Problems using local openmpi
Old   December 5, 2007, 13:36
Default hi, i try using a local ope
Stephan Gerber
stephan is on a distinguished road
hi,
i try using a local openmpi-version to use infiniband on a linux-cluster.
i did everything as explained in the forum ->i have recompiled Pstream but after starting any app like blockMesh etc. i get something like:
symbol lookup error: /Users/gerber/mac/OpenFOAM/OpenFOAM-1.3/lib/linuxAMD64Gcc4DPOpt/openmpi-1.2.2-1/ libPstream.so: undefined symbol: ompi_mpi_comm_null
so something went wrong but i have no clue what exactly. the recompiling show only warnings no errors.
Any help would be appreciated!
thanks
stephan
stephan is offline   Reply With Quote
Old   December 5, 2007, 18:01
Default hi, the problem is solved w
Stephan Gerber
hi,
the problem is solved with some inspiration of the forum (thanks bernhard!) - foam could bind libPstream but had not full access to all headers..
br
stephan
Problem with openmpi mighelone OpenFOAM Running, Solving & CFD 42 July 18, 2012 14:26
Problems with Fedora 9 and OpenMPI harly OpenFOAM Running, Solving & CFD 11 May 3, 2009 04:18
OpenMPI performance vega OpenFOAM Running, Solving & CFD 13 November 27, 2007 01:28
Cant run in parallel on two nodes using OpenMPI CHristofer Main CFD Forum 0 October 26, 2007 09:54
OpenFOAM 14 with OpenMPI 12 fhy OpenFOAM Installation 0 July 12, 2007 18:12
