Installation of OpenFoam 15 Compilation paraview |
July 16, 2008, 15:22 |
Dear all,
i tried to instal
Soeren Brot
Dear all,
i tried to install OpenFoam 1.5 today, everything looks fine until the compilation of paraview. Additional information: -Ubuntu 8.04 -"qmake --version QMake version 2.01a Using Qt version 4.3.4 in /usr/lib" -OpenFoam 1.4.1 worked properly As I am a more or less beginner in Linux, I used the the "installation guide" on the website and especially the README file. Typing the commands: * cd $FOAM_INST_DIR/ThirdParty * rm -rf ParaView3.3-cvs/platforms * buildParaView3.3-cvs the last one produces following error message: "soeren@soeren-laptop:~/OpenFOAM/ThirdParty$ buildParaView3.3-cvs Building ParaView3.3-cvs MPI support : OFF Python support : OFF MESA support : OFF Source : /home/soeren/OpenFOAM/ThirdParty/ParaView3.3-cvs Target : /home/soeren/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc -- Check for working C compiler: /home/soeren/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux/bin/gcc -- Check for working C compiler: /home/soeren/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux/bin/gcc -- broken CMake Error: The C compiler "/home/soeren/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux/bin/gcc" is not able to compile a simple test program. It fails with the following output: /usr/bin/make -f CMakeFiles/cmTryCompileExec.dir/build.make CMakeFiles/cmTryCompileExec.dir/build make[1]: Betrete Verzeichnis '/home/soeren/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc/CMakeFiles/ CMakeTmp' /home/soeren/OpenFOAM/ThirdParty/cmake-2.4.6/platforms/linux/bin/cmake -E cmake_progress_report /home/soeren/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc/CMakeFiles/C MakeTmp/CMakeFiles 1 Building C object CMakeFiles/cmTryCompileExec.dir/testCCompiler.o /home/soeren/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux/bin/gcc -o CMakeFiles/cmTryCompileExec.dir/testCCompiler.o -c /home/soeren/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc/CMakeFiles/C MakeTmp/testCCompiler.c /home/soeren/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux/bin/../libexec/gcc/i6 86-pc-linux-gnu/4.3.1/cc1: error while loading shared libraries: libmpfr.so.1: cannot open shared object file: No such file or directory make[1]: *** [CMakeFiles/cmTryCompileExec.dir/testCCompiler.o] Fehler 1 make[1]: Verlasse Verzeichnis '/home/soeren/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc/CMakeFiles/ CMakeTmp' make: *** [cmTryCompileExec/fast] Fehler 2 CMake will not be able to correctly generate this project. -- Configuring done make: *** Keine Targets angegeben und keine ğmakeĞ-Steuerdatei gefunden. Schluss. " Seems that the compiler does not work... I would greatly appreciate any help on how to resolve this problem! Thanks a lot in advance Sören |
July 16, 2008, 16:25 |
I am having exactly the same p
Ning Yang
I am having exactly the same problem.
July 17, 2008, 02:31 |
The new gcc requires gmp and m
Mark Olesen
Rep Power: 40 |
The new gcc requires gmp and mpfr to be installed. The details and rationale can be found here: changes.html
They might not be installed by default on slightly older systems. |
July 17, 2008, 03:06 |
i am having a problem with ins
mayank gupta
i am having a problem with installing openfoam.....my connection to ssh and rsh is failing...i work in a network.,....then when i run blockMesh . cavity
i get the error no such file or directory.but i have sourced the file correctly........can ne1 help me..it has been 2 weeks with this problem.... |
July 17, 2008, 03:42 |
From synaptic in Ubuntu 8.04 i
Javier Ros
From synaptic in Ubuntu 8.04 it seems that the packages you need are
libmpfr-dev libmpfr1|dbl May be that the second one is enough. Do a search in synaptic with the string mpfr and they will arise. Javier |
July 20, 2008, 10:38 |
hi,
I have another problem
name
hi,
I have another problem with ParaView. In my thirdparty folder there's no platforms directory and also no buildParaview3.3-cvs. Why is that? Thanks |
July 22, 2008, 04:56 |
Thanks a lot!
Including "libm
Soeren Brot
Thanks a lot!
Including "libmpfr-dev + libmpfr1|dbl" resolved my problem, everything fine now! Sören |
July 23, 2008, 08:17 |
I have the exactly same
Hy Yu
I have the exactly same problem as Seoren. However the configuration of my laptop a little different: Debian qmake --version QMake version 2.01a Using Qt version 4.3.1 in /usr/local/Trolltech/Qt-4.3.1/lib And I got the entirely same error message as Seoren. what should I do? Thanks a lot! Yu |
July 23, 2008, 18:26 |
Hello !
I compiled Paraview
victor
Hello !
I compiled Paraview and it works. I have SLED SP1 and installed from scratch the following: gmp (with ABI=64) mpfr gcc-4.3.1 (in the same path as stated in the README) qt-X11-opensource-src-4.3.5 and then buildParaView3.3-cvs, which worked. However, with Qt-4.3.1 it compiled as well, but, I had the problem regarding ".OpenFOAM" extension, and hence got to do the FoamToVTK procedure as Alberto suggest in a similar thread. Hope it helps best V |
July 24, 2008, 02:23 |
I have same problem
Djeghri Noureddine
I have same problem as Soeren had. my question is that i dont find libmpfr1|dbl. I have ubuntu 8.04. Thnks, Noureddine |
July 24, 2008, 02:36 |
hi while installing openFoam-1
#11 |
mayank gupta
hi while installing openFoam-1.5, when i m trying to source the file, i am getting errors
bash:~/............./apps/bin/foamcleanpath:no such file or directory... bash:~/.................../apps.paraview:no such file or directory such a thing is coming for many apps. can sum1 help? |
August 14, 2008, 10:38 |
I am trying to install openfoa
#12 |
Nishant
I am trying to install openfoam-1.5 and I can successfully run the case with bloclkmesh and solver commands (like icoFoam etc)
But paraFoam command is not working well. I have qt-4.3.5 installed by default in my FEDORA-9. I checked the GMP and MPFR installation as well. The error it is reposting is:- [343880@w191-210 channel395]$ paraFoam paraview: error while loading shared libraries: libQtAssistantClient.so.4: cannot open shared object file: No such file or directory can anybody help? regards, Nishant
Thanks and regards, Nishant |
August 14, 2008, 17:07 |
Hi Nishant
I guess compilat
#13 |
Rep Power: 18 |
Hi Nishant
I guess compilation is the only way out as the README document has explicity mentioned that the binaries of installation version will work only with Qt-4.3.1 . Please be kind to study the README and installation document provided . here is the link: http://www.opencfd.co.uk/openfoam/doc/README.html Please scroll down on this page and it details all the possible solutions. Hope that might solve your problem. With Best Regards Jaswi |
August 14, 2008, 17:43 |
Hello,Nishant Singh
I us
#14 |
Hua Zen
Hello,Nishant Singh
I use fedora9,it works for me.For the missing file,libQtAssistantClient.so.4,you need to install the package qt-x11-4.3.5-2.fc9.i386. Hope it helps |
August 14, 2008, 21:25 |
Nishant, I had to copy my Qt l
#15 |
Gene
Nishant, I had to copy my Qt libs and .so files over to /usr/libs; than re-ran through the paraview3.3 steps in the install documentation. That seemed to work for me.
If you got as far as you say, then you're probably just missing this last part. |
August 14, 2008, 23:07 |
hi jaswi
I go thru the REA
#16 |
Nishant
hi jaswi
I go thru the README file but I considered that the Qt version should be in between 4.3 and 4.4. Anyways, the problem at hand is that I have two installations of Qt - 1) qt 3.3 and 2) qt 4.3.5. Linz, I installed the same package but 4.3.5 but in my case there is dual installation of qt 3.3 and 4.3.5. Gene, I tried making a symbolic link through ln -s command for the lib folder b/w /usr/local/trolltech/qt-4.3.5/lib and /usr/lib/. but that didnt work. Will it be work, if i simply copy and recompile it? I will try this way. Thanks all... Nishant
August 14, 2008, 23:25 |
Hello, Nishant
Since I also
#17 |
Hua Zen
Hello, Nishant
Since I also use fedora 9,I could confirm that your problem is not related double qt version.For me,I also have two qt versions installed. [root@phy-208 ~]# rpm -q qt qt-4.3.5-2.fc9.i386 [root@phy-208 ~]# rpm -q qt3 qt3-3.3.8b-14.fc9.i386 The only answer I know is that you missing file libQtAssistantClient.so.4 is contained in the package qt-x11-4.3.5-2.fc9.i386. |
August 21, 2008, 10:40 |
Dear all!
I have the same p
#18 |
Aram Amouzandeh
Dear all!
I have the same problem as Martin. when i have a look at the linuxGccDPOpt/ directory it is empty, when i want to generate a mesh for the cavity case, the bashrc doesn t know the blockMesh command: [aa@lws16 icoFoam]$ blockMesh . cavity bash: blockMesh: command not found thx a lot in advance for any comments! aram |
August 21, 2008, 11:31 |
I tried to install OpenFoam 1.
#19 |
zhangting
I tried to install OpenFoam 1.5 today,I faced the problem just like Soeren described.
My OS is Mandriva2007,I have Qt version 4.3.2, and today I have installed gmp4.2.1 and mpfr 2.3.1,I think these meet the install requirment .but I can't bulidparaview. produces error message: like Soeren described This is the first time for me to install OF.I feel so confused , could any one help me?Thanks a lot! |
August 28, 2008, 22:01 |
I am a new Linux us
#20 |
Ying
I am a new Linux user and have Ubuntu 8.04 (64 bit) and OpenFOAM 1.5 (64 bit) on my laptop. The following is the error msg: Building ParaView3.3-cvs MPI support : OFF Python support : OFF MESA support : OFF Source : /home/then/OpenFOAM/ThirdParty/ParaView3.3-cvs Target : /home/then/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linux64Gcc /home/then/OpenFOAM/OpenFOAM-1.5/bin/buildParaView3.3-cvs: 64: cmake: not found make: *** No targets specified and no makefile found. Stop. done I followed the instructions in this thread and installed 2 libmpfr files, but still have the same error. Still trying to figure out why... Any comments? Thanks. |
[OpenFOAM] Paraview installation problem | mcjicpm2 | ParaView | 0 | March 9, 2009 07:15 |
ParaView Compilation | jakaranda | OpenFOAM Installation | 3 | October 27, 2008 11:46 |
Compilation error with paraview | quartzian | OpenFOAM Installation | 0 | September 21, 2008 08:32 |
Error building DICOMAppHelper during ParaView compilation | geoffjay | OpenFOAM Installation | 1 | May 7, 2008 13:07 |
Paraview installation problem please help | bender | OpenFOAM Installation | 2 | February 27, 2006 05:00 |
