Wmake error OpenSUSE 103 64 bit arch
Old   February 7, 2008, 06:53
Default when I try to run wmake, this
tom
when I try to run wmake, this is what I get:
SOURCE=setGammaSplashWet.C ; g++ -m32 -Dlinux -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/usr/OpenFOAM/OpenFOAM/OpenFOAM-1.4.1/src/finiteVolume/lnInclude -I/usr/OpenFOAM/OpenFOAM/OpenFOAM-1.4.1/src/meshTools/lnInclude -IlnInclude -I. -I/usr/OpenFOAM/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude -fPIC -pthread -c $SOURCE -o Make/linuxGccDPOpt/setGammaSplashWet.o
In file included from /usr/include/features.h:345,
from /usr/include/limits.h:27,
from /usr/lib64/gcc/x86_64-suse-linux/4.2.1/include/limits.h:122,
from /usr/lib64/gcc/x86_64-suse-linux/4.2.1/include/syslimits.h:7,
from /usr/lib64/gcc/x86_64-suse-linux/4.2.1/include/limits.h:11,
from /usr/include/c++/4.2.1/climits:50,
from /usr/OpenFOAM/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/label.H:38,
from /usr/OpenFOAM/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/labelList.H:36,
from /usr/OpenFOAM/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/Pstream.H:45,
from /usr/OpenFOAM/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/OPstream.H:37,
from /usr/OpenFOAM/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/parRun.H:4,
from /usr/OpenFOAM/OpenFOAM/OpenFOAM-1.4.1/src/finiteVolume/lnInclude/fvCFD.H:4,
from setGammaSplashWet.C:36:
/usr/include/gnu/stubs.h:7:27: error: gnu/stubs-32.h: No such file or directory
make: *** [Make/linuxGccDPOpt/setGammaSplashWet.o] Error 1
Where can I find the .rpm that holds stubs-32.h? I have been searching for it for a long time, but with no success. I have OpenFOAM installed and running perfectly on my home 32-bit PC.
My 64bit machine is Hp Compaq 6820s laptop.
Thank You!
Old   February 7, 2008, 10:11
Default Hello, I solved the missing
tom
I solved the missing stubs-32.h (it was in glibc-devel-32bit-2.6.1-18.x86_54.rpm), but now I have another problem:
Calling wmake on my setGammaSplashWet.C results in:
g++ -m32 -Dlinux -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/usr/OpenFOAM/OpenFOAM/OpenFOAM-1.4.1/src/finiteVolume/lnInclude -I/usr/OpenFOAM/OpenFOAM/OpenFOAM-1.4.1/src/meshTools/lnInclude -IlnInclude -I. -I/usr/OpenFOAM/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude -fPIC -pthread Make/linuxGccDPOpt/setGammaSplashWet.o -L/usr/OpenFOAM/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt \
-lfiniteVolume -lmeshTools -lOpenFOAM -ldl -lm -o /usr/OpenFOAM/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/setGammaSpl ashWet
/usr/lib64/gcc/x86_64-suse-linux/4.2.1/../../../../x86_64-suse-linux/bin/ld: cannot find -lfiniteVolume
collect2: ld returned 1 exit status
make: *** [/usr/OpenFOAM/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/setGammaSp lashWet] Error 1
For this one, I don't know where to start. I'm barely a beginning Linux user, as well as OpenFOAM, so any advice is deeply appreciated.
Old   February 7, 2008, 15:03
Default The linker did not find libfin
Assistant Moderator
Bernhard Gschaider
The linker did not find libfiniteVolue.so
Check whether there is such a file in /usr/OpenFOAM/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt and it is readable for your account
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   February 7, 2008, 22:12
Default The error reason must be befor
unoder
The error reason must be before. Search the forum. Some people solve the/a libfinitevolume-problem by downgrading flex to 2.5.4a. I don't know if this is the cause of an error here, but I had that flex-problem myself - and that was also opensuse 10.3, so you might consider to try it out.
Old   February 8, 2008, 05:07
Default Thank You for the advice: I
tom
I've tried to look for the file, but found nothing. I also ran foamInstallationTest and got two new suprises(critical errors with gcc and Java).
I'll search the forum and try to find the answer somewhere.
Old   February 8, 2008, 12:57
Default An old post solved the problem
tom
An old post solved the problem for me:
There was a conflict between the system gcc and the one defined by bashrc in .OpenFOAM-1.4 (and with Java too).... The conflict stated a search via a path using terms for 32-bit architecture(that's how I recognised the problem: I have x86_64 arch), so I had to export WM_64='on' before sourcing OpenFOAM's bashrc.
Thank You for the advice Martin: search the forum first, ask questions later.
Gambit on Opensuse install error Thiago FLUENT 7 December 14, 2013 07:59
Wmake error murasaki OpenFOAM 6 August 9, 2010 14:03
Error with Wmake skabilan OpenFOAM Installation 3 July 28, 2009 00:35
Building error of 15dev for OpenSUSE 111 on AMD64 machine waynezw0618 OpenFOAM Installation 1 February 18, 2009 10:12
Gambit error on opensuse Alessandro FLUENT 0 February 26, 2008 04:08
