Problem in running tutorial cases
Old   February 1, 2006, 13:52
Default Hi all, I downloaded all the
preetham
Hi all,
I downloaded all the requisite files and installed them as per the instructions in the README file. The FoamInstallationTest was succesful. However, when i tried running the tutorial cases by typing in FoamX, i get the following error
/home/preetham/OpenFOAM/OpenFOAM-1.2/bin/runFoamXHB: line 122: nsd: command not found
Moreover, when i type in the command blockMesh . cavity, I get the following error:
blockMesh: error while loading shared libraries: libmeshTools.so: cannot open shared object file: No such file or directory
the results of running the foamInstallation check is shown below:
Executing ./foamInstallationTest:
Checking basic setup...
Shell: bash
Host: svasti
OS: Linux version 2.6.11-1.1369_FC4smp
User: preetham
User_config: /home/preetham/.bashrc
Foam_config: /home/preetham/.OpenFOAM-1.2/bashrc sourced correctly.
Checking main FOAM env variables...
Environment_variable Set_to_file_or_directory Valid Crit
$WM_PROJECT_INST_DIR /home/preetham/OpenFOAM yes yes
$WM_PROJECT_USER_DIR /home/preetham/OpenFOAM/preetham-1.2 yes no
$FOAM_JOB_DIR /home/preetham/OpenFOAM/jobControl no yes
Checking the FOAM env variables set on the PATH...
Environment_variable Set_to_file_or_directory Valid Path Crit
$WM_PROJECT_DIR /home/preetham/OpenFOAM/OpenFOAM-1.2 yes yes yes
$FOAM_USER_APPBIN ...am-1.2/applications/bin/linuxGcc4Opt yes yes no
$FOAM_APPBIN ...AM-1.2/applications/bin/linuxGcc4Opt yes yes yes
$WM_DIR ...preetham/OpenFOAM/OpenFOAM-1.2/wmake yes yes yes
$FOAMX_PATH ...ations/utilities/preProcessing/FoamX yes no yes
$CEI_HOME /usr/local/ensight/CEI no no
$JAVA_PATH ...reetham/OpenFOAM/linux/j2sdk1.4.2_05 yes yes no
$MICO_ARCH_PATH ...c/mico-2.3.11/platforms/linuxGcc4Opt no yes
$LAM_ARCH_PATH ...src/lam-7.1.1/platforms/linuxGcc4Opt yes yes yes
$MPICH_ARCH_PATH --------- env variable not set --------- no
Checking the FOAM env variables set on the LD_LIBRARY_PATH...
$FOAM_LIBBIN ...enFOAM/OpenFOAM-1.2/lib/linuxGcc4Opt yes yes yes
$FOAM_USER_LIBBIN ...enFOAM/preetham-1.2/lib/linuxGcc4Opt yes yes no
Software versions
Software Version Location
gcc 4.0.0 /usr/bin/gcc
java 1.4.2_05 /home/preetham/OpenFOAM/linux/j2sdk1.4.2_05/bin/java
gzip 1.3.5 /usr/bin/gzip
tar 1.3.5 /bin/tar
icoFoam ...OAM/OpenFOAM-1.2/applications/bin/linuxGcc4Opt/icoFoam
Checking file/directory permissions...
File/directory Set Reqd Crit
Checking networking...
Action Result Crit
Pinging_svasti Successful yes
Pinging_localHost Successful yes
Test_rsh: Unsuccessful_connection_refused* yes
Test_ssh: Successful yes
(*) Only one of rsh or ssh is required by the Foam enviroment.
Base configuration ok.
Critical systems ok.
Any help would be greatly appreciated !!!!
Regards
preetham
Old   February 2, 2006, 04:38
Default do ldd `which blockMesh`
Mattijs Janssens
mattijs is on a distinguished road
do
to see which libraries are missing. Check the $FOAM_LIBBIN directory and see what is in there. (libmeshTools.so should be there).
Maybe you haven't unpacked the binary pack (OpenFOAM-1.2.linuxGcc4Opt_XXX.tgz) or it didn't complete? (since you do seem to have the icoFoam executable)
mattijs is offline   Reply With Quote
Old   June 13, 2009, 16:36
pks
pks is on a distinguished road
Originally Posted by mattijs View Post
do
I'm also getting the same error. I checked the availability of libmeshTools.so at $FOAM_LIBBIN, its there. I did a chmod 666, but in vain. May be I need to chek the paths. Please advice.
Thanks in advance.
pks is offline   Reply With Quote
Running Multiple cases over night Michael Bo Hansen FLUENT 9 May 7, 2009 03:10
VOF6DOF Tutorial Cases lukasfischer OpenFOAM Running, Solving & CFD 0 January 29, 2009 13:56
InterDyMFoam tutorial cases hsieh OpenFOAM Running, Solving & CFD 0 November 14, 2008 10:21
Compilation Error when running Tutorial 2.4 zhihuali Siemens 7 April 1, 2008 07:34
Tutorial is not running on star-CD version 3.2 Arnab Siemens 0 August 30, 2004 15:43
