-   OpenFOAM Installation (https://www.cfd-online.com/Forums/openfoam-installation/)
-   -   SingleDouble Precision (https://www.cfd-online.com/Forums/openfoam-installation/57406-singledouble-precision.html)
bjoern April 9, 2008 08:03
Hi, I run OpenFoam on Suse
I run OpenFoam on Suse 10 (x86_64).
When I run simpleFoam in single precision option everything works fine.
When want to I run it in double precision option I get the error message:
simpleFoam: symbol lookup error: simpleFoam: undefined symbol: _ZN4Foam13fvsPatchFieldIdE25pathConstructorTablePt r_E
Similar problem:
with DPO FoamX can not connect to the CaseServer.
with SPO it can do so.
What can be the reson for that?
Is there any difference in linking libraries between single and double?
Thanks for any help!
bjoern
fra76 April 9, 2008 12:21
It seems that the application
It seems that the application is linking a wrong version of some shared library.
Try to load the DP environment in a new shell. It usually helps!
