June 7, 2008, 06:02 |
Am I definitely at odds
bloblo
Am I definitely at odds with openfoam ? When I try to set boundary conditions, the only choise I have for 'wall' is 'wallfunctions'. The only one I have for 'inlet' is 'pressureInlet', and so on, whereas I am sure I had in the past 'adiabaticWall', 'turbulentInlet', .... The thing is, I can't even set it in the boundary file or I got : Invalid boundary type name 'adiabaticWall' What's the pb, according to you ? Regards. |
June 9, 2008, 11:21 |
Hi Bloblo!
You're taking ab
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Hi Bloblo!
You're taking about seeting the BCs in FoamX, right? 'adiabaticWall', 'turbulentInlet' etc are "only" the physicalTypes, which are a) only used by FoamX b) depend on the solver your project is under So if you have an isothermal solver like icoFoam you won't get the boundaryCondition 'adiabaticWall', (because it doesn't make sense) Bernhard
Problem with boundary type | Shanti | FLUENT | 2 | May 27, 2012 04:19 |
Invalid thermal boundary condition | azraf | Siemens | 2 | July 18, 2008 04:52 |
invalid type for binary expression: double / funct | Fiachra | FLUENT | 0 | April 12, 2007 08:04 |
pdf_initial_enthalpy: Invalid pdf type | mneo | FLUENT | 0 | October 12, 2006 11:45 |
error: CDR: invalid argument [1]: wrong type | Marc | FLUENT | 0 | July 24, 2006 05:59 |
