Installation Error
Old   February 2, 2006, 11:59
Default hi all, i have some problems
rafal zietara
rafal is on a distinguished road
hi all,
i have some problems with instalation of OpenFOAM on unicomputer (Red Hat 8.0, pentium 4, user rights). If anyone have any idea how to bypass this problem, please help.
Here is the output from Installation Test
celw8:~ > foamInstallationTest
Executing /home/expert/OpenFOAM/OpenFOAM-1.2/bin/foamInstallationTest:
Checking basic setup...
Shell: bash
Host: celw8.ce.umist.ac.uk
OS: Linux version 2.4.18-14
User: expert
User_config: /home/expert/.bashrc
Foam_config: /home/expert/.OpenFOAM-1.2/bashrc sourced correctly.
Checking main FOAM env variables...
Environment_variable Set_to_file_or_directory Valid Crit
$WM_PROJECT_INST_DIR /home/expert/OpenFOAM yes yes
$WM_PROJECT_USER_DIR /home/expert/OpenFOAM/expert-1.2 yes no
$FOAM_JOB_DIR /home/expert/OpenFOAM/jobControl no yes
Checking the FOAM env variables set on the PATH...
Environment_variable Set_to_file_or_directory Valid Path Crit
$WM_PROJECT_DIR /home/expert/OpenFOAM/OpenFOAM-1.2 yes yes yes
$FOAM_USER_APPBIN ...rt-1.2/applications/bin/linuxGcc4Opt yes yes no
$FOAM_APPBIN ...AM-1.2/applications/bin/linuxGcc4Opt yes yes yes
$WM_DIR /home/expert/OpenFOAM/OpenFOAM-1.2/wmake yes yes yes
$FOAMX_PATH ...ations/utilities/preProcessing/FoamX yes no yes
$CEI_HOME /usr/local/ensight/CEI no no
$JAVA_PATH .../expert/OpenFOAM/linux/j2sdk1.4.2_05 yes yes no
$MICO_ARCH_PATH ...c/mico-2.3.11/platforms/linuxGcc4Opt yes yes yes
$LAM_ARCH_PATH ...src/lam-7.1.1/platforms/linuxGcc4Opt yes yes yes
$MPICH_ARCH_PATH --------- env variable not set --------- no
Checking the FOAM env variables set on the LD_LIBRARY_PATH...
$FOAM_LIBBIN ...enFOAM/OpenFOAM-1.2/lib/linuxGcc4Opt yes yes yes
$FOAM_USER_LIBBIN ...OpenFOAM/expert-1.2/lib/linuxGcc4Opt yes yes no
Software versions
Software Version Location
gcc 4.0.1 /home/expert/OpenFOAM/linux/gcc-4.0.1/bin/gcc
java 1.4.2_05 /home/expert/OpenFOAM/linux/j2sdk1.4.2_05/bin/java
gzip 1.3.3 /usr/bin/gzip
tar 1.3.3 /bin/tar
icoFoam ...OAM/OpenFOAM-1.2/applications/bin/linuxGcc4Opt/icoFoam
Checking file/directory permissions...
File/directory Set Reqd Crit
Checking networking...
Action Result Crit
..._celw8.ce.umist.ac.uk Successful yes
Pinging_localHost Networking_cannot_reach_localHost yes
WARNING: CRITICAL ERROR
Test_rsh: Unsuccessful_connection_refused* yes
Test_ssh: Successful yes
(*) Only one of rsh or ssh is required by the Foam enviroment.
Base configuration ok.
The foam installation contains 1 critical error(s).
Review the output for warning messages and consult
the installation guide for trouble shooting.
celw8:~ >
rafal is offline   Reply With Quote
Old   February 2, 2006, 12:24
Default does your tcp/ip stack working
stefan
stefanke is on a distinguished road
does your tcp/ip stack working? Are you able to ping your localhost (172.0.0.1). You get this error because the installation script is not able to ping you localhost. Are you in the right runlevel (3 or 5)?
Take care that you network setup is working and go ahead.
stefanke is offline   Reply With Quote
Old   February 2, 2006, 12:38
Default Thats true I cannot ping mysel
rafal zietara
Thats true I cannot ping myself (i dont know why but i will sort this out with admin)
thanks
Old   February 2, 2006, 12:43
Default There are only two possibiliti
stefan
There are only two possibilities:
- your tcp/ip stack is buggy
- your tcp/ip stack is not loaded
> check the loaded kernel modules
> what is the output of ifconfig
I am sure your Admin will fix this problem
cheers
Stefan
OF15dev installation error velan OpenFOAM Installation 11 February 13, 2009 10:23
Help Error Installation of openfoam15dev loneboard OpenFOAM Installation 4 February 4, 2009 10:24
Installation error sukratu OpenFOAM Installation 6 September 16, 2007 23:46
Error after installation.. Nari Siemens 5 June 28, 2007 15:02
Fluent 6.2.16 installation with Error EOF tuks FLUENT 3 July 13, 2005 14:20
