May 17, 2006, 08:53 |
Hi. I'm upgrading OpenFOAM on
Gavin Tabor
Rep Power: 17 |
Hi. I'm upgrading OpenFOAM on my own machine. Followed the usual routine of downloading and installing, then tried to run blockMesh on the cavity case from the tutorials. Error as follows:
lutoslawski<39> blockMesh . cavity blockMesh: /lib/tls/libc.so.6: version `GLIBC_2.3.4' not found (required by blockMesh) I've checked through my .cshrc file several times, and can't understand what is going wrong here (particularly as I've already successfully upgraded my PhD student's machines). I'm probably doing something very stupid, but I can't see what. Any suggestions? Gavin |
May 17, 2006, 08:59 |
What OS + version are you runn
Rolf Hansen
Rep Power: 17 |
What OS + version are you running ?
Rolf |
May 17, 2006, 09:11 |
... and what OS + version is y
Rolf Hansen
Rep Power: 17 |
... and what OS + version is your student running ?
May 17, 2006, 09:19 |
I'm on RedHat 9 (.0, I think)
Gavin Tabor
Rep Power: 17 |
I'm on RedHat 9 (.0, I think) - he may be on RedHat 8, being a slightly older machine.
Gavin |
May 17, 2006, 09:53 |
The problem is that a fully up
Rolf Hansen
Rep Power: 17 |
The problem is that a fully updated RedHat 9 only reaches glibc version 2.3.2-something and that the OpenFOAM-1.3 binaries have been created on a machine with newer glibc version. I had the same problem on our cluster. I read that updating glibc is VERY MESSY and could destroy your OS so that even simple commands like ls and cp does not work anymore. I therefore searched the forum and found a post by Bernhard Gsnaider that helped me:
"... What I did was: remove the executable-binaries (not the .o-s and not the .so-s) and perform a wmake in the applications directory. That should only relink the applications (and then everything should be fine)" This worked for me even though I had to do some manual recompiling with for example foamFlex++, but it can be done. Alternatively update to RedHat fedora core 3. I am running FC3 on my personal PC, and I have no problems running OpenFOAM-1.3. I would certaintly recommend you to update your OS since this is the quickest thing to do. Also RedHat 9 is obsolete with no active updates etc. Regards Rolf |
May 17, 2006, 11:16 |
You can also recompile the who
Martin Beaudoin
Rep Power: 22 |
You can also recompile the whole thing from source, instead of using the pre-compiled binary version, or upgrading your OS.
Check out this document on the OpenFOAM Wiki: http://openfoamwiki.net/index.php/Howto_compile_O penFOAM Martin |
May 18, 2006, 04:13 |
Thanks for the advice!
I
David Segersson
Rep Power: 17 |
Thanks for the advice! I had the same problem and your suggested solution seems to work just fine. Just did rm * under OpenFoam1.3/applications/bin and then executed the Allwmake script in the applications directory. After this the applications seem to work (now I just have to find out why FoamX is complaining over a missing nameservice (ns.ref file missing...). Regards David |
May 18, 2006, 07:35 |
Hi again,
After a second chec
David Segersson
Rep Power: 17 |
Hi again,
After a second check it does not seem to be totally correct after all. The foamFlex seems to need recompiling in my case as well. Doing a wclean and then wmake in itīs directory does not however produce a binary (even though it doesnīt return any error messages...). Rolf, I would appreciate if you could more exactly tell me what you did when it comes to manual recompilation of foamFlex (and maybe other parts...)? Regards David |
May 18, 2006, 09:24 |
Maybe something related to you
#9 |
Martin Beaudoin
Rep Power: 22 |
Maybe something related to your local version of bison, which is needed to generate a valid version of the files parse.c and skel.c. for your local system.
Try this: cd $WM_PROJECT_DIR/applications/utilities/miscellaneous/foamFlex make clean wclean make wmake Martin |
May 18, 2006, 10:06 |
It seems like the only problem
#10 |
David Segersson
Rep Power: 17 |
It seems like the only problem was that the foamFlex++ binary was not written to applications/bin but to a file OpenFoam.out in the foamFlex directory. All I had to do was to change the name to foamFlex++ and move it to applications/bin, then everything worked (at least I can compile fluentMeshToFoam which did not work before).
Thanks anyway for the advice David |
May 18, 2006, 10:21 |
Found the problem:
a typo
#11 |
Martin Beaudoin
Rep Power: 22 |
Found the problem:
a typo in the file $WM_PROJECT_DIR/applications/utilities/miscellaneous/foamFlex/Make/files: The last line of the file should be EXE = $(FOAM_APPBIN)/foamFlex++ Martin |
May 18, 2006, 10:31 |
Same typo in:
$WM_PROJECT_D
#12 |
Martin Beaudoin
Rep Power: 22 |
Same typo in:
$WM_PROJECT_DIR/applications/test/Field/Make/files $WM_PROJECT_DIR/applications/test/alloc/Make/files $WM_PROJECT_DIR/applications/test/maxMem/Make/files $WM_PROJECT_DIR/applications/utilities/miscellaneous/foamFlex/Make/files Martin |
May 18, 2006, 11:00 |
These are not OpenFOAM apps, t
#13 |
Mattijs Janssens
Rep Power: 26 |
These are not OpenFOAM apps, these are standalone apps so do not need to link in libOpenFOAM etc.
See $WM_DIR/Makefile for how it hangs together. |
August 24, 2006, 12:02 |
Hi all,
I am installing Ope
#14 |
Santiago Laín
Hi all,
I am installing OpenFOAM v 1.3 on a RedHat 8 with binaries. Although the installation seemed to be fine when I try the first example in the tutorial blockMesh . cavity I got the message that can not handle libstdc++.so.6 with TLS data. Has anybody any idea what does it mean? and how to solve the problem? Thanks a lot!!! P.S. the same message appears when I try to run another application as dnsFoam for instance. |
August 24, 2006, 12:43 |
Search for 'TLS' on this forum
#15 |
Mattijs Janssens
Rep Power: 26 |
Search for 'TLS' on this forum.
AMD 64 bit installation | maka | OpenFOAM Installation | 7 | January 11, 2009 10:42 |
Regarding installation | vidyaprakash | Siemens | 0 | December 21, 2006 23:03 |
installation | mohammad | FLUENT | 0 | May 4, 2003 10:15 |
NT 4.0 installation | peter.liang | Siemens | 2 | July 4, 2001 12:52 |
HP-UX installation | new here | FLUENT | 1 | October 26, 2000 21:54 |
