RobbieTheK |
October 4, 2022 11:48 |
makeParaView fails with Could NOT find Qt5Help with ThirdParty-2206
We have Qt 5.15.2 installed as a module and loaded at
./makeParaView -cmake -qmake -qt-5.15.2
fails with:
-- Could NOT find Qt5Help (missing: Qt5Help_DIR)
CMake Warning at VTK/CMake/vtkModule.cmake:4365 (find_package):
Found package configuration file:
/usr/lib64/cmake/Qt5/Qt5Config.cmake
but it set Qt5_FOUND to FALSE so package "Qt5" is considered to be NOT
FOUND. Reason given by package:
Failed to find Qt5 component "Help" config file at
"/usr/lib64/cmake/Qt5Help/Qt5HelpConfig.cmake"
Call Stack (most recent call first):
Qt/Widgets/CMakeLists.txt:117 (vtk_module_find_package)
CMake Error at VTK/CMake/vtkModule.cmake:4371 (message):
Could not find the Qt5 external dependency.
We have this file at:
I tried the symbols link route and end up with:
CMake Error at /usr/lib64/cmake/Qt5Core/Qt5CoreConfigVersion.cmake:2 (set):
Maximum recursion depth of 1000 exceeded
/usr/lib64/cmake/Qt5Help/Qt5HelpConfig.cmake:28 (find_package)
I did set:
Qt5_DIR=/opt/Qt/5.15.2/gcc_64/lib/cmake/Qt5
Is there a work around for this?
