April 27, 2009, 13:56 |
OpenFOAM 1.5 installation on OpenSUSE 11.0
Philip Cardiff
Rep Power: 34 |
I am trying to install to install OF 1.5 (as downloaded from the OF website) on my OpenSUSE 11.0. My OpenSUSE 11.0 is a virtual machine but that shouldn't make any difference. So far I have: Downloaded the files from the OF website. Unpacked them in OpenFOAM directory. Added '. HOME/OpenFOAM/OpenFOAM-1.5.x/etc/bashrc' to my .bashrc, and sourced it. Then I am a bit confused, should the foam installation be set-up now or must I also compile it? At this stage I tried to run one of the tutorial cases (icoFoam) but blockMesh and icoFoam and any other program I ran got an error saying it was missing some library file. So then I tried to compile OF. I moved to the 'OpenFOAM-1.5' directory and executed './Allwmake' But this got quite a few errors. I resourced the bashrc and tried again but it still gets errors. The first error is: SOURCE=OPwrite.C ; g++ -m32 -Dlinux -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/home/philipc/OpenFOAM/ThirdParty/lam-7.1.4/platforms/linuxGccDPOpt/include -IlnInclude -I. -I/home/philipc/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude -I/home/philipc/OpenFOAM/OpenFOAM-1.5/src/OSspecific/Unix/lnInclude -fPIC -pthread -c $SOURCE -o Make/linuxGccDPOptLAM/OPwrite.o SOURCE=IPread.C ; g++ -m32 -Dlinux -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/home/philipc/OpenFOAM/ThirdParty/lam-7.1.4/platforms/linuxGccDPOpt/include -IlnInclude -I. -I/home/philipc/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude -I/home/philipc/OpenFOAM/OpenFOAM-1.5/src/OSspecific/Unix/lnInclude -fPIC -pthread -c $SOURCE -o Make/linuxGccDPOptLAM/IPread.o OPwrite.C:30:17: error: mpi.h: No such file or directory IPread.C:30:17: error: mpi.h: No such file or directory IPread.C:40: error: ‘MPI_Request’ was not declared in this scope IPread.C:40: error: template argument 1 is invalid IPread.C:40: error: invalid type in declaration before ‘;’ token IPread.C: In constructor ‘Foam::IPstream::IPstream(Foam::Pstream::commsType s, int, Foam::label, Foam::IOstream::streamFormat, Foam::IOstream::versionNumber)’: IPread.C:62: error: ‘MPI_Status’ was not declared in this scope etc. My foamInstallationTest is: Checking basic setup... ------------------------------------------------------------------------------- Shell: bash Host: linux-qqry OS: Linux version 2.6.25.18-0.2-pae ------------------------------------------------------------------------------- Checking main OpenFOAM env variables... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Crit ------------------------------------------------------------------------------- $WM_PROJECT_INST_DIR /home/philipc/OpenFOAM yes yes $WM_PROJECT_USER_DIR /home/philipc/OpenFOAM/philipc-1.5 yes no $WM_THIRD_PARTY_DIR /home/philipc/OpenFOAM/ThirdParty yes yes ------------------------------------------------------------------------------- Checking the OpenFOAM env variables set on the PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $WM_PROJECT_DIR /home/philipc/OpenFOAM/OpenFOAM-1.5 yes yes yes $FOAM_APPBIN ...M-1.5/applications/bin/linuxGccDPOpt yes yes yes $FOAM_USER_APPBIN ...c-1.5/applications/bin/linuxGccDPOpt yes yes no $WM_DIR .../philipc/OpenFOAM/OpenFOAM-1.5/wmake yes yes yes ------------------------------------------------------------------------------- Checking the OpenFOAM env variables set on the LD_LIBRARY_PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $FOAM_LIBBIN ...nFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt yes yes yes $FOAM_USER_LIBBIN ...enFOAM/philipc-1.5/lib/linuxGccDPOpt yes yes no $MPI_ARCH_PATH ...ty/lam-7.1.4/platforms/linuxGccDPOpt no yes ------------------------------------------------------------------------------- Third party software ------------------------------------------------------------------------------- Software Version Location ------------------------------------------------------------------------------- gcc 4.3.1 .../OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux/bin/gcc gzip 1.3.12 /usr/bin/gzip tar 1.19 /bin/tar icoFoam WARNING: Conflicting installations: OpenFOAM settings : /home/philipc/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/icoFoam current path : CRITICAL ERROR ------------------------------------------------------------------------------- Checking networking... ------------------------------------------------------------------------------- Action Result Crit ------------------------------------------------------------------------------- Pinging_linux-qqry Successful yes Pinging_localHost Successful yes Test_rsh: Unsuccessful_connection_refused* yes Test_ssh: Successful yes (*) Only one of rsh or ssh is required by the OpenFOAM enviroment. ------------------------------------------------------------------------------- Base configuration ok. The foam installation contains 1 critical error(s). Review the output for warning messages and consult the installation guide for trouble shooting. done. Any help or guidance would be much appreciated, Philip |
April 27, 2009, 14:42 |
Hy Yu
Rep Power: 17 |
Hi Philip,
I think that you need only to install OF. If you download the files from OpenFOAM website and unpack them correctly. The last thing you need to check and do is: add the following line in your "~/.bashrc" " . $Home/OpenFOAM/OpenFOAM-1.5/etc/bashrc" then source the edited .bashrc. Everything should be OK. I am not sure which version of OF you have downloaded. If you download OF-1.5, it is easy to install. If it is OF-1.5.x, it should be compiled. Hongyi |
April 28, 2009, 04:23 |
Samuele
Rep Power: 17 |
You are getting the same errors I was used to. Did you download and unpack the "Binary pack, double precision" in the OpenFOAM directory?
Remember that after the set-up of the files, you have to compile ParaView first and OpenFOAM later, as indicated in the READ ME file. Otherwise the program won't work. |
April 28, 2009, 04:42 |
Philip Cardiff
Rep Power: 34 |
Hi Hongyi and StructureITA,
Thanks for the help. I downloaded OF 1.5 (not OF 1.5.x) from the OF website. After I unpacked the for files (including the binary pack, double precision), and after I added the line into my '.bashrc' and sourced it, I was still getting an error when I tried to run anything such as blockMesh or icoFoam. I got an error saying error while loading shared library 'libPstream.so'. I found 'libPstream.so' in 'OpenFOAM-1.5/lib/linuxGccDPOpt/dummy/' directory, and when I copied it into the 'OpenFOAM-1.5/lib/linuxGccDPOpt/' directory, then blockMesh and icoFoam and the other solvers seemed to work fine. Why is this? Now paraFoam is the next step, it gets an error saying error while loading shared library lipmpi.so.0. According to the website, I must recompile it with the correct version of Qt. My version of OpenSUSE has 4.4 installed. I can't figure out how to download and install Qt4.3 from the link on the site: http://download.opensuse.org/repositories/KDE:/Qt43 I am quite new to linux, and I can't figure out which file I am meant to download and what do I do with it? Any help is really appreciated. One last thing, when I recompile paraView, must I also then recompile OF? Thanks, Philip |
April 28, 2009, 04:58 |
#5 | |
Samuele
Rep Power: 17 |
MESSAGE(SEND_ERROR “Qt ${QTVERSION} not supported. Please use Qt 4.3 (you may need to clean your dirtied cache).”)Yes. |
April 28, 2009, 05:23 |
Philip Cardiff
Rep Power: 34 |
StructureITA,
Thanks for the help. I did as you said and I am recompiling paraView now. I'll then try recompiling OF and let you know how I get on. Thanks again. Philip |
April 28, 2009, 13:40 |
Philip Cardiff
Rep Power: 34 |
I was able to compile paraFoam but I get errors when I try compile OF:
The first error seems to be: + cd /home/philipc/OpenFOAM/ThirdParty/lam-7.1.4 + make distclean make: *** No rule to make target `distclean'. Stop. + rm -rf /home/philipc/OpenFOAM/ThirdParty/lam-7.1.4/platforms/linuxGccDPOpt + ./configure --prefix=/home/philipc/OpenFOAM/ThirdParty/lam-7.1.4/platforms/linuxGccDPOpt --enable-shared --disable-static --without-romio --without-mpi2cpp --without-profiling --without-fc ./Allwmake: line 66: ./configure: No such file or directory + make make: *** No targets specified and no makefile found. Stop. + make install make: *** No rule to make target `install'. Stop. + make distclean make: *** No rule to make target `distclean'. Stop. And then shortly after that I get IPread and OPwrite errors: OPwrite.C:30:17:IPread.C:30:17: error: mpi.h: No such file or directory error: mpi.h: No such file or directory IPread.C:40: error: ‘MPI_Request’ was not declared in this scope IPread.C:40: error: template argument 1 is invalid IPread.C:40: error: invalid type in declaration before ‘;’ token OPwrite.C:38: error: ‘MPI_Request’ was not declared in this scope OPwrite.C:38: error: template argument 1 is invalid I am not sure what's going wrong. Any ideas would be really helpful. |
April 28, 2009, 14:02 |
Philip Cardiff
Rep Power: 34 |
I am not sure if the first error matters, but the second error seems to be happening when './Allwmake' is being executed in the 'OpenFOAM-1.5/src/Pstream' directory, where:
OPwrite.C:30:17: error: mpi.h: No such file or directory is the first problem. |
April 29, 2009, 03:15 |
#9 | |
Mark Olesen
Rep Power: 40 |
The directory pointed to by $MPI_ARCH_PATH should contain the usual bin/, include/, lib/ ... subdirectories. Check these for the "mpi.h" file. |
April 29, 2009, 04:46 |
#10 | |
Philip Cardiff
Rep Power: 34 |
Thanks for your help. Quote:
In $MPI_ARCH_PATH, there is an empty 'bin/' directory and an empty 'lib/' directory and also no 'include/' directory. When I run './Allwmake' in the 'OpenFOAM/ThirdParty' directory, the first error seems to be: + cd /home/philipc/OpenFOAM/ThirdParty/lam-7.1.4 + make distclean make: *** No rule to make target `distclean'. Stop. + rm -rf /home/philipc/OpenFOAM/ThirdParty/lam-7.1.4/platforms/linuxGccDPOpt + ./configure --prefix=/home/philipc/OpenFOAM/ThirdParty/lam-7.1.4/platforms/linuxGccDPOpt --enable-shared --disable-static --without-romio --without-mpi2cpp --without-profiling --without-fc ./Allwmake: line 66: ./configure: No such file or directory + make where it can't seem to find './configure'. why can't it find this file, I tried extracting the two ThirdParty archives again and recompiling but I get the same error. Thanks again for your help, Philip. |
April 29, 2009, 04:58 |
#11 | |
Mark Olesen
Rep Power: 40 |
April 29, 2009, 05:06 |
#12 |
Philip Cardiff
Rep Power: 34 |
I checked the 'ThirdParty/openmpi-1.2.6/platforms/linuxGccDPOpt' directory, and all the files seem to be there - 'bin/','include/' and 'lib/' directories.
How do I change it so as to try use 'openmpi' instead of 'lam'? Thanks very much for your help |
April 29, 2009, 05:16 |
#13 |
Mark Olesen
Rep Power: 40 |
The setting WM_MPLIB (set in the etc/{bashrc,cshrc}) controls which mpi library you'll be using. The version information is in the etc/settings.{sh,csh}. In my version, the WM_MPLIB is set to OPENMPI by default, so I don't know why your installation ended up with LAM.
good luck. /mark |
April 29, 2009, 05:50 |
#14 | |
Philip Cardiff
Rep Power: 34 |
It's a bit strange, I am not sure why it's changing to lam. I tried copying the contents of 'ThirdParty/openmpi-1.2.6/platforms/linuxGccDPOpt' to 'ThirdParty/lam-7.1.4/platforms/linuxGccDPOpt', and then I tried 'Allwmake' in the 'ThirdParty' directory, and it seemed to get past the error but then got another error straight after: + cd ParMetis-3.1 + wmake libso METISLib /usr/bin/ld: cannot find -llam collect2: ld returned 1 exit status make: *** [/home/philipc/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/lam-7.1.4/libmetis-parmetis.so] Error 1 Why is it using LAM when it's set to OPENMPI. |
April 29, 2009, 06:02 |
#15 | ||
Mark Olesen
Rep Power: 40 |
Pehaps the bash guide might be of some help: http://www.tldp.org/LDP/abs/html/index.html Quote:
April 29, 2009, 06:14 |
#16 |
Philip Cardiff
Rep Power: 34 |
SUCCESS!
The bashrc was set to OPENMPI but I didn't know that WM_MPLIB is only conditionally set so I executed: unset WM_MPLIB then I sourced the bashrc, I then ran './Allwmake' in the 'ThirdParty' directory and it finished with no errors. It had a few warnings but I think they are OK. Now on to compile the rest of OF. Thanks for your patience and help. |
April 29, 2009, 06:28 |
OpenFOAM compiled
#17 |
Philip Cardiff
Rep Power: 34 |
OpenFOAM compiled fine and the first tutorial case seems to be grand!
Thanks very much for your help, It is really appreciated! ParaFoam is kinda working but not quite right but I'll try compile again, and hopefully sort it out. Thanks for your help, Philip C. |
Critical errors during OpenFoam installation in OpenSuse 11.0 | amscosta | OpenFOAM | 5 | May 1, 2009 14:06 |
Installing OpenFOAM 1.5 on OpenSUSE 11.1 | StructureITA | OpenFOAM Installation | 31 | April 30, 2009 19:45 |
Problem installing OpenFOAM 1.5 installation on RHEL 4. | vwsj84 | OpenFOAM Installation | 4 | April 23, 2009 04:48 |
64bitrhel5 OF installation instructions | mirko | OpenFOAM Installation | 2 | August 12, 2008 18:07 |
Adventure of fisrst openfoam installation on Ubuntu 710 | jussi | OpenFOAM Installation | 0 | April 24, 2008 14:25 |
