May 18, 2009, 16:26 |
GCC Critical Error.
Marco Bernardes
hi Guys,
I'm trying to install OpenFoam but I could not solve the following problems: I will appreciate any help. Regards, Marco. ------------------------------------- gcc ...figure WARNING: Conflicting installations: OpenFOAM settings : /home/marco/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux/bin/gcc current path : /usr/bin/gcc CRITICAL ERROR icoFoam WARNING: Conflicting installations: OpenFOAM settings : /home/marco/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/icoFoam current path : CRITICAL ERROR Checking networking... ------------------------------------------------------------------------------- Action Result Crit ------------------------------------------------------------------------------- Pinging_marco Successful yes Pinging_localHost Successful yes Test_rsh: Unsuccessful_connection_refused* yes Test_ssh: Successful yes (*) Only one of rsh or ssh is required by the OpenFOAM enviroment. ------------------------------------------------------------------------------- Base configuration ok. The foam installation contains 2 critical error(s). Review the output for warning messages and consult the installation guide for trouble shooting. done. |
May 23, 2009, 19:58 |
Anton Kidess
Rep Power: 29 |
Marco, did you edit your .bashrc file? To me it looks like the environment variables are not set correctly.
May 25, 2009, 06:20 |
Marco Bernardes
Anton,
thank you very much for your reply. Yes, I have edited the .bashrc. Now I get the following: gcc ...figure WARNING: Conflicting installations: OpenFOAM settings : /bin/gcc current path : /usr/bin/gcc CRITICAL ERROR Could help me please to solve this problem? I will appreciate it. regards, Marco. |
May 25, 2009, 13:17 |
Anton Kidess
Rep Power: 29 |
Are you trying to use the system compiler or the one with OpenFOAM (latter is highly recommended)? Is the OpenFOAM statement the last line in your ~/.bashrc? What is the output of "echo $WM_COMPILER_DIR" and "echo $PATH"?
May 27, 2009, 21:10 |
Marco Bernardes
Anton,
thank you again. I'm linux newby. The output of "echo $WM_COMPILER_DIR" returns nothing. The "echo $PATH" returns: /home/marco/OpenFOAM/ThirdParty/openmpi-1.2.6/platforms/linuxGccDPOpt/bin:/home/marco/OpenFOAM/marco-1.5/applications/bin/linuxGccDPOpt:/home/marco/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt:/home/marco/OpenFOAM/OpenFOAM-1.5/wmake:/home/marco/OpenFOAM/OpenFOAM-1.5/bin:/usr/lib/mpi/gcc/openmpi/bin:/home/marco/bin:/usr/local/bin:/usr/bin:/bin:/usr/bin/X11:/usr/X11R6/bin:/usr/games:/opt/kde3/bin:/usr/lib/mit/bin:/usr/lib/mit/sbin Thanks, Marco. |
May 28, 2009, 07:08 |
Marco Bernardes
Anton,
I have changed the OpenFOAM settings to "WM_COMPILER_INST=OpenFOAM" but the error remains the same: cc ...figure WARNING: Conflicting installations: OpenFOAM settings : /home/marco/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux/bin/gcc current path : /usr/bin/gcc CRITICAL ERROR Marco. |
May 28, 2009, 13:08 |
Anton Kidess
Rep Power: 29 |
Your PATH variable is missing an entry like ~/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux/bin. It is supposed to be set in OpenFOAM/OpenFOAM-1.5/etc/settings.sh.
OpenFOAM comes split up in four archives, two for OpenFOAM itself, two with third party applications. Did you miss either ThirdParty.General.gtgz or ThirdParty.linuxGcc.gtgz? Is there a gcc binary in /home/marco/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux/bin ? |
June 6, 2009, 21:42 |
OpenFOAM install.
Marco Bernardes
Finally I have got OpenFOAM installed. The ./foamInstallationTest have run without problem. I have tried to run the sample 'cavity'. The paraFoam command returns the following error message: paraFoam: error while loading shared libraries: libpython2.5.so.1.0: cannot open shared object file: Error 40 Could you help me please? Thanks, Marco. |
June 6, 2009, 21:47 |
Anton Kidess
Rep Power: 29 |
Thats good, you're done with the hard part I think To fix this problem, you need a scripting tool called Python. You can easily install it using the package manager of your Linux distribution, e.g. Synaptic on Ubuntu/Debian or Yast on SUSE.
June 11, 2009, 04:55 |
Hello masb and akidess,
masb: I've exactly the same problems. Can you tell me exactly what you did to solve the following error gcc ...figure WARNING: Conflicting installations: OpenFOAM settings : /bin/gcc current path : /usr/bin/gcc CRITICAL ERROR There is a gcc binary in /home/xxx/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux/bin Moreover, I tried too to run the sample 'cavity' : First, I had the same message as your : paraFoam: error while loading shared libraries: libpython2.5.so.1.0: cannot open shared object file So I installed the librairy libpython3.0 (the most recent version). Now: > paraFoam paraview: error while loading shared libraries: libpython2.5.so.1.0: cannot open shared object file: No such file or directory What should I do? akidess (or others), any idea? |
June 11, 2009, 15:51 |
#11 |
Marco Bernardes
Anton,
After the Paraview 3.3 and the PV3FoamReader module compilation the paraview is working fine. After running the cavity sample, paraFoam starts the paraview program but I can't see any result. Regards, Marco. The blockMesh returns: /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.5 | | \\ / A nd | Web: http://www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Exec : blockMesh Date : Jun 11 2009 Time : 16:45:29 Host : linux-l0h8 PID : 5107 Case : /home/marco/OpenFOAM/marco-1.5/run/tutorials/icoFoam/cavity nProcs : 1 // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Reading block mesh description dictionary Creating block mesh Creating blockCorners Creating curved edges Creating blocks Creating patches Creating block mesh topology Default patch type set to empty Check block mesh topology Basic statistics Number of internal faces : 0 Number of boundary faces : 6 Number of defined boundary faces : 6 Number of undefined boundary faces : 0 Checking patch -> block consistency Creating block offsets Creating merge list . Creating points Creating cells Creating patches Creating mesh from block mesh Default patch type set to empty Writing polyMesh end ************************************************** ******* The icoFoam command returns many things like this: Time = 0.5 Courant Number mean: 0.116925 max: 0.852134 DILUPBiCG: Solving for Ux, Initial residual = 1.89493e-07, Final residual = 1.89493e-07, No Iterations 0 DILUPBiCG: Solving for Uy, Initial residual = 4.14522e-07, Final residual = 4.14522e-07, No Iterations 0 DICPCG: Solving for p, Initial residual = 1.06665e-06, Final residual = 3.39604e-07, No Iterations 1 time step continuity errors : sum local = 5.25344e-09, global = 8.60268e-20, cumulative = -1.20491e-18 DICPCG: Solving for p, Initial residual = 5.36118e-07, Final residual = 5.36118e-07, No Iterations 0 time step continuity errors : sum local = 6.86432e-09, global = -1.44128e-18, cumulative = -2.64619e-18 ExecutionTime = 0.4 s ClockTime = 3 s End ************************************************** * |
June 11, 2009, 16:11 |
Sucess!
#12 |
Marco Bernardes
Anton,
finally I have got the image of the results. Thank you very much for your help. The program is great! Regards, Marco. |
June 11, 2009, 19:29 |
#13 |
Anton Kidess
Rep Power: 29 |
Great Marco, good job!
Riderman, python 3 is no substitute for python 2.5. Try installing the proper version. Also, did you edit your ~/.bashrc file to include the OpenFOAM bashrc? In OpenFoam-1.5/etc/settings.sh, is WM_COMPILER_INST set to OpenFOAM? |
June 12, 2009, 10:33 |
#14 |
Hello akidess,
I don't really know what I should do. What do you exactly mean by - "edit your ~/.bashrc file to include the OpenFOAM bashrc". Updating the environmental variables? Yes I did it. - "is WM_COMPILER_INST set to OpenFOAM" I've done everything that is written in the README file (http://www.opencfd.co.uk/openfoam/doc/README.html) until >paraFoam, in 6 getting Started The proper version of libpython isn't available: http://packages.ubuntu.com/search?la...ords=libpython. That's why a installed the version 3.0 Thank you for your help and have a nice Friday. |
June 12, 2009, 13:29 |
#15 |
Anton Kidess
Rep Power: 29 |
I recommend using ubuntu 8.04 LTS (personally I use 8.10). There are posts of problems with paraFoam and 9.04 in this Forum without a solution. Anyways, from your link it looks like Python 2.6 is available, so install that. Unlike Python 3, it should be compatible to Python 2.5.
To be more clear on what I wrote earlier: You edited the file ~/.bashrc to include the line ". $HOME/OpenFOAM/OpenFOAM-<VERSION>/etc/bashrc"? Is OpenFOAM installation in $HOME/OpenFoam/OpenFOAM-1.5/ ? Now, look at $HOME/OpenFOAM/OpenFOAM-<VERSION>/etc/settings.sh: Find a line that starts with WM_COMPILER_INST and see if it's set to OpenFOAM and not system. I'm assuming from the output you provided that you got the first two steps right, but there's something wrong in the settings.sh file. -Anton |
June 16, 2009, 11:39 |
Thank you!!!
#16 |
Yeahhhhhhhhhh at least it works!!!
Thank you very much Akidess, you can't imagine (or perhaps yes ) how I'm happy. Champagne! Would you like a flute? However, I've this error message: >OpenFOAM/OpenFOAM-1.5/tutorials/icoFoam/cavity$ paraFoam Could not find platform independent libraries <prefix> Consider setting $PYTHONHOME to <prefix>[:<exec_prefix>] 'import site' failed; use -v for traceback warning: Not importing directory '/usr/lib/python2.5/encodings': missing __init__.py unknown chip id 0x94c9, can't guess But, but, the graphic windows opened. I have got any idea of what it means. |
June 16, 2009, 14:57 |
#17 |
Anton Kidess
Rep Power: 29 |
Great, I'm glad I could help . I've never come across those messages, so I'll have to refer you to your favorite search engine if no-one else knows an answer.
Some clues: The $PYTHONHOME environment variable is not set on my computer either, so that is not the culprit. The "unidentified chip" message sounds like a problem with your graphics driver. Cheers, Anton |
June 18, 2009, 07:17 |
#18 |
Hello Akidess, and hello others,
I have a problem with paraview, exactly the same as in the following link: http://www.cfd-online.com/Forums/ope...afoam-bug.html " A reader for "cavity.OpenFOAM" could not be found. Please choose one: " this is followed by a long list of file formats However, Qt is still installed. >~/OpenFOAM/ThirdParty$ qmake --version QMake version 2.01a Using Qt version 4.5.0 in /usr/lib Should I uninstall this version and install another one? |
June 18, 2009, 13:07 |
#19 |
Anton Kidess
Rep Power: 29 |
Did you use paraview, or paraFoam? Latter is the correct command.
June 19, 2009, 05:29 |
#20 |
I used paraFoam.
For the moment, in the readme (http://www.opencfd.co.uk/openfoam/doc/README.html), I'm still at the 6 point, Getting Started Should I go to the next step? Last edited by riderman; June 19, 2009 at 06:53. |
Compile problem | ivanyao | OpenFOAM Running, Solving & CFD | 1 | October 12, 2012 09:31 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
Compiling problems with hello worldC | fw407 | OpenFOAM Installation | 21 | January 6, 2008 17:38 |
user subroutine error | CFDUSER | CFX | 2 | December 9, 2006 06:31 |
