October 18, 2007, 17:14 |
Hello
I am trying to instal
mou
Rep Power: 17 |
Hello
I am trying to instal OF 1.4 on Silaris(Sparc). I used gcc-4.2.0(Thanks to Josef Buergler) on OpenFOAM/solaris/gcc-4.2.0/ to compile OF. I faced this error Making dependency list for source file triSurface/surfacePatch/surfacePatchIOList.C Making dependency list for source file tools/labelledTri/sortLabelledTri.C Making dependency list for source file triSurfaceFields/triSurfaceFields.C SOURCE=faceTriangulation/faceTriangulation.C ; g++ -Dsolaris -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -O3 -fno-schedule-insns -DNoRepository -ftemplate-depth-30 -IlnInclude -I. -I/home/hpc1929/OpenFOAM/OpenFOAM-1.4/src/OpenFOAM/lnInclude -fPIC -c $SOURCE -o Make/solarisGcc4DPOpt/faceTriangulation.o bash: g++: command not found *** Error code 127 make: Fatal error: Command failed for target `Make/solarisGcc4DPOpt/faceTriangulation.o' + wmake libso edgeMesh `lnInclude/uptodate' is up to date. Making dependency list for source file edgeMesh.C Making dependency list for source file edgeMeshIO.C Making dependency list for source file featureEdgeMesh.C I become so thankful to fix this problem? Thank you MOu |
[OpenFOAM] ParaView command not found | joey | ParaView | 12 | January 18, 2021 05:38 |
[OpenFOAM] Paraview command not found | hardy | ParaView | 7 | September 18, 2008 04:59 |
Problem of compilation OF 14Allwmake command not found | erik_d | OpenFOAM Bugs | 13 | September 13, 2008 21:45 |
IcoFoam Not Installed and blockMesh command not found | cesarbz | OpenFOAM Installation | 6 | July 4, 2008 04:44 |
Line 140 make command not found What is the solution | faroque | OpenFOAM | 1 | November 13, 2006 04:16 |
