OpenFOAM14 linux64 paraview canbt find libtcl84so and libtk84so
Old   April 12, 2007, 22:14
Default Problem: When running paravi
Jason Hoogland
hoogland is on a distinguished road
Problem:
When running paraview on 64 bit gentoo:
${HOME}/OpenFOAM/linux64/paraview-2.4.4/lib/paraview-2.4/paraview-real: error while loading shared libraries: libtcl8.4.so: cannot open shared object: No such file or directory
Cause:
Old tcl/tk installation on machine.
Solution:
Install/upgrade to tcl/tk-8.4 .
Outcome:
paraview now works fine.
Jason
hoogland is offline   Reply With Quote
Old   September 22, 2007, 15:00
Default Same problem occured under ubu
Andreas Birgel
andi_hape is on a distinguished road
Same problem occured under ubuntu 7.04. 64 bit.
Same solution, but additional on that created two links:
libtcl8.4.so -> libtcl8.4.so.0
libtk8.4.so -> libtk8.4.so.0
Andi
andi_hape is offline   Reply With Quote
Old   June 26, 2008, 08:21
Default Hi Jason, forgive me for my
Hy Yu
ttdtud is on a distinguished road
Hi Jason,
forgive me for my stupid question: how can i install/upgrade "old tcl/tk" to "tcl/tk-8.4"?
thanks a lot in advance.
Hy
ttdtud is offline   Reply With Quote
Old   June 26, 2008, 09:13
Default If you want the easier way of
Jason Hoogland
If you want the easier way of precompiled binaries, depends on your system. What is your system. What is the output of "uname -a"?
Alternatively you could just download the tarball and compile, but it sounds like you should go the former.
hoogs
Old   June 26, 2008, 10:12
Default Hi Jason, "uname -a" says: Li
Hy Yu
Hi Jason,
"uname -a" says: Linux ttdws93 2.6.18-4-amd64 #1 SMP Fri May 4 00:37:33 UTC 2007 x86_64 GNU/Linux
and i use Debian.
Actually i have found how man can download and compile it but i am not sure so i think the former way you mentioned is better for me.
thank u very much!
hy
Old   June 26, 2008, 12:38
Default If you have your repositories
Jason Hoogland
If you have your repositories sorted out (/etc/apt/repos.d or similar from memory), use
> sudo aptitude install tcl8.4 tk8.4
hoogs
[OpenFOAM] ParaView 33 canbt open OpenFoam file hariya03 ParaView 7 September 25, 2008 17:33
Linux64 Installation usker Siemens 3 March 20, 2007 04:23
Does Fluent 6.3 LINUX64 run on EMT64 processors? Joe FLUENT 2 January 11, 2007 10:29
FoamX canbt find applications ingaerme OpenFOAM Pre-Processing 8 December 12, 2006 14:56
[OpenFOAM] HI all I cant find display button in paraview when i execute cavity tutorial there is only parameter button in the paraview chan ParaView 2 February 13, 2006 07:37
