Random machine freezes when running several OpenFoam jobs simultaneously |
August 27, 2009, 12:00 |
Tobias Baier
Dear Foamers,
I am experiencing random machine freezes when running several (>6) OpenFoam processes on an 8-kernel computer (two quad-core processors) and I cannot figure out why this is happening. Maybe someone has had the same experience or an idea what might be going on. A little background: a) When I start > 6 OpenFOAM processes simultaneously the system completely freezes between 1 and 30 minutes later. This happens both when I run a parallel job or several individual jobs. ("Freeze" means no keyboard entry is accepted and the mouse doesn't move - I cannot even change to the basic shell with "ctrl-alt-F1" and no connection via network is possible.) b) I am not observing this behavior with any other program (in particular parallel jobs in Mathematica and Comsol run for >12 hours using all 8 system cores without problems) c) In particular I have been using icoFoam and simpleFoam as well as self compiled variants of these which also solve a scalar equation. d) The same problem occurs under OpenSUSE 11.0 and the enterprise version SLES10-SP2. e) I could reproduce the behavior with OpenFoam versions 1.5, 1.6 and also 1.3. f) The jobs I used are not particularly memory intensive, so no wild swapping is going on. g) Running only a few jobs works fine... The computer I am using has two quad-core Intel-Xeon X5570 CPUs and 12 GB of RAM. I have been using the pre-compiled OpenFOAM binaries as downloaded from sourceforge (apart from the two customized solvers). Any suggestions on how to overcome the problem are greatly appreciated! Thanks, Tobias Baier |
July 2, 2010, 04:55 |
Muhammad reza hassani
I have the same problem, when I edit color map or legends. how I can kill the process when the keyboard does not function. If I wait, does it differ? I have not waited more than 10 min. I don't know if I wait more it gets out of the freeze condition
July 2, 2010, 06:33 |
#3 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
No idea about the original problem |
July 2, 2010, 06:34 |
#4 | |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings mhassani,
You're experiencing problems with ParaView, not OpenFOAM in particular. Quote:
Best regards, Bruno
July 2, 2010, 06:38 |
Niklas Nordin
Rep Power: 29 |
are you running the job over a network disk?
is it the same when you run them under /scratch? is it the same when your foam installation is under /scratch? N |
July 2, 2010, 07:40 |
Tobias Baier
Hi mhassani,
I never found out what really was the reason for my system hangups, but in the end concluded that is was most likely a hardware problem and that it was unrelated to OpenFOAM (I also occasionally got hangups when using some other software heavily). Anyway, I believe you are experiencing the same problem but most likely for some different reason, since in particular you seem to get a hangup while using Paraview. Have you tried using "ctrl-alt-F1" to switch to a basic shell? If that still works, you might be able to abort paraview from there... Best, Tobias |
Statically Compiling OpenFOAM Issues | herzfeldd | OpenFOAM Installation | 21 | January 6, 2009 09:38 |
OpenFOAM Distribution by Virtual Machine | will | OpenFOAM Installation | 5 | June 20, 2008 08:11 |
Adventure of fisrst openfoam installation on Ubuntu 710 | jussi | OpenFOAM Installation | 0 | April 24, 2008 14:25 |
Kubuntu uses dash breaks All scripts in tutorials | platopus | OpenFOAM Bugs | 8 | April 15, 2008 07:52 |
Running 2 CFD jobs on one PC | steve podleski | Main CFD Forum | 17 | February 16, 2000 14:40 |
