December 23, 2007, 17:33 |
I just downloaded Hrv's
Pei-Ying Hsieh
Rep Power: 18 |
I just downloaded Hrv's 1.4.1-dev version and all the support files. Based on the installation instructions, I am suppose to use gmake. But, when I typed gmake, I got "command not found". It looks like gmake is basically make on FreeBSD. Has anyone tried to install the developement version on either Ubuntu or SuSE? Can I install the development just like the standard version using wmake? Do I need all the utility packages (gdb, cmake)? Thanks! Peiying |
December 24, 2007, 03:14 |
Hi Peiying,
gmake I think is
Dragos
Rep Power: 20 |
Hi Peiying,
gmake I think is the gnu version of make, and on many systems is just a symbolik link to make. You don't need gdb as long as you don't do debugging. But you need cmake if you are going to compile paraview. Dragos |
December 24, 2007, 11:36 |
Thanks Dragos!
Now, I am ha
Pei-Ying Hsieh
Rep Power: 18 |
Thanks Dragos!
Now, I am having trouble with gcc. I downloaded gcc-4.2.2.tgz from powerlab. I got the following errors during configure. I am using OpenSUSE 10.3 64 bit (which has gcc-4.2.1 installed). Any suggestion will be highly appreciated. Peiying ----------------------- OpenFOAM/linuxSrc> mkdir gcc-4.2.2-obj OpenFOAM/linuxSrc> cd gcc-4.2.2-obj linuxSrc/gcc-4.2.2-obj> ../gcc-4.2.2/configure --prefix=/usr/tmp/gcc-4.2.2 --exec-prefix=/usr/tmp/gcc-4.2.2 --enable-languages=c,c++ --enable-shared creating cache ./config.cache checking host system type... x86_64-unknown-linux-gnu checking target system type... x86_64-unknown-linux-gnu checking build system type... x86_64-unknown-linux-gnu checking for a BSD compatible install... /usr/bin/install -c checking whether ln works... yes checking whether ln -s works... yes checking for gcc... gcc checking whether the C compiler (gcc -m32 -m32) works... no configure: error: installation or configuration problem: C compiler cannot create executables. linuxSrc/gcc-4.2.2-obj> |
December 25, 2007, 21:12 |
Can someone tell me whi
Pei-Ying Hsieh
Rep Power: 18 |
Can someone tell me which OS is the installation instructions of the development based on? I am not able to find gcc-4.2.2 for either SuSE or Ubuntu. When I tried to install the OF-1.4.1 development version on SuSE 10.3 64 bit OS, I got some errors (used linux64/gcc-4.2.1 and bash). Thanks a lot! peiying |
December 26, 2007, 02:18 |
Dragos
Rep Power: 20 |
... configure: error: installation or configuration problem: C compiler cannot create executables. You are specifying a path where most likely you don't have access as regular user. Try instead of /usr/tmp/gcc-4.2.2 something else, like /tmp/gcc-4.2.2. Dragos |
December 26, 2007, 11:54 |
Dear Dragos:
Thanks a lot f
Pei-Ying Hsieh
Rep Power: 18 |
Dear Dragos:
Thanks a lot for the pointer. Your were correct! Now, I am able to compile gcc-4.2.2 using /tmp/gcc-4.2.2 on a 32 bit system. However, I am still having trouble compiling gcc-4.2.2 on a 64 bit OS. I got errors saying incompatible i386 with x86_64. Is there a switch that I can turn on to 64 bit OS, something like WM_64=on? Thanks again for your reply! Peiying |
December 27, 2007, 03:21 |
Unfortunately, gcc is not alwa
Dragos
Rep Power: 20 |
Unfortunately, gcc is not always straight froward to compile. You should have a look at install gcc, especially at prerequisites paragraph.
Dragos |
December 27, 2007, 20:37 |
Dear Dragos:
Thanks for the
Pei-Ying Hsieh
Rep Power: 18 |
Dear Dragos:
Thanks for the suggestions. I did look at the gcc installation instructions and the manual. But, I still cannot figure out how to do this. I sent an email to gcc-help. I might try gcc-4.2.1 later to see if I can make some progress. Peiying |
December 29, 2007, 17:00 |
Pei, deailed step-by-step inst
#9 |
Srinath Madhavan (a.k.a pUl|)
Rep Power: 21 |
Pei, deailed step-by-step instructions to compile gcc and/or even binutils for an OpenFOAM setup are given in the wiki. I have followed these instructions for OF versions 1.3, 1.4 and 1.4.1 and have never faced any problems. Go here --> http://openfoamwiki.net/index.php/Howto_compile_OpenFOAM#Compiling_and_installin g_GNU_Gcc
December 31, 2007, 08:18 |
Hi, Srinath,
Thanks for the
#10 |
Pei-Ying Hsieh
Rep Power: 18 |
Hi, Srinath,
Thanks for the reply! By following the steps in the wiki, I am able to compile 1.4.1-dev on 64 bit SuSE 10.2, except dx and paraview. I will try Ubuntu 64 bit later. Peiying |
How to install CFX in Ubuntu-Linux OS ???? | Student | CFX | 5 | January 17, 2011 08:20 |
Which version is current development line for 15 | dkingsley | OpenFOAM Installation | 20 | January 22, 2009 02:49 |
Can someone PLEASE document the development version installation | bernd | OpenFOAM Installation | 76 | November 14, 2008 21:51 |
Development version download | guillaume | OpenFOAM Installation | 30 | October 15, 2008 00:59 |
Modifying motionU in the development version | philippose | OpenFOAM Running, Solving & CFD | 8 | February 1, 2007 15:25 |
