Compiling OpenFOAM 12 in Single Precision
Old   April 21, 2006, 05:24
Default Hi! I have to use the splitMe
Francesco Del Citto
fra76 is on a distinguished road
Hi!
I have to use the splitMesh utility, which doesn't work at all on OpenFOAM 1.3.
Because of the size of the mesh I have to split (is a .msh file with lots of internal faces that are walls), I'd be glad to compile OpenFOAM 1.2 in single precision (SP) mode, as I've seen it is allowed in version 1.3.
Is there a way to do this?
fra76 is offline   Reply With Quote
Old   April 21, 2006, 09:07
Default Hello Francesco, 1: you can
Martin Beaudoin
mbeaudoin will become famous soon enough
Hello Francesco,
1: you can dowload a pre-compiled single-precision version of OpenFOAM from the OpenCFD Web site.
2: If you really need to recompile OpenFOAM, you first need to change the environment variable WM_PRECISION_OPTION from the default value DP to SP.
Just look-up the definition of the variable WM_PRECISION_OPTION in the file
$HOME/OpenFOAM/OpenFOAM-1.3/.OpenFOAM-1.3/bashrc (or the cshrc file in the same directory)
Once the modification is done, don't forget to source your environment by doing the following command:
# for bash
. $HOME/OpenFOAM/OpenFOAM-1.3/.OpenFOAM-1.3/bashrc
or
#for csh
source $HOME/OpenFOAM/OpenFOAM-1.3/.OpenFOAM-1.3/cshrc
(By the way, you need to do this modification as well if you want to use the pre-compiled single-precision version of OpenFOAM...)
Then, simply recompile OpenFOAM.
I plan to do the same recompilation in a very short while, so if in the process of recompiling I discover some "gotchas", I'll post them here. For example, there might be problems with paraFoam/paraView compiled in double precision and the dynamic library libPVFoamReader.so compiled in single precision.
I plan to add a little section to the Wiki Howto describing the recompilation process in single precision for OpenFOAM 1.3.
http://openfoamwiki.net/index.php/Howto_compile_O penFOAM
Good luck!
Martin
mbeaudoin is offline   Reply With Quote
Old   April 21, 2006, 09:29
Default Thanks Martin, but I need to b
Francesco Del Citto
Thanks Martin, but I need to build OpenFOAM 1.2 in SP mode.
I have already compiled OF 1.3 in SP and Debug mode, on Fedora Core 5 x86_64, but I don't know if I can do the same with OF 1.2
Francesco
Old   April 21, 2006, 10:24
Default Francesco: AFAIK 1.2 doesn't
Assistant Moderator
Bernhard Gschaider
Francesco:
AFAIK 1.2 doesn't support SP outOfTheBox. You might try to go to scalar.H and change
typedef double scalar;
to
typedef float scalar;
and recompile EVERYTHING. But I've never tried that and therefor can'T tell you if it will work
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   April 21, 2006, 11:58
Default Bummer.. I should have read yo
Martin Beaudoin
Bummer.. I should have read your message less quickly...
Sorry for introducing noise in the mailing list, I will try to behave for now on...
Bernhard suggestion is probably the best solution, but I have never tried it myself as well.
Good luck!
Martin
Old   April 21, 2006, 12:05
Default Perhaps my problems with split
Francesco Del Citto
Perhaps my problems with splitMesh are resolved, so I'd not need to build OF 1.2 in single precision...
I hope so!
Francesco
Single v.s. double precision Confused CFX 15 November 10, 2016 04:42
Is there an option for single precisiondouble precision in OpenFOAM hsieh OpenFOAM Running, Solving & CFD 5 April 13, 2015 14:37
Compiling 15dev and 15x in single precision bastil OpenFOAM Installation 0 February 5, 2009 04:34
Compiling 15dev and 15x in single precision bastil OpenFOAM Installation 0 February 5, 2009 04:03
OpenFOAM Double precision vs Single Precision alexandrepereira OpenFOAM Running, Solving & CFD 1 June 11, 2008 14:30
