May 16, 2008, 04:52 |
I'm trying to compile Ope
peter anderson
I'm trying to compile OpenFoam with Ubuntu 8.04 and among other I get an error message : `/home/peter/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/liberrorEstimation.so' is up to date. + wmake libso Gstream /usr/bin/ld: cannot find -lXext collect2: ld returned 1 exit status make: *** [/home/peter/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libGstream.so] Error 1 Can anybody tell me what library I'm missing and how to get/install one ? Thanks Peter |
May 16, 2008, 07:36 |
Hi Peter
The names of any o
Rep Power: 18 |
Hi Peter
The names of any of the missing libraries is normally given in the error message. Just remove the "l" which stands for library I guess and rest of that is what you are looking for. As in your case the error message says: cannot find -lXext implies that you do not have Xext library and about.com says the following about it: http://linux.about.com/cs/linux101/g/xext.htm Well the next step would be to install that missing lib und voila monsieur:-) Hope that helps Regards Jaswi |
May 16, 2008, 07:48 |
Peter,
Even if you have lib
Mark Olesen
Rep Power: 40 |
Peter,
Even if you have libXext installed, it could still be that it doesn't get linked properly. For example, if you are compiling a 32-bit OpenFOAM on a 64-bit machine with 64-bit libs installed. AFAIK the libGstream is no longer actually used by any of the current OpenFOAM applications. Skip the compilation of the library entirely and it'll probably be okay anyhow. |
UDF compilation error | Szabolcs Varga | Fluent UDF and Scheme Programming | 4 | September 14, 2015 05:27 |
usrbinld cannot find | doug | OpenFOAM Installation | 19 | November 4, 2010 14:15 |
udf compilation error | sdp | FLUENT | 0 | February 5, 2009 02:58 |
UDF compilation error | Hari | FLUENT | 0 | February 22, 2008 13:40 |
Compilation error | Rajneesh | FLUENT | 0 | November 11, 2005 16:52 |
