August 25, 2009, 08:36 |
paraFoam does not run
Rainer Schaefer
Who can help me:
Where can I download Qt4.3.x and libssl.so.0.9.8 ? Thank you in advance. Rainer |
August 26, 2009, 03:25 |
Gijsbert Wierink
Rep Power: 18 |
Hi Rainer,
Qt-4.3.5 you can find at ftp://ftp.trolltech.no/qt/source/ Look for the package "qt-x11-opensource-src-4.3.5.tar.gz" (somewhere at the bottom of the list), that one worked for me. The missing lib I would first just try to install it via Code:
sudo apt-get install libssl.so.0.9.8 Code:
su -c 'yum install libssl.so.0.9.8' Regards, Gijs |
August 26, 2009, 05:36 |
Disabled
hello rainer
just go to paraview.org and then download the paraview version you need unpak it and just put the path in your .bashrc or .profile like you want and then that is enogh i dont think that this version runs with qt i think it runs under the x-window i dont really know but it looks really defrent to the other's (i mean how the window looks like) then do not use paraFoam you have to convert your resultion files with foamToVTK and then use this paraview |
September 2, 2009, 07:55 |
Rainer Schaefer
Hallo Gijs,
thank you for your information. Unfortinately I'm using RHEL5.3. And I have heard, that there will arise some difficulties with QT4.3.5. Best Wishes Rainer |
September 2, 2009, 08:13 |
Niels Nielsen
Rep Power: 27 |
Hi
If you are using 64bit consider this http://www.cfd-online.com/Forums/ope...-x86_64-a.html Here everything works for RHEL 5.3 64bit and clones like CentOS. regards |
Working directory via command line | Luiz | CFX | 4 | March 6, 2011 20:02 |
[OpenFOAM] ParaFoam reader | duartealbuquerque | ParaView | 21 | December 23, 2009 23:29 |
[OpenFOAM] ParaFoam Scripting | iyer_arvind | ParaView | 7 | November 2, 2006 04:06 |
[OpenFOAM] ParaFoam outputs empty foam file | theof | ParaView | 1 | January 20, 2006 13:51 |
Problem running paraFoam paraview command not found | spdracer22 | OpenFOAM Pre-Processing | 2 | December 7, 2005 05:32 |
