Library problem on a 64bit machine wrong ELF class ELFCLASS32 |
June 11, 2007, 07:29 |
I compiled and insta
Jan Goebel
Rep Power: 17 |
I compiled and installed OpenFoam 1.4 on a Fedora Core 6 X86_64 bit machine. running foamInstallationTest everything seems to work fine, but when I want to start FoamX I still have problems... Output: Checking basic setup... ------------------------------------------------------------------------------- Shell: bash Host: Goebel OS: Linux version 2.6.20-1.2952.fc6 User: GoebelJ User_config: /home/GoebelJ/.bashrc Foam_config: /home/GoebelJ/.OpenFOAM-1.4/bashrc sourced correctly. ------------------------------------------------------------------------------- Checking main FOAM env variables... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Crit ------------------------------------------------------------------------------- $WM_PROJECT_INST_DIR /home/GoebelJ/OpenFOAM yes yes $WM_PROJECT_USER_DIR /home/GoebelJ/OpenFOAM/GoebelJ-1.4 yes no $FOAM_JOB_DIR /home/GoebelJ/OpenFOAM/jobControl no yes ------------------------------------------------------------------------------- Checking the FOAM env variables set on the PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $WM_PROJECT_DIR /home/GoebelJ/OpenFOAM/OpenFOAM-1.4 yes yes yes $FOAM_USER_APPBIN ....4/applications/bin/linux64Gcc4DPOpt yes yes no $FOAM_APPBIN ....4/applications/bin/linux64Gcc4DPOpt yes yes yes $WM_DIR .../GoebelJ/OpenFOAM/OpenFOAM-1.4/wmake yes yes yes $FOAMX_PATH ...ations/utilities/preProcessing/FoamX yes no yes $CEI_HOME /usr/local/ensight/CEI no no $JAVA_PATH ...ebelJ/OpenFOAM/linux64/j2sdk1.4.2_05 yes yes no $MICO_ARCH_PATH ...co-2.3.12/platforms/linux64Gcc4DPOpt yes yes yes $LAM_ARCH_PATH ...lam-7.1.2/platforms/linux64Gcc4DPOpt yes yes yes $MPICH_ARCH_PATH --------- env variable not set --------- no ------------------------------------------------------------------------------- Checking the FOAM env variables set on the LD_LIBRARY_PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $FOAM_LIBBIN ...AM/OpenFOAM-1.4/lib/linux64Gcc4DPOpt yes yes yes $FOAM_USER_LIBBIN ...OAM/GoebelJ-1.4/lib/linux64Gcc4DPOpt yes yes no $LAM_ARCH_PATH ...lam-7.1.2/platforms/linux64Gcc4DPOpt yes yes yes ------------------------------------------------------------------------------- Software versions ------------------------------------------------------------------------------- Software Version Location ------------------------------------------------------------------------------- gcc /home/GoebelJ/OpenFOAM/linux64/gcc-4.1.1/bin/gcc java 1.4.2_05 /home/GoebelJ/OpenFOAM/linux64/j2sdk1.4.2_05/bin/java gzip 1.3.5 /home/GoebelJ/OpenFOAM/linux64/gcc-4.1.1/bin/gzip tar 1.3.5 /bin/tar icoFoam ...OpenFOAM-1.4/applications/bin/linux64Gcc4DPOpt/icoFoam ------------------------------------------------------------------------------- Checking file/directory permissions... ------------------------------------------------------------------------------- File/directory Set Reqd Crit ------------------------------------------------------------------------------- Checking networking... ------------------------------------------------------------------------------- Action Result Crit ------------------------------------------------------------------------------- Pinging_Goebel Successful yes Pinging_localHost Successful yes Test_rsh: Unsuccessful_connection_refused* yes Test_ssh: Successful yes (*) Only one of rsh or ssh is required by the Foam enviroment. ------------------------------------------------------------------------------- Base configuration ok. Critical systems ok. [GoebelJ@Goebel bin]$ FoamX Starting NameServer with inet:Goebel:1234 ... nsd: error while loading shared libraries: libssl.so.0.9.7: wrong ELF class: ELFCLASS32 thank you for your help, Jan |
Wrong elfclass32 | F.P. | FLUENT | 0 | January 8, 2009 06:33 |
FoamX libXpso6 wrong ELF class error | abanerj3 | OpenFOAM Pre-Processing | 2 | May 18, 2008 15:32 |
64bit machine for CFX | Ahlo | CFX | 1 | February 7, 2008 16:30 |
Problems installing OpenFoam on a 64bit machine | jango | OpenFOAM Installation | 1 | June 4, 2007 14:53 |
runing Fluent with a 64bit machine | Rucy | FLUENT | 1 | November 17, 2005 08:51 |
