[OpenFOAM.com] cant execute waveFoam Solver in waves2Foam |
April 15, 2020, 09:31 |
Rep Power: 6 |
I just installed waves2Foam and tried to run the standingWave Simulation found in the tutorials folder. I tipped in : ./Allrun then this happend: blockMesh already run on /home/sase/OpenFOAM/sase-7/applications/utilities/waves2Foam/tutorials/waveFoam/standingWave: remove log file 'log.blockMesh' to re-run setWaveParameters already run on /home/sase/OpenFOAM/sase-7/applications/utilities/waves2Foam/tutorials/waveFoam/standingWave: remove log file 'log.setWaveParameters' to re-run setWaveField already run on /home/sase/OpenFOAM/sase-7/applications/utilities/waves2Foam/tutorials/waveFoam/standingWave: remove log file 'log.setWaveField' to re-run waveFoam already run on /home/sase/OpenFOAM/sase-7/applications/utilities/waves2Foam/tutorials/waveFoam/standingWave: remove log file 'log.waveFoam' to re-run After that i tried to see the results in paraFoam. paraFoam opened but nothing was calculated so i tried to use the waveFoam solver but when i try to use this solver this command: "command not found" appears. So i tried to use the interFoam solver but everytime i try this massage appears: --> FOAM FATAL IO ERROR: keyword PIMPLE is undefined in dictionary "/home/sase/OpenFOAM/sase-7/applications/utilities/waves2Foam/tutorials/waveFoam/standingWave/system/fvSolution" file: /home/sase/OpenFOAM/sase-7/applications/utilities/waves2Foam/tutorials/waveFoam/standingWave/system/fvSolution from line 38 to line 118. From function const Foam::dictionary& Foam::dictionary::subDict(const Foam::word&) const in file db/dictionary/dictionary.C at line 705. FOAM exiting Iam using Ubuntu 19.10 and OpenFoam V7 |
January 2, 2021, 00:18 |
Rep Power: 5 |
Hi Thread,
I have the same problem as you, and I am trying to figure it out. May i Know if you have found the reason? bests jie |
Will the results of steady state solver and transient solver be same? | carye | OpenFOAM Running, Solving & CFD | 9 | December 28, 2019 05:21 |
Divergence problem | Smaras | FLUENT | 13 | February 21, 2013 05:03 |
3d vof | Smaras | FLUENT | 2 | February 19, 2013 06:58 |
Working directory via command line | Luiz | CFX | 4 | March 6, 2011 20:02 |
why the solver reject it? Anyone with experience? | bearcat | CFX | 6 | April 28, 2008 14:08 |
