How to compile OF with another Mpi
Old   September 4, 2009, 05:17
Post How to compile OF with another Mpi
Ivan Flaminio Cozza
ivan_cozza is on a distinguished road
Send a message via MSN to ivan_cozza
Hi Foamers,
I would like to compile OF with an OpenMPI version different from the one included in the Third Party, as I use other home-made parallel codes that work with a system installation of OpenMPI libraries. The standard OF installation overwrites the $MPI_HOME and $MPI_ARCH_PATH variables, so the system installation is switched off.
Is there any simple workaround to tell OF to use my system installation? Actually I'm obliged to create a separate openfoam user on my system, but I would prefer to use OF and my other codes from a single user.
I use OpenFOAM-1.6.x under a SLAMD64 Linux distro.
Thanks, Ivan
ivan_cozza is offline   Reply With Quote
Old   September 29, 2009, 12:43
bigphil's Avatar
Philip Cardiff
bigphil will become famous soon enoughbigphil will become famous soon enough
I think $MPI_HOME and $MPI_ARCH_PATH variables are set in '$WM_PROJECT_DIR/etc/settings.sh' about two-thirds of the way down:
case "$WM_MPLIB" in
OPENMPI)
#mpi_version=openmpi-1.3.3
mpi_version=openmpi-1.2.6
export MPI_HOME=$WM_THIRD_PARTY_DIR/$mpi_version
export MPI_ARCH_PATH=$MPI_HOME/platforms/$WM_OPTIONS
# Tell OpenMPI where to find its install directory
export OPAL_PREFIX=$MPI_ARCH_PATH
_foamAddPath $MPI_ARCH_PATH/bin
_foamAddLib $MPI_ARCH_PATH/lib
export FOAM_MPI_LIBBIN=$FOAM_LIBBIN/$mpi_version
unset mpi_version
You could probably change these to where your system OpenMPI is installed, just a suggestion not sure if it will work.
Philip
bigphil is offline   Reply With Quote
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM Rizwan Fluent UDF and Scheme Programming 40 March 18, 2018 06:05
Error compile file udf czfluent Fluent UDF and Scheme Programming 24 September 26, 2009 13:24
Error using LaunderGibsonRSTM on SGI ALTIX 4700 jaswi OpenFOAM 2 April 29, 2008 10:54
Is Testsuite on the way or not lakeat OpenFOAM Installation 6 April 28, 2008 11:12
MPI and parallel computation Wang Main CFD Forum 7 April 15, 2004 11:25
