, 2014 10:46 |
Re : Problem Installing OpenFOAM on Centos -5.3 | mohanphy | OpenFOAM Installation | 1 | February 7, 2010 19:09 |
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' | mfiandor | OpenFOAM Installation | 2 | January 25, 2010 09:50 |
