PowerPCCell Fedora 7 ld relocation error
Old   February 11, 2008, 08:25
Default Hi I'm installing compiling
Marcelo M. Garcia
mgarcia is on a distinguished road
Hi
I'm installing compiling OpenFOAM-1.4.1 in a IBM blade QS21 (2 duo-core Cell BE) with Fedora 7 using the IBM SDK 3.0 (gcc-4.1.1).
The error is about ld relocation from elf64-powerpc to elf32-powerpc[1]. In the file "rules" I put to be 64-bits[2], but seems that the file "ccSPOpt/libfbsdmalloc.o" has to be 32 bits. Is this right? Is there a work around for this?
Note, I tried the Fedora gcc-4.1.2, and I got the same error.
Regards
Marcelo
[1]
+ cd malloc
+ ./Allwmake
+ wmake libo fbsdmalloc
/home/ocf/OpenFOAM/OpenFOAM-1.4.1/wmake/wmakeLnInclude: linking include files to /home/ocf/OpenFOAM/OpenFOAM-1.4.1/src/malloc/fbsdmalloc/lnInclude
Making dependency list for source file fbsdmalloc.c
could not open file libc_private.h for source file fbsdmalloc.c
could not open file spinlock.h for source file fbsdmalloc.c
SOURCE=fbsdmalloc.c ; ppu-gcc -mpowerpc64 -mcpu=970 -m64 -Dlinuxppc64 -DSP -Wall -O3 -fno-gcse -IlnInclude -I. -I/home/ocf/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude -fPIC -c $SOURCE -o Make/linuxppc64GccSPOpt/fbsdmalloc.o
ld -A64 -r -o /home/ocf/OpenFOAM/OpenFOAM-1.4.1/lib/linuxppc64GccSPOpt/libfbsdmalloc.o Make/linuxppc64GccSPOpt/fbsdmalloc.o
ld: Relocatable linking with relocations from format elf64-powerpc (Make/linuxppc64GccSPOpt/fbsdmalloc.o) to format elf32-powerpc (/home/ocf/OpenFOAM/OpenFOAM-1.4.1/lib/linuxppc64GccSPOpt/libfbsdmalloc.o) is not supported
make: *** [/home/ocf/OpenFOAM/OpenFOAM-1.4.1/lib/linuxppc64GccSPOpt/libfbsdmalloc.o] Error 1
+ '[' '!' -r /home/ocf/OpenFOAM/OpenFOAM-1.4.1/src/mico-2.3.12/platforms/linuxppc64GccSPOpt/l ib/libmico2.3.12.a ']'
[2]::::::::::::::
c
.SUFFIXES: .c .h
cWARN = -Wall
cc = ppu-gcc -mpowerpc64 -mcpu=970 -m64
include $(RULES)/c$(WM_COMPILE_OPTION)
cFLAGS = $(GFLAGS) $(cWARN) $(cOPT) $(cDBUG) $(LIB_HEADER_DIRS) -fPIC
ctoo = $(WM_SCHEDULER) $(cc) $(cFLAGS) -c $$SOURCE -o $@
LINK_LIBS = $(cDBUG)
LINKLIBSO = $(cc) -shared
LINKEXE = $(cc) -Xlinker -z -Xlinker nodefs
c++
.SUFFIXES: .C .cxx .cc .cpp
c++WARN = -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast
CC = ppu-g++ -mpowerpc64 -mcpu=970 -m64
include $(RULES)/c++$(WM_COMPILE_OPTION)
ptFLAGS = -DNoRepository -ftemplate-depth-40
c++FLAGS = $(GFLAGS) $(c++WARN) $(c++OPT) $(c++DBUG) $(ptFLAGS) $(LIB_HEADER_DIRS) -fPI
C
Ctoo = $(WM_SCHEDULER) $(CC) $(c++FLAGS) -c $$SOURCE -o $@
cxxtoo = $(Ctoo)
cctoo = $(Ctoo)
cpptoo = $(Ctoo)
LINK_LIBS = $(c++DBUG)
LINKLIBSO = $(CC) $(c++FLAGS) -shared
LINKEXE = $(CC) $(c++FLAGS)
mgarcia is offline   Reply With Quote
Old   February 14, 2008, 04:30
Default Solved. I forgot to change the
Marcelo M. Garcia
Solved. I forgot to change the linker to "ppu-ld"
Fluent gives libc error on 64 bit AMD Fedora 9 Kumar FLUENT 3 October 7, 2008 12:52
`logf' causes overflow in R_X86_64_PC32 relocation norbinou Siemens 3 March 8, 2008 10:26
FoamX starting on Fedora 8 x86_64 and i386 Error nsd ORBIIOPAddr %24myIOP ior %24FOAMX_CONFIGnsref %2360 devnull rationaalinen OpenFOAM Pre-Processing 6 December 2, 2007 11:40
Error Display of FLUENT on LINUX FEDORA 7 Gustavo Gondran Ribeiro FLUENT 7 August 31, 2007 23:06
FoamX Error after upgrade to Fedora Core 6 philippose OpenFOAM Installation 5 October 31, 2006 12:36
