[foam-extend.org] OFExtend 5.0 - TurboWG cant compile certain files I need |
Sami Safarini
Rep Power: 5 ![]() |
On TurboWG-experimental branch of openfoam extend 5.0 (
This is the link to all the files i have used.) , I am trying to compile the Turboperformance folder again as I think the function isnt being found when I try to run the SinglePumpPhase tutorial, but I get this error during compilation. note: because ‘Foam::SLListBase::const_iterator’ has user-provided ‘void Foam::SLListBase::const_iterator: ![]() 265 | inline void Foam::SLListBase::const_iterator: ![]() | ^~~~ make: *** [forces/forces.dep:718: Make/linux64GccDPInt32Opt/forces.o] Error 1 When I try to compile the transient transientSimpleDyMFoam i get the following error, note: because ‘Foam::dimensionSet’ has user-provided ‘bool Foam::dimensionSet: ![]() 197 | bool operator=(const dimensionSet&) const; | ^~~~~~~~ make: *** [transientSimpleDyMFoam.dep:748: Make/linux64GccDPInt32Opt/transientSimpleDyMFoam.o] Error 1 When I try to compile the initializeRotation application i get the following error /foam/foam-extend-5.0/src/foam/lnInclude/SLListBaseI.H:265:13: note: because ‘Foam::SLListBase::const_iterator’ has user-provided ‘void Foam::SLListBase::const_iterator: ![]() 265 | inline void Foam::SLListBase::const_iterator: ![]() | ^~~~ make: *** [initializeRotation.dep:727: Make/linux64GccDPInt32Opt/initializeRotation.o] Error 1 Anyone have any idea? If I remove the turboperformance from the tutorial controlDict, i get it to work but I get a floating point error which hints to me that the initializeRotation function is important, and that the TurboWG installation was done correctly. |
turbomachinery cfd |
Display Modes | |
[waves2Foam] Surface Elevation run-time evaluation | ericJag | OpenFOAM Community Contributions | 4 | January 7, 2025 14:34 |
[blockMesh] mergePatchPairs problem when using two master and slave combination | Ali_Sh | OpenFOAM Meshing & Mesh Conversion | 0 | September 22, 2021 10:35 |
boundary conditions in fvMatrix multiplication make me despair | marek88 | OpenFOAM | 5 | August 25, 2018 04:55 |
OpenFOAM 5.0 Released | CFDFoundation | OpenFOAM Announcements from OpenFOAM Foundation | 11 | June 6, 2018 00:48 |
looking for fluent 5.0 validation files valve10 | tom | FLUENT | 1 | September 10, 2012 04:57 |
