Flex vs foamFlex
Old   October 10, 2006, 11:24
Default Is there any reason for using
lel
Alexander Lelyakin
lel is on a distinguished road
Is there any reason for using flex version 2.4.5
and not some modern version of flex installed in the system anyway?
I tried to use system flex (2.5.31). It compiles without problem.
To do that it is necessary eliminate shipped
FlexLexer.h from lnInclude which is not obvious thing.
lel is offline   Reply With Quote
Old   October 11, 2006, 06:14
Default Sorry, I was not right. fle
lel
Alexander Lelyakin
flex++ installed in in my system (ubuntu-6.06)
cannot compile all .L files in OpemFOAM.
More precise - output from flex++ cannot be compiled by g++
There are two types of error messages:
- duplicate class definition
- absence of 'main' on link stage
However it is still interresting what is so special in OpenFOAM that it cannot use standard flex++ and should use patched version of it?
Old   October 11, 2006, 06:23
Default Easy: standard flex does not c
Hrvoje Jasak
Easy: standard flex does not conform with the C++ standard and the new compilers refuse to work with it. Also, I got annoyed with the warnings about using non-standard headers etc and this got fixed as well.
Note that flex needs to produce a proper code for later compilation, so adherence to standard is really important. At the same time (the last time I've looked), nobody is giving flex the attention it needs.
(if you want something done properly, you end up doing it yourself) :-)
Hrv
Hrvoje Jasak
Flex and readSTLASCIIL podallaire OpenFOAM Installation 2 June 1, 2010 17:00
What is the difference between flex and foamFlex allenzhao OpenFOAM Installation 1 August 14, 2008 17:17
Problem wih Compiling under Tru64 foamFlex matthias OpenFOAM Installation 2 December 1, 2005 05:36
Flex License Borrowing Henry Oxted Main CFD Forum 5 March 23, 2005 16:59
vig-o-flex lipovetzky leonid Main CFD Forum 0 October 6, 1998 10:48
