May 6, 2009, 09:26 |
compilation error in OF-1.5
matteo lombardi
Rep Power: 17 |
Hello, I am trying to compile OF-1.5 and it works ok for a while but then abruptly it says:
SOURCE=fields/fvPatchFields/basic/calculated/calculatedFvPatchFields.C ; g++ -m64 -Dlinux64 -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -march=opteron -O3 -DNoRepository -ftemplate-depth-40 -I/u/cmcs/lombardi/OpenFOAM/OpenFOAM-1.5/src/triSurface/lnInclude -I/u/cmcs/lombardi/OpenFOAM/OpenFOAM-1.5/src/meshTools/lnInclude -IlnInclude -I. -I/u/cmcs/lombardi/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude -I/u/cmcs/lombardi/OpenFOAM/OpenFOAM-1.5/src/OSspecific/Unix/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/calculatedFvPatchFields.o /u/cmcs/lombardi/OpenFOAM/OpenFOAM-1.5/src/meshTools/lnInclude/wallPointData.C: In function ‘Foam::Ostream& Foamerator<<(Foam::Ostream&, const Foam::wallPointData<Type>&) [with Type = Foam::Vector<double>]’: /u/cmcs/lombardi/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/FaceCellWave.C:264: instantiated from ‘void Foam::FaceCellWave<Type>::checkCyclic(const FoamlyPatch&) const [with Type = Foam::wallPointData<Foam::Vector<double> >]’ /u/cmcs/lombardi/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/FaceCellWave.C:787: instantiated from ‘void Foam::FaceCellWave<Type>::handleCyclicPatches() [with Type = Foam::wallPointData<Foam::Vector<double> >]’ /u/cmcs/lombardi/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/FaceCellWave.C:1059: instantiated from ‘Foam::label Foam::FaceCellWave<Type>::iterate(Foam::label) [with Type = Foam::wallPointData<Foam::Vector<double> >]’ /u/cmcs/lombardi/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/FaceCellWave.C:854: instantiated from ‘Foam::FaceCellWave<Type>::FaceCellWave(const FoamlyMesh&, const Foam::labelList&, const Foam::List<T>&, Foam::UList<T>&, Foam::UList<T>&, Foam::label) [with Type = Foam::wallPointData<Foam::Vector<double> >]’ /u/cmcs/lombardi/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/MeshWave.C:65: instantiated from ‘Foam::MeshWave<Type>::MeshWave(const FoamlyMesh&, const Foam::labelList&, const Foam::List<T>&, Foam::label) [with Type = Foam::wallPointData<Foam::Vector<double> >]’ /u/cmcs/lombardi/OpenFOAM/OpenFOAM-1.5/src/meshTools/lnInclude/patchDataWave.C:233: instantiated from ‘void Foam:atchDataWave<TransferType>::correct() [with TransferType = Foam::wallPointData<Foam::Vector<double> >]’ /u/cmcs/lombardi/OpenFOAM/OpenFOAM-1.5/src/meshTools/lnInclude/patchDataWave.C:193: instantiated from ‘Foam:atchDataWave<TransferType>:atchDataWave(cons t FoamlyMesh&, const Foam::labelHashSet&, const Foam::List<Foam::Field<typename TransferType::dataType>*>&, bool) [with TransferType = Foam::wallPointData<Foam::Vector<double> >]’ fvMesh/wallDist/wallDistData.C:100: instantiated from ‘void Foam::wallDistData<TransferType>::correct() [with TransferType = Foam::wallPointData<Foam::Vector<double> >]’ fvMesh/wallDist/wallDistReflection.C:54: instantiated from here /u/cmcs/lombardi/OpenFOAM/OpenFOAM-1.5/src/meshTools/lnInclude/wallPointData.C:48: error: no matching function for call to ‘operator<<(Foam::Ostream&, const Foam::wallPoint&)’ /u/cmcs/lombardi/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/IOstream.H:550: note: candidates are: Foam::Ostream& Foamerator<<(Foam::Ostream&, const Foam::IOstream::streamFormat&) /u/cmcs/lombardi/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/char.H:51: note: Foam::Ostream& Foamerator<<(Foam::Ostream&, char) /u/cmcs/lombardi/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/char.H:52: note: Foam::Ostream& Foamerator<<(Foam::Ostream&, const char*) /u/cmcs/lombardi/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/string.H:214: note: Foam::Ostream& Foamerator<<(Foam::Ostream&, const Foam::string&) /u/cmcs/lombardi/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/string.H:68: note: Foam::Ostream& Foamerator<<(Foam::Ostream&, const std::string&) /u/cmcs/lombardi/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/word.H:129: note: Foam::Ostream& Foamerator<<(Foam::Ostream&, const Foam::word&) /u/cmcs/lombardi/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/fileName.H:173: note: Foam::Ostream& Foamerator<<(Foam::Ostream&, const Foam::fileName&) /u/cmcs/lombardi/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/int.H:59: note: Foam::Ostream& Foamerator<<(Foam::Ostream&, int) /u/cmcs/lombardi/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/bool.H:51: note: Foam::Ostream& Foamerator<<(Foam::Ostream&, bool) /u/cmcs/lombardi/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/Scalar.H:266: note: Foam::Ostream& Foamerator<<(Foam::Ostream&, Foam::floatScalar) /u/cmcs/lombardi/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/Scalar.H:266: note: Foam::Ostream& Foamerator<<(Foam::Ostream&, Foam::doubleScalar) /u/cmcs/lombardi/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/IOstream.H:551: note: Foam::Ostream& Foamerator<<(Foam::Ostream&, const Foam::IOstream::versionNumber&) (...) for a full log see file attached. any idea? I am using gcc-4.3.2 (i tried with the one in the Third party package but for some reason it always gave me some error with the libstdc++.so (why?) and thus i decided to install gcc-4.3.2..) Thanks, matteo |
Problem installing OpenFOAM 1.5 installation on RHEL 4. | vwsj84 | OpenFOAM Installation | 4 | April 23, 2009 04:48 |
OpenFOAM Version 1.5 Released | OpenFOAM discussion board administrator | OpenFOAM Announcements from ESI-OpenCFD | 0 | July 14, 2008 18:22 |
Compilation error with uparm.f | Raghu | Siemens | 2 | May 30, 2007 02:09 |
Compilation Error.... | Arnab | Siemens | 4 | September 12, 2004 15:54 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
