Compile cannot find -lfoam (1st error msg)
Failed compilation of openfoam-extend 4.1. Here's the first instance of load error in compilation --- can't find -lfoam. Running opensuse linux. I don't know how far through compilation this is but it's been running for 1/2 hour or so. Same error continues for many more files. See compiler output snippet below:
SOURCE=dsmcFoam.C ; g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-200 -I/home/tom/foam/foam-extend-4.1/src/finiteVolume/lnInclude -I/home/tom/foam/foam-extend-4.1/src/lagrangian/basic/lnInclude -I/home/tom/foam/foam-extend-4.1/src/lagrangian/dsmc/lnInclude -I/home/tom/foam/foam-extend-4.1/src/meshTools/lnInclude -IlnInclude -I. -I/home/tom/foam/foam-extend-4.1/src/foam/lnInclude -I/home/tom/foam/foam-extend-4.1/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPInt32Opt/dsmcFoam.o thanks all. tom kosvic |
