Compiling library and solver fails (on a cluster) - spack error
Hello all.
I'm new to Linux and OpenFOAM and I am working on a cluster for the first time. OpenFOAM (v2112) has been installed as a module by an admin via the package manager. I work in my work directory /work/user/username. I have also cloned a repository into this directory. Now I want to compile the library and the solver and I get the following error message: make: *** No rule to make target 'Spack', needed by '[spack'. Stop. wmake error: file 'Make/linux64GccDPInt32-spack/sourceFiles' could not be created in /work/user/username/hydrology/src/hydrology I put the $WM_PROJECT_DIR directory in my bashrc file (bashrc under $HOME/username/.bashrc). Furthermore, I created my $WM_PROJECT_USER_DIR at the beginning of my work: export WM_PROJECT_USER_DIR=$HOME/username/OpenFOAM/$USER-$WM_PROJECT_VERSION mkdir $WM_PROJECT_USER_DIR --parent Unfortunately, after that, I was told that I'd better store/run all things like my simulations in /work/user/username. I have now looked at the individual files inside the cloned repository - Allwmake (top-level) as well as files and options (under cluster/work/user/username/hydrology/src/hydrology/Make). However, I have not found anything that helps me. And the query echo $FOAM_USER_APPBIN and echo $FOAM_USER_LIBBIN outputs: /cluster/home/username/OpenFOAM/username-v2112/platforms/linux64GccDPInt32-spack/bin and /cluster/home/username/OpenFOAM/username-v2112/platforms/linux64GccDPInt32-spack/lib respectively. In cluster/work/user/username/hydrology/src/hydrology/Make there is also the directory linux64GccDPInt32-spack. It contains the file options - when this file is opened, the following message is displayed: [spack cc] ERROR: Spack compiler must be run from Spack! Input 'SPACK_ENV_PATH' is missing. Unfortunately, I don't know what the errors mean or what I did wrong so far. I don't make any further progress, especially not with the message/error about the Spack compiler. My research into this issue did not help me. I don't know if the problem is that everything is in different directories or outside the directory where OpenFOAM is installed? Or is it because OpenFOAM is perhaps already pre-compiled (Here I read that I then need the dev/develop package?)? I apologize for any possibly incorrect Linux/OpenFOAM-related terms and contexts. I am still new and currently working my way into the nomenclature. 😊 Would be really happy if someone could help me. 😊 Thanks in advance Sabrina |
Same spack error while compiling library on a cluster
I am facing an issue which is very similar to yours. When trying to compile my library on a cluster (same OpenFOAM version) with wmake libso I get the same error message as you: [spack cc] ERROR: Spack compiler must be run from Spack! Input 'SPACK_ENV_PATH' is missing. However, in the file options contained inside linux64GccDPInt32-spack (located in the same path as yours), I don't have the error message, but instead it says: Code:
EXE_INC = -I$(LIB_SRC)/finiteVolume/lnInclude -I$(LIB_SRC)/fileFormats/lnInclude -I$(LIB_SRC)/meshTools/lnInclude -I$(LIB_SRC)/functionObjects/forces/lnInclude -I$(LIB_SRC)/dynamicMesh/lnInclude By any chance, have you found a solution, or understood where this error comes from? Or does anybody else reading know how to solve this issue? Thanks, Francesca :) |
