Open foam installation
Dear all,
I am working on OpenFoam 2.3.1. I am using source code to install on a cluster. I want to install OpenFoam on a cluster. For this, I am using spack to load gcc 5.3 and Flexlexer. I created symbolic link for FlexLexer using command ln -s $HOME/OpenFOAM/OpenFOAM-2.3.1/src/OpenFOAM/lnInclude/FlexLexer.h $HOME/Software/GNU/Flex/2.5.39/include/FlexLexer.h But after compiling, i found some errors and at the end of log file, they were showing make: Target 'application' was not remade because of errors. this is my bashrc file in home # Spack . $HOME/Software/spack/share/spack/setup-env.sh spack load gcc # GNU Software export PATH="$HOME/Software/GNU/Flex/2.5.39/bin:$PATH" export LD_LIBRARY_PATH="$HOME/Software/GNU/Flex/2.5.39/lib:$LD_LIBRARY_PATH" # Open MPI module load openmpi/4.1.1 # OpenFOAM source $HOME/OpenFOAM/OpenFOAM-2.3.1/etc/bashrc export WM_NCOMPROCS=8 Kindly help me if some one knows how to figure it out. Thank you |
