[Sponsors] | |||||
[OpenFOAM.com] macOS Sequoia, Mpirun parallel problems |
Miguel Hernandez
Rep Power: 6 ![]() |
Hello to everyone.
Since I recently install MacOS Sequoia (15.4.1) I'm encountering this problem. It seems that I'm not able to run anymore snappyHexMesh in parallel mode! When I try this command: Code:
mpirun -np 16 snappyHexMesh -overwrite -parallel Code:
--> FOAM FATAL ERROR: (openfoam-2412)
The dummy Pstream library cannot be used in parallel mode
From static bool Foam::UPstream::init(int &, char **&, const bool)
in file UPstream.C at line 49.
FOAM exiting
FOAM exiting
FOAM exiting
FOAM exiting
FOAM exiting
FOAM exiting
FOAM exiting
FOAM exiting
FOAM exiting
FOAM exiting
FOAM exiting
FOAM exiting
FOAM exiting
FOAM exiting
FOAM exiting
FOAM exiting
prterun detected that one or more processes exited with non-zero status,
thus causing the job to be terminated. The first process to do so was:
Process name: [prterun-Mac-9514@1,2]
Exit code: 1
I have installed openFoam from gelato app HTML Code:
https://github.com/gerlero/openfoam-app Please, can someone help me? Thanks in advance. |
| Tags |
| macos, mpirun error, sequoia, snappyhesmesh |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Communication Deadlock in MPPICFoam Parallel Solver | auburnhpc | OpenFOAM Running, Solving & CFD | 1 | May 29, 2021 17:55 |
| MPI parallel meet problems | jiaojiao | OpenFOAM | 1 | May 10, 2016 03:30 |
| parallel Grief: BoundaryFields ok in single CPU but NOT in Parallel | JR22 | OpenFOAM Running, Solving & CFD | 2 | April 19, 2013 17:49 |
| Problems with MFIX code and Parallel Processing. | Fernando Pio | Main CFD Forum | 4 | August 29, 2006 15:33 |
| CFX - Parallel Problems | CFX User | CFX | 0 | November 1, 2004 19:12 |
