How to set environment variables
Old   September 3, 2005, 04:20
Default I am using Fedora core 3 on my
kanishka
I am using Fedora core 3 on my P4.
I am installing openfoam-1.1 and followed everything that is given in documnetation and the read me file.
But finally while running foamInstallationTest, i get the following result.
[kanishka@localhost bin]$ ./foamInstallationTest
Executing ./foamInstallationTest:
Checking basic setup...
Shell: bash
Host: localhost.localdomain
OS: Linux version 2.6.9-1.667
User: kanishka
User_config: /home/kanishka/.bashrc
Foam_config: /home/kanishka/.OpenFOAM-1.1/bashrc sourced correctly.
FATAL ERROR Foam install directory not set.
Set correct path to installation 'WM_PROJECT_INST_DIR' in /home/kanishka/.foam2.3/bashrc
Checking main FOAM env variables...
Environment_variable Set_to_file_or_directory Valid Crit
$WM_PROJECT_INST_DIR --------- env variable not set --------- yes
$WM_PROJECT_USER_DIR --------- env variable not set --------- no
$FOAM_JOB_DIR --------- env variable not set --------- yes
Checking the FOAM env variables set on the PATH...
Environment_variable Set_to_file_or_directory Valid Path Crit
$WM_PROJECT_DIR --------- env variable not set --------- yes
$FOAM_USER_APPBIN --------- env variable not set --------- no
$FOAM_APPBIN --------- env variable not set --------- yes
$WM_DIR --------- env variable not set --------- yes
$FOAMX_PATH --------- env variable not set --------- yes
$CEI_HOME --------- env variable not set --------- no
$JAVA_PATH --------- env variable not set --------- no
$MICO_ARCH_PATH --------- env variable not set --------- yes
$LAM_ARCH_PATH --------- env variable not set --------- yes
$MPICH_ARCH_PATH --------- env variable not set --------- no
Checking the FOAM env variables set on the LD_LIBRARY_PATH...
$FOAM_LIBBIN --------- env variable not set --------- yes
$FOAM_USER_LIBBIN --------- env variable not set --------- no
Software versions
Software Version Location
gcc 3.4.2
WARNING: Conflicting installations:
foam settings: /bin/gcc
current path : /usr/bin/gcc
CRITICAL ERROR
java previous
libgcj)
foam settings: /bin/java
current path : /usr/bin/java
gzip 1.3.3 /usr/bin/gzip
tar 1.3.3 /bin/tar
icoFoam *** not installed ***
CRITICAL ERROR
Checking file/directory permissions...
File/directory Set Reqd Crit
Checking networking...
Action Result Crit
...localhost.localdomain Successful yes
Pinging_localHost Successful yes
Test_rsh: Unsuccessful_connection_refused* yes
Test_ssh: Successful yes
(*) Only one of rsh or ssh is required by the Foam enviroment.
Base configuration ok.
The foam installation contains 2 critical error(s).
Review the output for warning messages and consult
the installation guide for trouble shooting.
...can anyone tell me how to set environment variables and what exactly is the problem.
Old   September 4, 2005, 10:15
Default Hi, Under $HOME/OpenFOAM, d
Pei-Ying Hsieh
hsieh is on a distinguished road
Under $HOME/OpenFOAM, did you create a folder called linux, placed gcc, java, paraview tgz files under linux, and then unpack the tgz files there?
The very first time I installed OpenFOAM, I put all the downloaded files under OpenFOAM and got similar errors.
pei
hsieh is offline   Reply With Quote
Setting Environment Variables PETER P. CFX 1 August 3, 2008 18:33
MPI Environment Variables braennstroem OpenFOAM Installation 8 February 8, 2008 09:19
What is the future CFD environment? TP Main CFD Forum 3 January 23, 2007 10:19
environment variables version 3.2 F.K. Siemens 15 June 28, 2004 12:41
home environment john FLUENT 2 May 24, 2004 05:55
