Installing OpenFoam141dev vtk errors
Old   February 11, 2009, 02:54
Default Hi everyone, I hope someone
cvv
Carel
cvv is on a distinguished road
Hi everyone,
I hope someone can help me.
Im am trying to install OpenFoam 1.4.1-dev on a SLED10.2 - 64bit machine. We have managed to get most of the compiler issues sorted out. For instance there were a couple of places where the paths were still /home/dm2/henry...
I still get problems when I want to compile Paraview. The compiler is GCC 4.2.1. and Paraview 2.4.4 is installed.
The problem I have is that when I want to run cmake get the following error.
~/OpenFOAM/OpenFOAM-1.4.1-dev/applications/utilities/postProcessing/graphics/PVF oamReader/PVFoamReader/Make/linux64GccDPOpt> cmake ../..
-- VTK not found. Set the VTK_DIR cmake cache entry to the directory containing VTKConfig.cmake. This is either the root of the build tree, or PREFIX/lib/vtk for an installation. For VTK 4.0, this is the location of UseVTK.cmake. This is either the root of the build tree or PREFIX/include/vtk for an installation.
CMake Error at CMakeLists.txt:60 (VTK_WRAP_ClientServer):
Unknown CMake command "VTK_WRAP_ClientServer".
I added the following lines in the file CMakeCache.txt in the directory ~/OpenFOAM/OpenFOAM-1.4.1-dev/applications/utilities/postProcessing/graphics/PVF oamReader/PVFoamReader
where the cmake command is pointing to:
//Path to VTK
VTK_DIR:PATH=/home/carel/OpenFOAM/linuxSrc/paraview-2.4.4-linux/VTK
but it looks like it stall cannot find VTK, although the file VTKConfig.cmake does reside in the above directory. If I check the variables with ccmake it does show the VTK_DIR correctly.
Any ideas?
As a side note if I run paraFoam on the cavity case for instance I get the following errors:
ErrorMessage
# Error or warning: There was a VTK Error in file: /home/dm2/henry/OpenFOAM/linuxSrc/paraview-2.4.4/GUI/Client/vtkPVWindow.cxx (2366)
vtkPVWindow (0x86bc00): Cannot read file information when no reader is specified. This probably means that the reader for the file with name: /home/carel/OpenFOAM/carel-1.4.1-dev/run/cavity/cavity.foam cannot be found
ErrorMessage end
ErrorMessage
# Error or warning: There was a VTK Error in file: /home/dm2/henry/OpenFOAM/linuxSrc/paraview-2.4.4/GUI/Widgets/vtkKWApplication.cx x (1335)
vtkPVApplication (0x61a890):
Script:
paraFoam.pvs
Returned Error on line 11:
invalid command name ""
ErrorMessage end
I believe this will dissapear once we get Paraview to compile?
Regards,
Carel
cvv is offline   Reply With Quote
OpenFOAM141dev A new implementation of dynamicKistlerGammaContactAngle eberberovic OpenFOAM Running, Solving & CFD 26 June 10, 2021 04:08
SpaceVaryingGammaContactAngle in OpenFOAM141dev asaha OpenFOAM Running, Solving & CFD 0 January 23, 2009 10:16
Errors with surfactantFoam While Compiling OpenFOAM141dev from extends chegdan OpenFOAM Installation 1 July 3, 2008 21:10
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
CoupledFvScalarMatrix in OpenFOAM141dev oleg_weinstein OpenFOAM Installation 6 December 13, 2007 13:16
