Error while compiling FoamX related applications |
May 7, 2008, 13:21 |
When I run FoamX I receive an
Geoff Johnson
Rep Power: 17 |
When I run FoamX I receive an error saying that it can't find FoamXHostBrowser, which FoamXHostBrowser confirms this so I've tried to recompile the source in the directory ~/OpenFOAM/OpenFOAM-1.4.1/applications/utilities/preProcessing/FoamX/C++ and I get the following error output:
/Allwmake + case $WM_ARCH in + CMD='wmake libso' + cd FoamXServer + wmake libso `/apps/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libFoamXServer.so' is up to date. + cd FoamXLib + wmake libso /usr/bin/ld: cannot find -lssl collect2: ld returned 1 exit status make: *** [/apps/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libFoamX.so] Error 1 + cd FoamXHostBrowser + wmake g++ -m64 -Dlinux64 -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -march=opteron -O3 -DNoRepository -ftemplate-depth-40 -I/apps/OpenFOAM/OpenFOAM-1.4.1/src/mico-2.3.12/platforms/linux64GccDPOpt/includ e -Wno-old-style-cast -I../FoamXLib/lnInclude -I../FoamXServer -IlnInclude -I. -I/apps/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude -fPIC Make/linux64GccDPOpt/FoamXHostBrowser.o Make/linux64GccDPOpt/IHostBrowserImpl.o -L/apps/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt \ -lFoamX -lFoamXServer -L/apps/OpenFOAM/OpenFOAM-1.4.1/src/mico-2.3.12/platforms/linux64GccDPOpt/lib -lmicocoss2.3.12 -lmico2.3.12 -lssl -lcrypto -ldl -lpthread -lOpenFOAM -liberty -ldl -lm -o /apps/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linux64GccDPOpt/FoamXHostBrowser /usr/bin/ld: cannot find -lFoamX collect2: ld returned 1 exit status make: *** [/apps/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linux64GccDPOpt/FoamXHostBrowser ] Error 1 (... error output continues but is similar for the other applications in the directory) My system is SuSE 10.1 x86_64, and according to foamInstallationTest everything is correct with my installation. Does anyone know where I should look? At one point the error says "cannot find -lFoamX", does this mean another part of of my Foam installation is incomplete? |
May 7, 2008, 17:11 |
> /usr/bin/ld: canno
Martin Beaudoin
Rep Power: 22 |
> /usr/bin/ld: cannot find -lssl You are missing a library called libssl. You need this library in order to link an application based on Mico/Corba. Encryption is part of the communication layer of Corba, so you need to have the dev package for libopenssl on your system. On my SuSE 10.3 x86_64 system, libssl.a is provided by the following RPM: libopenssl-devel-0.9.8e-45.5. Martin |
May 7, 2008, 19:43 |
Argh. Thanks. I didn't even se
Geoff Johnson
Rep Power: 17 |
Argh. Thanks. I didn't even see that error message. I feel a little silly now.
Display Modes | |
Errors when Compiling UDF: error C2040/error C2099 | Julian K. | FLUENT | 1 | December 21, 2008 00:23 |
Unusual memory related error | ReeKo | CFX | 7 | September 30, 2008 19:11 |
FoamX error | lawrencelkl | OpenFOAM Installation | 5 | May 23, 2008 01:29 |
FoamX canbt find applications | ingaerme | OpenFOAM Pre-Processing | 8 | December 12, 2006 14:56 |
Problem related to the Error: General-car-0cdr | wei wang | FLUENT | 0 | May 7, 2005 03:03 |
