[OpenFOAM.org] UPstream.H: No such file or directory (but exists)
Like Tree1Likes
  • 1 Post By olesen
Old   July 15, 2020, 16:19
Default UPstream.H: No such file or directory (but exists)
mahmoodn is on a distinguished road
Hi
On Centos-7 with GCC-4.8.5 and OpenFoam-7, I get this error for missing UPstream.H file while everything look normal and I have sourced etc/bashrc file.
[marzieh@hpc ~]$ source ~/OpenFOAM-7/etc/bashrc
[marzieh@hpc ~]$ env | grep WM
WM_LINK_LANGUAGE=c++
WM_ARCH=linux64
WM_COMPILER_TYPE=system
WM_OSTYPE=POSIX
WM_THIRD_PARTY_DIR=/home/marzieh/ThirdParty-7
WM_CXXFLAGS=-m64 -fPIC -std=c++0x
WM_CFLAGS=-m64 -fPIC
WM_PROJECT_VERSION=7
WM_COMPILER_LIB_ARCH=64
WM_PROJECT_INST_DIR=/home/marzieh
WM_CXX=g++
WM_PROJECT_DIR=/home/marzieh/OpenFOAM-7
WM_LABEL_OPTION=Int32
WM_PROJECT=OpenFOAM
WM_LDFLAGS=-m64
WM_COMPILER=Gcc
WM_MPLIB=SYSTEMOPENMPI
WM_CC=gcc
WM_COMPILE_OPTION=Opt
WM_DIR=/home/marzieh/OpenFOAM-7/wmake
WM_LABEL_SIZE=32
WM_PROJECT_USER_DIR=/home/marzieh/OpenFOAM/marzieh-7
WM_OPTIONS=linux64GccDPInt32Opt
WM_PRECISION_OPTION=DP
WM_ARCH_OPTION=64
[marzieh@hpc ~]$ cd OpenFOAM-7/
[marzieh@hpc OpenFOAM-7]$ ./Allwmake
Allwmake /home/marzieh/OpenFOAM-7
make: Nothing to be done for `all'.
Start ThirdParty Allwmake
Build MPI libraries if required
Build Scotch decomposition library scotch_6.0.6
    /home/marzieh/ThirdParty-7/platforms/linux64GccDPInt32/scotch_6.0.6
    scotch header in /home/marzieh/ThirdParty-7/platforms/linux64GccDPInt32/scotch_6.0.6/include
    scotch libs   in /home/marzieh/ThirdParty-7/platforms/linux64GccDPInt32/lib
Build PTScotch decomposition library scotch_6.0.6 (uses MPI)
    ptscotch header in /home/marzieh/ThirdParty-7/platforms/linux64GccDPInt32/scotch_6.0.6/include/openmpi-system
    ptscotch libs   in /home/marzieh/ThirdParty-7/platforms/linux64GccDPInt32/lib/openmpi-system
Build Metis decomposition
    optional component Metis was not found
Done ThirdParty Allwmake
Allwmake src
version changed from previous build
removing .o files corresponding to OpenFOAM/global/global.o ...
Allwmake src/Pstream
wmake dummy
g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -O3  -DNoRepository -ftemplate-depth-100   -IlnInclude -I. -I/home/marzieh/OpenFOAM-7/src/OpenFOAM/lnInclude -I/home/marzieh/OpenFOAM-7/src/OSspecific/POSIX/lnInclude   -fPIC -c UPstream.C -o /home/marzieh/OpenFOAM-7/platforms/linux64GccDPInt32Opt/src/Pstream/dummy/UPstream.o
UPstream.C:26:22: fatal error: UPstream.H: No such file or directory
 #include "UPstream.H"
compilation terminated.
make: *** [/home/marzieh/OpenFOAM-7/platforms/linux64GccDPInt32Opt/src/Pstream/dummy/UPstream.o] Error 1
and
[marzieh@hpc OpenFOAM-7]$ find . -name UPstream.H
./src/OpenFOAM/db/IOstreams/Pstreams/UPstream.H
Any idea to fix that?
mahmoodn is offline   Reply With Quote
Old   October 10, 2020, 10:55
Ace Ventura
kingdomkarl is on a distinguished road
Hey,
have you ever managed to remedy this issue ?
I´m facing it now as well ...
kingdomkarl is offline   Reply With Quote
Old   October 11, 2020, 06:51
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
Originally Posted by kingdomkarl View Post
Hey,
Since OpenFOAM compromises many source files in many different directories and subdirectories, it would be tedious and error-prone to have all of them listed as include directories. To get around this, when any OpenFOAM library is compiled, the first step is to create an "lnInclude" directory with soft-links to all of the headers. If these are missing, or have incorrect links, you will get the type of error that you are seeing.
I am not sure where you got your package (built it yourself, downloaded somewhere,..) but you will need to recreate these directories.
Try something like this :
cd src/
wmakeLnIncludeAll -update
georgynio likes this.
olesen is offline   Reply With Quote
Old   October 11, 2020, 06:56
Mark Olesen
Hey,
BTW if you are using CentOS, you could also give the precompiled packages a try.
https://develop.openfoam.com/Develop...ompiled/redhat
In this case the '-devel' subpackage would contain the sources and the corresponding lnInclude directories
Old   January 15, 2021, 04:22
Default Thanks
Jinguo Sun
sunjg13 is on a distinguished road
cd src/
It works well!!! The code "wmakeLnIncludeAll -update" solves the problem about "Upstream.h not found"
sunjg13 is offline   Reply With Quote
[swak4Foam] swak4foam for OpenFOAM 4.0 mnikku OpenFOAM Community Contributions 80 May 17, 2022 08:06
how to calculate mass flow rate on patches and summation of that during the run? immortality OpenFOAM Post-Processing 104 February 16, 2021 08:46
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 19:43
Trouble compiling utilities using source-built OpenFOAM Artur OpenFOAM Programming & Development 14 October 29, 2013 10:59
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' mfiandor OpenFOAM Installation 2 January 25, 2010 09:50
