[Other] BlockMesh Permissions Workaround Not Working - File Locations |
#1 | |
Max
Rep Power: 0 ![]() |
I'm trying the second tutorial on OpenFOAM, and I'm getting stuck on literally the first step, running BlockMesh.
My account is an admin account, so I'm getting this message Quote:
cylinder case I have a fresh install of v2306, using the Native Windows instructions since that seemed to be the easiest. Here is where OpenFOAM is installed on my machine: [USER]\AppData\Roaming\ESI-OpenCFD\OpenFOAM\v2306. Can anyone give me some advice? |
Mark Olesen
Rep Power: 41 ![]() ![]() |
Two things: never use root (admin) for running any programs beyond administrative tasks - even if you actually trust the sources. Running with dynamic code compilation will probably not work at all if you are using the cross-compiled windows binaries. If they are to work, they would probably need a lot more tools installed (gcc etc).
With the #eval keyword (instead of #calc), there will be no issues - since that keyword uses an internal parser and doesn't compile new code. If you have something like #codeStream etc, you will either have to skip those with the cross-compiled windows binaries or else use WSL and one of the precompiled Linux binaries (eg, for Ubuntu). You will have to make a decision. |
#3 | |
Yanjun Tong
Rep Power: 6 ![]() |
#4 | |
Yanjun Tong
Display Modes | |
Custom Thermophysical Properties | wsmith02 | OpenFOAM | 4 | June 1, 2023 14:30 |
[swak4Foam] swak4foam for OpenFOAM 4.0 | mnikku | OpenFOAM Community Contributions | 80 | May 17, 2022 08:06 |
OpenFoam "Permission denied" and "command not found" problems. | iyidaniel@yahoo.co.uk | OpenFOAM Running, Solving & CFD | 11 | January 2, 2018 06:47 |
polynomial BC | srv537 | OpenFOAM Pre-Processing | 4 | December 3, 2016 09:07 |
[swak4Foam] Error bulding swak4Foam | sfigato | OpenFOAM Community Contributions | 18 | August 22, 2013 12:41 |
