[OpenFOAM.com] v1606+ Compilation error - ptscotch.h not found
Like Tree4Likes
  • 1 Post By TmsO
Old   July 7, 2016, 15:14
Default v1606+ Compilation error - ptscotch.h not found
Tommaso
TmsO is on a distinguished road
Hi everyone,
I wonder if anyone could help me....I've just downloaded the new OF version 1606 and I'm trying to compile it. Unluckily I got the following error:
/home/tommaso/App/OpenFOAM/OpenFOAM-v1606+/src/parallel/decompose/ptscotchDecomp
wmake libso ptscotchDecomp
wmakeLnInclude: linking include files to ./lnInclude
Making dependency list for source file ptscotchDecomp.C
could not open file ptscotch.h for source file ptscotchDecomp.C due to No such file or directory
g++ -std=c++0x -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3  -DNoRepository -ftemplate-depth-100 -DOMPI_SKIP_MPICXX -I/usr/lib/openmpi/include/openmpi/opal/mca/event/libevent2021/libevent -I/usr/lib/openmpi/include/openmpi/opal/mca/event/libevent2021/libevent/include -I/usr/lib/openmpi/include -I/usr/lib/openmpi/include/openmpi -pthread -I/include -I/home/tommaso/App/OpenFOAM/ThirdParty-v1606+/platforms/linux64GccInt32/scotch_6.0.3/include/openmpi-system -I/usr/include/scotch -I../decompositionMethods/lnInclude -IlnInclude -I. -I/home/tommaso/App/OpenFOAM/OpenFOAM-v1606+/src/OpenFOAM/lnInclude -I/home/tommaso/App/OpenFOAM/OpenFOAM-v1606+/src/OSspecific/POSIX/lnInclude   -fPIC -c ptscotchDecomp.C -o /home/tommaso/App/OpenFOAM/OpenFOAM-v1606+/platforms/linux64GccDPInt32OptSYSTEMOPENMPI/src/parallel/decompose/ptscotchDecomp/ptscotchDecomp.o
ptscotchDecomp.C:214:26: fatal error: ptscotch.h: No such file or directory
compilation terminated.
/home/tommaso/App/OpenFOAM/OpenFOAM-v1606+/wmake/rules/General/transform:8: recipe for target '/home/tommaso/App/OpenFOAM/OpenFOAM-v1606+/platforms/linux64GccDPInt32OptSYSTEMOPENMPI/src/parallel/decompose/ptscotchDecomp/ptscotchDecomp.o' failed
make: *** [/home/tommaso/App/OpenFOAM/OpenFOAM-v1606+/platforms/linux64GccDPInt32OptSYSTEMOPENMPI/src/parallel/decompose/ptscotchDecomp/ptscotchDecomp.o] Error 1
It looks like that the compiler cannot find ptscotch.h for some reason.
My libraries/compilers etc are all up to date.
I'm not much of an expert on this sort of things, so I hope to get some help.
Cheers,
Tommaso
sourav90 likes this.
Last edited by wyldckat; September 9, 2016 at 17:52. Reason: Added [CODE][/CODE] markers
TmsO is offline   Reply With Quote
Old   August 18, 2016, 11:35
Default changing Compiler
Stefan
StefanW is on a distinguished road
Hey Tommaso,
just got the same problem doing the installation on a cluster of the university.
Just got the advise to check whether the "bashrc" file contains the right "standard-Compiler- and MPI-version" which is supposed from the admins.
So i changed the compiler to the "Icc" one by changing the code of the bashrc
#- Compiler:
# WM_COMPILER = Gcc | Gcc45 | Gcc46 | Gcc47 | Gcc48 | Gcc49| Clang | Icc
#######export WM_COMPILER=Gcc
export WM_COMPILER=Icc
and the MPI-Version to "SYSTEMOPENMPI"
export WM_MPLIB=SYSTEMOPENMPI
The installation is running now since 3 hours and didn't crash like the last times. Fingers crossed it runs through all the steps...
I hope that may help you.
Regards
Stefan
StefanW is offline   Reply With Quote
Old   August 19, 2016, 04:03
Default Installation fail
Stefan
the installation failed also, again at the ptscotch.h file.
I will talk to the admins and let you know.
Regards Stefan
Old   September 7, 2016, 10:13
Default Solved!
Tommaso
Hello Stephan,
thanks for you reply and sorry for the delay. I had to put the project in the backburner for a while and I resumed it not long ago.
Finally I managed to get everything working just by installing ptscotch with:
sudo apt-get install ptscotch
eveything compiled and now it's working!
Thanks again!
Old   September 9, 2016, 17:50
Retired Super Moderator
Bruno Santos
Quick answer: Sorry for the delay in responding to this, but it was only fairly recently that I managed to document the detailed installation steps for installing OpenFOAM+ v1606+ on a few systems: https://openfoamwiki.net/index.php/I...AM%2B-v1606%2B
Nonetheless, there is no clear indication in the details you've all provided, in order to diagnose why "ptscotch" is not getting built properly.
For those who are still having problems with this, please run the following commands:
cd $WM_THIRD_PARTY_DIR
./Allwmake > log.make 2>&1
gzip < log.make > log.make.gz
Then please attach the file "log.make.gz" to your next post, which will provide the complete output of the attempt at building Scotch and PTScotch.
edit: I forgot to mention that if you downloaded the package "ThirdParty-v1606+.tgz" soon after the release of v1606+, it was updated again a few days later to fix one or two issues with the build scripts. That might have been the origin of the very first reported issue here.
Old   October 5, 2017, 03:11
Default Problems with ptscotch and OpenFoam
Rosemarie Meuer
rmeuer is on a distinguished road
I am having the same problem with OpenFoam16.12. I have attached the error messages from ptscotch.
rmeuer is offline   Reply With Quote
Old   October 24, 2022, 11:28
Victor Eijkhout
VictorEijkhout is on a distinguished road
Scotch & Ptscotch...
I installed scotch/ptscotch myself and then added include & lib directories to the compiler. That worked for me. In my case that meant editing
wmake/rules/linux64Gcc/c++
VictorEijkhout is offline   Reply With Quote
Building OpenFOAM1.7.0 from source ata OpenFOAM Installation 46 March 6, 2022 13:21
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' muth OpenFOAM Running, Solving & CFD 3 August 27, 2018 04:18
dsmcInitialise - dsmcFoam archymedes OpenFOAM Pre-Processing 94 July 15, 2016 16:14
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 08:48
Compilation Error.... Arnab Siemens 4 September 12, 2004 15:54
