Problem installing OpenFOAM 141
Old   January 19, 2008, 09:03
Default I am new to linux and OF In
Sachin Kanetkar
sachin is on a distinguished road
In fact it is because of OF i am using Linux
I am using SUSE 10.1
I would explain what all i did
-Downloaded OF on my windows machine(unfortunately not allowed to connect my laptop to thru this LAN)
-Transferred it by pen drive to Laptop
-Unpacked using tar command
-Added the last line as said in Readme file
-from terminal . $HOME/ bashcr....i dont remeber but had copied from readme file and pasted it on console
-but it just jumps to next console with doin anything
if I run foaminstallationText it says
source file not complied to home/sachin/OpenFoam
Please help me out as early as possible
sachin is offline   Reply With Quote
Old   February 17, 2008, 16:57
Default Hi, seems you had the same p
jas
Joerg Schenkel
jas is on a distinguished road
seems you had the same problem like I.
But where did you find the .bashrc file, I cant find it.
How do you come this far?
Do you download all thatt gcc and other-compiler-Stuff, do I really need it?
I wasn´t able to put something in the $home directory, only in the $home/(username)/... .
Is it meant that you put somthing in your Username-Home, when it is written put it in your-Home??
jas is offline   Reply With Quote
Old   February 22, 2008, 10:20
Default The .bashrc file should be in
Jeremiah Hall
jjhall is on a distinguished road
The .bashrc file should be in your home directory, if you use the bash shell. Your home directory is defined by the environment variable $HOME, and should be the directory /home/<username>/. If you download everything into the directories described on the download page and in the README, you then have to modify your .bashrc accordingly and source it with:
> source ~/.bashrc
Then you shouldn't need to compile from source.
jjhall is offline   Reply With Quote
Trouble with installing OpenFOAM on Ubuntu Milos OpenFOAM Installation 16 November 16, 2009 02:44
Problem in Paraview While installing OpenFOAM 15 in Suse 103 altranindia OpenFOAM Installation 1 February 20, 2009 09:20
Pls help last problem to be solved for installing OPENfoam daydayuper OpenFOAM Installation 5 November 9, 2008 04:59
Installing OpenFOAM without Paraview quartzian OpenFOAM Installation 0 September 8, 2008 09:29
Installing OpenFOAM honcho OpenFOAM Installation 1 April 9, 2008 06:29
