Sshd amp libelfso0 on gentoo box
Old   June 15, 2006, 08:38
Default Hi, I'm in the process of i
Alan Freed
alfreed is on a distinguished road
I'm in the process of installing OpenFoam 1.3 on my Gentoo box.
I installed the following files:
* *OpenFoam-1.3.General.gtgz
* *OpenFoam-1.3.linuxGcc4DPOpt.gtgz
and under the subdirectory 'linux', the unzipped the three third-party packages.
I then updated my .bashrc file, as specified in the README, and
compiled the OpenFOAM source code via Allwmake.
No errors up to this point.
When I run foamInstallationTest I get one fatal error that I do not
understand:
Checking networking...
Action * * * * * * * * * Result * * * * * * * * * * * * * * * * * * * Crit
Pinging_celeborn * * * * Successful * * * * * * * * * * * * * * * * * yes
Pinging_localHost * * * *Successful * * * * * * * * * * * * * * * * * yes
Test_rsh: * * * * * * * *No_telnet_running:_cannot_check* * * * * * * yes
Test_ssh: * * * * * * * *No_telnet_running:_cannot_check* * * * * * * yes
FATAL ERROR: No remote shell available.
* * * * * * *Foam1.3 enviroment requires either ssh and/or rsh.
* * * * * * *Contact your system administrator.
I don't understand this because my sshd is running! *My Gentoo box
is a stand-alone machine - I have no ssh server to connect to.
Ignoring this for the moment, I thought about running the tutorials
and ran into another error:
al@celeborn ~/OpenFOAM/OpenFOAM-1.3/bin $ FoamX
Starting NameServer with inet:celeborn:1234 ...
nsd: error while loading shared libraries: libelf.so.0: cannot open shared
object file: No such file or directory
My linux kernel is built to handle elf, but when I run whereis libelf.so.0
this file is not found on my system. *
Any pointers are most welcomed.
Thanks,
Al
alfreed is offline   Reply With Quote
Old   June 15, 2006, 09:40
Default to get the foamInstallationTes
Alexander Jarosch
alexice is on a distinguished road
to get the foamInstallationTest to be okay you have to emerge a telnet client, do:
emerge -av netkit-telnetd
and to get rid of the libelf.so.O stuff you should do
emerge -av libelf
to get a libelf on your gentoo.
Hope that helps, worked for my gentoo box,
Alex
alexice is offline   Reply With Quote
Old   June 15, 2006, 10:05
Default Alex, Thanks, that fixed bo
Alan Freed
Alex,
Thanks, that fixed both issues.
Al
Gentoo ebuild for OpenFOAM141 deepblue17 OpenFOAM Installation 3 July 29, 2010 09:27
FoamX libelfso0 nunoinlux OpenFOAM Bugs 6 September 11, 2007 20:13
Canbt fix libelfso0 proble clo OpenFOAM Installation 3 January 10, 2007 04:17
FoamX libelfso0 mockealm OpenFOAM Installation 6 June 29, 2006 15:37
Building on Sparc64 running gentoo parra OpenFOAM Installation 0 May 5, 2006 15:17
