Paraview installation problem please help
Old   February 25, 2006, 21:09
Default Hi All, I recently dowloaded
Ben
bender is on a distinguished road
Hi All,
I recently dowloaded and installed OpenFoam 1.2 along with Gcc, paraview 2.2.0 and java. I unpacked the files just as the readme file suggested and everything seemed to work and the foamInstallationTest confirmed this. I am now going through the cavity tutorial and I have found that paraview will not work. I get the following:
paraFoam $FOAM_RUN/tutorials/icoFoam cavity
/home/user/OpenFOAM/OpenFOAM-1.2/bin/paraFoam: line 57: 8289 Illegal instruction paraview paraFoam.pvs
or if I just try and load paraview by itself I get the same illegal instruction:
paraview
Illegal instruction
My system is an AMD32 bit and I am using Ubuntu linux, could this be causing any issues? I'm not sure. I'm a bit of a linux novice so any advice on what to look for would be appreciated.
-Cheers
bender is offline   Reply With Quote
Old   February 25, 2006, 21:19
Default I should also add that paravie
Ben
I should also add that paraview does begin to start up and a intro screen pops up for a couple of seconds but then it closes and I get the 'Illegal Instruction' output.
has anyone else experienced this?
Old   February 27, 2006, 05:00
Default try to 'unsetenv' the environm
Mattijs Janssens
mattijs is on a distinguished road
try to 'unsetenv' the environment variable
PV_INTERFACE_PATH
This will prevent paraview from loading the Foam reader module.
Now you can use 'foamToVTK' to generate vtk files.
2) as for why the Foam reader does not work I have no idea.
mattijs is offline   Reply With Quote
[OpenFOAM] Paraview installation problem mcjicpm2 ParaView 0 March 9, 2009 07:15
Paraview installation problem please help mcjicpm2 OpenFOAM Installation 0 March 9, 2009 06:55
Installation of OpenFoam 15 Compilation paraview soeren_brot OpenFOAM Installation 45 January 12, 2009 06:39
Installation problems about Paraview and PV3foamreader clark_liang OpenFOAM Installation 1 January 12, 2009 06:05
Paraview installation troubles jjhall OpenFOAM Installation 3 April 17, 2008 12:59
