[OpenFOAM.com] Problem when installing from source
Old   February 12, 2025, 11:25
Post Problem when installing from source
Persona is on a distinguished road
this is my first post here and hopefully not my last.
For a project, i need to install openfoam.com from source. I am following the instructions provided here
https://develop.openfoam.com/Develop...p/doc/Build.md
Note that i do not have root access so i had installed all the dependencies i needed with conda (not classical at all, i am aware of that but so far i can manage). After struggling a bit, i have the impression i am almost there.
Now, OpenFOAM complains while compiling OpenQBMM libraries, here is an extract of the log
wmake libso Vandermonde
     Ctoo: Vandermonde.C
     link: /scratch/OpenFoam/OpenFOAM-v2412/platforms/linux64GccDPInt32Opt/lib/libvandermonde.so
     /home/user/miniforge3/envs/OpenFoamEnv/bin/../lib/gcc/x86_64-conda-linux-gnu/14.2.0/../../../../x86_64-conda-linux-gnu/bin/ld: cannot find /scratch/OpenFoam/OpenFOAM-v2412/build/linux64GccDPInt32Opt/modules/OpenQBMM/src/Vandermonde/Vandermonde.o: No such file or directory
     collect2: error: ld returned 1 exit status
     make: *** [/scratch/OpenFoam/OpenFOAM-v2412/wmake/makefiles/general:210: /scratch/OpenFoam/OpenFOAM-v2412/platforms/linux64GccDPInt32Opt/lib/libvandermonde.so] Error 1
I have several similar errors and the problems always concern OpenQBMM libraries. Do you have any idea what i should do in this case?
Thanks in advance.
Persona is offline   Reply With Quote
[OpenFOAM.com] swak4foam compiling issues on a cluster saj216 OpenFOAM Installation 5 January 17, 2023 17:05
[Other] Tabulated thermophysicalProperties library chriss85 OpenFOAM Community Contributions 62 October 2, 2022 04:50
SU2-7.0.1 on ubuntu 18.04 hyunko SU2 Installation 7 March 16, 2020 05:37
[swak4Foam] Error bulding swak4Foam sfigato OpenFOAM Community Contributions 18 August 22, 2013 13:41
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 02:24
