Error building DICOMAppHelper during ParaView compilation
Old   May 5, 2008, 18:03
Default While compiling paraview 2.4.4
Geoff Johnson
geoffjay is on a distinguished road
While compiling paraview 2.4.4 on SuSE 10.1 I get to section for compiling vtk and I get:
Linking C executable ../../../bin/ProcessShader
[ 14%] Built target ProcessShader
[ 14%] Generating vtkMaterialXMLLibrary.h
[ 14%] Built target vtkMaterialLibraryConfiguredFiles
Scanning dependencies of target vtkDICOMParser
[ 14%] Building CXX object VTK/Utilities/DICOMParser/CMakeFiles/vtkDICOMParser.dir/DICOMAppHelper.o
/apps/OpenFOAM/linuxSrc/paraview-2.4.4/VTK/Utilities/DICOMParser/DICOMAppHelper. cxx: In member function #virtual void DICOMAppHelper::ImagePositionPatientCallback(DICOM Parser*, doublebyte, doublebyte, DICOMParser::VRTypes, unsigned char*, quadbyte)#:
/apps/OpenFOAM/linuxSrc/paraview-2.4.4/VTK/Utilities/DICOMParser/DICOMAppHelper. cxx:587: error: #memcpy# was not declared in this scope
/apps/OpenFOAM/linuxSrc/paraview-2.4.4/VTK/Utilities/DICOMParser/DICOMAppHelper. cxx:609: error: #memcpy# was not declared in this scope
/apps/OpenFOAM/linuxSrc/paraview-2.4.4/VTK/Utilities/DICOMParser/DICOMAppHelper. cxx: In member function #virtual void DICOMAppHelper::TransferSyntaxCallback(DICOMParser *, doublebyte, doublebyte, DICOMParser::VRTypes, unsigned char*, quadbyte)#:
/apps/OpenFOAM/linuxSrc/paraview-2.4.4/VTK/Utilities/DICOMParser/DICOMAppHelper. cxx:699: error: #strcmp# was not declared in this scope
/apps/OpenFOAM/linuxSrc/paraview-2.4.4/VTK/Utilities/DICOMParser/DICOMAppHelper. cxx: In member function #const char* DICOMAppHelper::TransferSyntaxUIDDescription(const char*)#:
/apps/OpenFOAM/linuxSrc/paraview-2.4.4/VTK/Utilities/DICOMParser/DICOMAppHelper. cxx:1002: error: #strcmp# was not declared in this scope
make[2]: *** [VTK/Utilities/DICOMParser/CMakeFiles/vtkDICOMParser.dir/DICOMAppHelper.o] Error 1
make[1]: *** [VTK/Utilities/DICOMParser/CMakeFiles/vtkDICOMParser.dir/all] Error 2
make: *** [all] Error 2
I've compiled gcc, and cmake, but not binutils. The version of binutils that I have looked new enough and has the demangle.h library, is it still a good idea to compile it under the OpenFOAM directory?
I'm using the install document at:
http://openfoamwiki.net/index.php/Ho...mpile_OpenFOAM
geoffjay is offline   Reply With Quote
Old   May 7, 2008, 14:07
Default I recompiled everything in the
Geoff Johnson
I recompiled everything in the order binutils, gcc, gdb, cmake, paraview, openfoam and now things are mostly working. Past this section anyways.
Building paraview neilm OpenFOAM Installation 8 October 12, 2009 14:03
Installation of OpenFoam 15 Compilation paraview soeren_brot OpenFOAM Installation 45 January 12, 2009 07:39
ParaView Compilation jakaranda OpenFOAM Installation 3 October 27, 2008 12:46
Compilation error with paraview quartzian OpenFOAM Installation 0 September 21, 2008 09:32
[OpenFOAM] Building Paraview with reader builtin instead of parafoam script tj22 ParaView 2 April 7, 2006 13:55
