[OpenFOAM.com] flex yylex issues while install OpenFOAM from source
Old   August 28, 2022, 21:22
Question flex yylex issues while install OpenFOAM from source
Ashish Pathak
patashish704 is on a distinguished road
I am trying to install openfoam-v2206 from source on RHEL 8.3. As I do not have access to root privileges, I installed the required packages such as bison and flex from source as well. Before invoking ./Allwmake -s -l, I added the path to flex and bison binaries to $PATH environment variable and path to flex lib to $LD_LIBRARY_PATH. I also populated $FOAM_EXTRA_CFLAGS and $FOAM_EXTRA_CXX_FLAGS to "-I/<path to flex include>" and $FOAM_EXTRA_LDFLAGS to "-L/<path to flex lib> -lfl". Now when I invoke ./Allwmake -s -l, the installation fails (while building applications) with a message that says: "flex-2.6.4-install/lib/libfl.so.2: undefined reference to yylex". How to fix this problem to do a successful openfoam installation from source?
patashish704 is offline   Reply With Quote
[swak4Foam] Installation Problem with OF 6 version Aurel OpenFOAM Community Contributions 14 November 18, 2020 16:18
Trouble compiling utilities using source-built OpenFOAM Artur OpenFOAM Programming & Development 14 October 29, 2013 10:59
OpenFOAM 2.2.2 source pack installation on Xubuntu 13.10 zordiack OpenFOAM Installation 1 October 26, 2013 13:08
centOS 5.6 : paraFoam not working yossi OpenFOAM Installation 2 October 9, 2013 01:41
[swak4Foam] build problem swak4Foam OF 2.2.0 mcathela OpenFOAM Community Contributions 14 April 23, 2013 13:59
