December 22, 2004, 08:24 |
First of all, I thanks the pe
First of all, I thanks the people that create OpenFOAM to make it free software. I have been looking for a good piece of open software like this for some time. I intend to use OpenFOAM in CFD teaching, thesis development and research projects.
I have just begin to explore the OpenFOAM capabilities and I intent to run it in a Rocks cluster (Makalu, 3.3), which already has MPICH 1.2.6 compiled with gcc 3.2.3 and the Sun Grid Engine sheduler (SGE 5.3). I have already installed OpenFOAM in a personal account and run a tutorial iteratively in the frontend. Does anyone has any experience in running OpenFOAM in a Rocks cluster? I would like to receive any hints on how to run it in parallel using the existing gcc-MPICH environment and then in batch mode using SGE. Thanks in advance. |
December 22, 2004, 08:28 |
Do you have to use MPICH? We
Do you have to use MPICH? We prefer LAM particularly on Linux where MPICH behaved very badly on large cases. Also gcc-3.4 is much better than gcc-3.2, do you have to use 3.2?
December 22, 2004, 09:27 |
Dear Henry,
I do not have
Dear Henry,
I do not have to use it but it seems to be a better solution in the long run because MPICH compiled with gcc is standard in the Rocks distribution. New Rocks releases will probably update gcc but they will probably continue to use MPICH and not LAM. Are you familiar with the Rocks distribution? |
December 22, 2004, 10:38 |
No I am not familiar with Roc
No I am not familiar with Rocks. We use SuSE 9.1,2 and always use the latest gcc and lam versions. I don't like to be constrained by the compiler version supplied with the operating system, it is rarely optimal for CFD. The last time I tried MPICH I was unable to run my large cases because of the bugs in the linux version so I moved over to lam which ran fine and gave better performance so I have stuck with it.
However OpenFOAM can now be compiled with any version of MPI (or PVM for that matter), it's just a matter of compiling the appropriate Pstream library with the comms library you want to use. |
December 22, 2004, 11:01 |
First, I am not an expert in
First, I am not an expert in parallel environments. I am basically an user that has to maintain his own clusters running without an IT professional - a third world problem - who considers Rocks a manageable solution.
ROCKS is a cluster distribution made to deploy and manage easily large clusters, having some in the top 500 built with it. I agree that not having the latest compiler may impose some limitations but ROCKS was made to run large problems. Thus, I plan to give its MPICH environment a try. I have not read the OpenFOAM programmer manual yet for the details of OpenFOAM compilation. I will study it and then I will probably post some questions about its recompilation. I think you could help me a lot at that time. Thanks. |
November 15, 2005, 15:14 |
PVM compiled OpenFOAM:
Howe
#6 | |
Maka Mohu
Rep Power: 18 |
http://howto.x-tend.be/openMosix-Summer2004/x146.html Thanks, Maka |
November 15, 2005, 16:31 |
Have a look at:
/home/hjasa
Hrvoje Jasak
Rep Power: 33 |
Have a look at:
/home/hjasak/OpenFOAM/OpenFOAM-1.2/src/Pstream Here, there is the protocol-dependent part of the Pstream class, currently implementing the dummy, mpi and the long-untouched pvm library. First, you will need to set tPVM as the communications library in: OpenFOAM-1.2/.cshrc Look for the block called # Communications library # ~~~~~~~~~~~~~~~~~~~~~~ if ($WM_MPLIB == MPICH) then and add an "else if" block for PVM Then, revive the code in the Pstream section above and the rest should just work. I'd appreciate the working setup for the .cshrc file and updates for the pvm Pstream once you get it working - thanks. Enjoy, Hrv
Script to Run Parallel Jobs in Rocks Cluster | asaha | OpenFOAM Running, Solving & CFD | 12 | July 4, 2012 22:51 |
Micro HOWTO Rocks clusters 50 OpenFoam 15 Linux64 | james | OpenFOAM Installation | 1 | August 30, 2008 10:15 |
MPI on Clusters | wak | Siemens | 0 | September 19, 2004 22:03 |
CFD for flow in fractured rocks | S. Yokuda | Main CFD Forum | 2 | February 5, 2001 09:48 |
