[OpenFOAM.com] errors from running paraFoam in WSL
Like Tree3Likes
  • 2 Post By wxyyoyo
  • 1 Post By x84645
Old   January 15, 2025, 18:00
Default errors from running paraFoam in WSL
wxyyoyo is on a distinguished road
I am new in WSL, Ubuntu, and openFoam. I followed the instructions from the page: https://openfoam.org/download/dev-ubuntu/. Everything went smoothly until the last step: paraFoam. My Ubuntu version is Ubuntu 24.04.1 LTS, noble.
The error message is as follows:
Created temporary 'pitzDailySteady.OpenFOAM'
MESA: error: ZINK: failed to choose pdev
glx: failed to create drisw screen
Loguru caught a signal: SIGSEGV
Stack trace:
0 0x7fdd3ebeb320 /usr/lib/x86_64-linux-gnu/libc.so.6(+0x45320) [0x7fdd3ebeb320]
( 2.949s) [paraview ] :0 FATL| Signal: SIGSEGV
Segmentation fault (core dumped)
wxyyoyo@LAPTOP-I34VA0MJ:~/OpenFOAM/wxyyoyo-dev/run/pitzDailySteady$ paraFoam
Stack trace:
0 0x7f9ec37dc320 /usr/lib/x86_64-linux-gnu/libc.so.6(+0x45320) [0x7f9ec37dc320]
( 1.436s) [paraview ] :0 FATL| Signal: SIGSEGV
Please help. Thanks inadvance!
wxy
wxyyoyo is offline   Reply With Quote
Old   January 15, 2025, 18:25
Smile solved!
Just find a solution as follows:
sudo add-apt-repository ppa:kisak/kisak-mesa
sudo apt update
sudo apt upgrade
It is on the page: https://askubuntu.com/questions/1516...o-ubuntu-24-04
My paraFoam is working now! Thanks!
francescomarra and Wesley like this.
Old   January 22, 2025, 01:54
Richard Bratton
x84645 is on a distinguished road
Hi all, I'm new and just trying to get OpenFoam running on WSL but can't get past this error. When I try to launch ParaView with paraFoam, I get the following message:
“: CommandLine Error: Option 'spirv-expand-step' registered more than once!
LLVM ERROR: inconsistency in registered CommandLine options”
Has anyone encountered this issue before, and if so, could you offer some advice on how to resolve it? I’ve been troubleshooting for a while and would appreciate any tips or steps to fix this error.
Thanks in advance!
x84645 is offline   Reply With Quote
Old   January 22, 2025, 05:00
Yann
Yann will become famous soon enoughYann will become famous soon enough
Hello Richard,
Do you need a specific feature from paraFoam which is not supported by the OpenFOAM native reader in ParaView?
If not, installing the windows version of ParaView works like a charm to visualize your results.
https://discourse.paraview.org/t/i-w...uld-i-use/7232
Yann is offline   Reply With Quote
Old   January 22, 2025, 20:20
Richard Bratton
Originally Posted by Yann View Post
Hello Richard,
Hi Yann. Thanks for the quick response and suggestion. I'm new at all of this and didn't know about the windows paraview version. I loaded it up and now it's working great. Thank you.
Yann likes this.
Old   January 26, 2025, 15:58
Default Issue with ParaView and VcXsrv on WSL2 (Ubuntu 24.04) - "Could not connect to display
rotnem is on a distinguished road
Hi everyone,
I’m having trouble running ParaView with VcXsrv on WSL2 (Ubuntu 24.04). When I try to run ParaView, I get the following error:
qt.qpa.xcb: could not connect to display 10.255.255.254:0
qt.qpa.plugin: Could not load the Qt platform plugin "xcb" in "" even though it was found.
This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Available platform plugins are: eglfs, linuxfb, minimal, minimalegl, offscreen, vnc, wayland-egl, wayland, wayland-xcomposite-egl, wayland-xcomposite-glx, xcb.
paraview:721 terminated with signal 6 at PC=7f351d7cfb1c SP=7ffd503f1240. Backtrace:
/usr/bin/../lib/x86_64-linux-gnu/libc.so.6(pthread_kill+0x11c)[0x7f351d7cfb1c]
/usr/bin/../lib/x86_64-linux-gnu/libc.so.6(gsignal+0x1e)[0x7f351d77626e]
/usr/bin/../lib/x86_64-linux-gnu/libc.so.6(abort+0xdf)[0x7f351d7598ff]
/usr/bin/../lib/x86_64-linux-gnu/libQt5Core.so.5(+0x91104)[0x7f351b656104]
/usr/bin/../lib/x86_64-linux-gnu/libQt5Gui.so.5(_ZN22QGuiApplicationPrivate25create PlatformIntegrationEv+0x17ad)[0x7f351bc746dd]
/usr/bin/../lib/x86_64-linux-gnu/libQt5Gui.so.5(_ZN22QGuiApplicationPrivate21create EventDispatcherEv+0x40)[0x7f351bc74c20]
/usr/bin/../lib/x86_64-linux-gnu/libQt5Core.so.5(_ZN23QCoreApplicationPrivate4initE v+0x8e5)[0x7f351b8a3ff5]
/usr/bin/../lib/x86_64-linux-gnu/libQt5Gui.so.5(_ZN22QGuiApplicationPrivate4initEv+ 0x2f)[0x7f351bc77b9f]
/usr/bin/../lib/x86_64-linux-gnu/libQt5Widgets.so.5(_ZN19QApplicationPrivate4initEv +0x15)[0x7f351cd4f5b5]
paraview(+0x112c4)[0x55e059fd12c4]
/usr/bin/../lib/x86_64-linux-gnu/libc.so.6(+0x2a1ca)[0x7f351d75b1ca]
/usr/bin/../lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0x8b)[0x7f351d75b28b]
paraview(+0x9b05)[0x55e059fc9b05]
My Setup:
WSL Version: WSL2
Linux Distribution: Ubuntu 24.04
ParaView: Installed via apt
VcXsrv: Installed on Windows
What I’ve Tried:
Verified that VcXsrv is running and configured with "Disable access control."
Any help or guidance would be greatly appreciated! Thank you in advance for your time and support.
Best regards,
rotnem is offline   Reply With Quote
parafoam crash, wsl2
courant number increases to rather large values 6863523 OpenFOAM Running, Solving & CFD 22 July 6, 2023 00:48
p_rgh initial residual no change with different settings manuc OpenFOAM Running, Solving & CFD 3 June 26, 2018 16:53
AMI interDyMFoam for mixer nu problem danny123 OpenFOAM Programming & Development 8 September 6, 2013 03:34
dynamic Mesh is faster than MRF???? sharonyue OpenFOAM Running, Solving & CFD 14 August 26, 2013 08:47
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
