July 22, 2010, 13:53 |
unable to install openfoam 1.7 using apt-get
Maaz Ahmed
I am a complete newbie to openfoam and am trying to install it, I get the following message on the screen root@maaz-laptop:/home/maaz/OpenFoam# apt-get install openfoam170 Reading package lists... Done Building dependency tree Reading state information... Done openfoam170 is already the newest version. You might want to run `apt-get -f install' to correct these: The following packages have unmet dependencies: openfoam170: Depends: libc6 (>= 2.11) but 2.9-4ubuntu6.2 is to be installed Depends: libopenmpi1.3 but it is not installable Depends: libqt4-help (>= 4:4.5.3) but it is not going to be installed Depends: libqt4-network (>= 4:4.5.3) but it is not going to be installed Depends: libqt4-sql (>= 4:4.5.3) but it is not going to be installed Depends: libqt4-webkit (>= 4:4.5.3) but it is not going to be installed Depends: libqt4-xml (>= 4:4.5.3) but it is not going to be installed Depends: libqtcore4 (>= 4:4.6.1) but it is not going to be installed Depends: libqtgui4 (>= 4:4.5.3) but it is not going to be installed Depends: libscotch-5.1 but it is not installable Depends: libstdc++6 (>= 4.4.0) but 4.3.3-5ubuntu4 is to be installed E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution). this gives a clearer picture I guess root@maaz-laptop:/home/maaz/OpenFoam# dpkg -i openfoam170_0-1_i386.deb Selecting previously deselected package openfoam170. (Reading database ... 110089 files and directories currently installed.) Unpacking openfoam170 (from openfoam170_0-1_i386.deb) ... dpkg: dependency problems prevent configuration of openfoam170: openfoam170 depends on libc6 (>= 2.11); however: Version of libc6 on system is 2.9-4ubuntu6.2. openfoam170 depends on libopenmpi1.3; however: Package libopenmpi1.3 is not installed. openfoam170 depends on libqt4-help (>= 4:4.5.3); however: Package libqt4-help is not installed. openfoam170 depends on libqt4-network (>= 4:4.5.3); however: Version of libqt4-network on system is 4.5.0-0ubuntu4.3. openfoam170 depends on libqt4-sql (>= 4:4.5.3); however: Version of libqt4-sql on system is 4.5.0-0ubuntu4.3. openfoam170 depends on libqt4-webkit (>= 4:4.5.3); however: Version of libqt4-webkit on system is 4.5.0-0ubuntu4.3. openfoam170 depends on libqt4-xml (>= 4:4.5.3); however: Version of libqt4-xml on system is 4.5.0-0ubuntu4.3. openfoam170 depends on libqtcore4 (>= 4:4.6.1); however: Version of libqtcore4 on system is 4.5.0-0ubuntu4.3. openfoam170 depends on libqtgui4 (>= 4:4.5.3); however: Version of libqtgui4 on system is 4.5.0-0ubuntu4.3. openfoam170 depends on libscotch-5.1; however: Package libscotch-5.1 is not installed. openfoam170 depends on libstdc++6 (>= 4.4.0); however: Version of libstdc++6 on system is 4.3.3-5ubuntu4. dpkg: error processing openfoam170 (--install): dependency problems - leaving unconfigured Errors were encountered while processing: openfoam170 I have a .deb package of openfoam download which was available on the site for a few days. and when i do a apt-get -f install, root@maaz-laptop:/home/maaz/OpenFoam# apt-get -f install Reading package lists... Done Building dependency tree Reading state information... Done Correcting dependencies... Done The following packages were automatically installed and are no longer required: libstdc++6-4.3-dev libsm-dev libice-dev x11proto-kb-dev libscotch-dev libgfortran3 g++-4.3 m4 libxdmcp-dev g++ xtrans-dev x11proto-core-dev csh binutils-dev libxt-dev zlib1g-dev x11proto-input-dev libpthread-stubs0-dev flex libxau-dev libpthread-stubs0 openmpi-bin libscotch-5.0.6 libibverbs1 openmpi-common libx11-dev libopenmpi-dev libxcb1-dev libopenmpi1 Use 'apt-get autoremove' to remove them. The following packages will be REMOVED: openfoam170 0 upgraded, 0 newly installed, 1 to remove and 8 not upgraded. 1 not fully installed or removed. After this operation, 352MB disk space will be freed. Do you want to continue [Y/n]? I gave a no and tried installing the dependencies one by one. For this I built a dependency tree amongst the pakages not installed as libc6 libstdc++6 libscotch-5.1 libopenmpi1.3 libqtcore4 Depends: libc6 (>= 2.4) Depends: libstdc++6 (>= 4.1.1) libqtgui4 Depends: libc6 (>= 2.4) Depends: libqtcore4 (= 4.5.0-0ubuntu4) Depends: libstdc++6 (>= 4.1.1) libqt4-webkit Depends: libc6 (>= 2.3.6-6~) Depends: libqtcore4 (= 4.5.0-0ubuntu4) Depends: libqtgui4 (= 4.5.0-0ubuntu4) Depends: libstdc++6 (>= 4.1.1) libqt4-xml Depends: libc6 (>= 2.4) Depends: libqtcore4 (= 4.5.0-0ubuntu4) Depends: libstdc++6 (>= 4.1.1) libqt4-sql Depends: libc6 (>= 2.1.3) Depends: libqtcore4 (= 4.5.0-0ubuntu4) Depends: libstdc++6 (>= 4.1.1) and started with libc6 and got the following message root@maaz-laptop:/home/maaz/OpenFoam# apt-get install libc6 -t '4.4*' Reading package lists... Done Building dependency tree Reading state information... Done libc6 is already the newest version. The following packages were automatically installed and are no longer required: libstdc++6-4.3-dev libsm-dev libice-dev x11proto-kb-dev libscotch-dev libgfortran3 g++-4.3 m4 libxdmcp-dev g++ xtrans-dev x11proto-core-dev csh binutils-dev libxt-dev zlib1g-dev x11proto-input-dev libpthread-stubs0-dev flex libxau-dev libpthread-stubs0 openmpi-bin libscotch-5.0.6 libibverbs1 openmpi-common libx11-dev libopenmpi-dev libxcb1-dev libopenmpi1 Use 'apt-get autoremove' to remove them. 0 upgraded, 0 newly installed, 0 to remove and 8 not upgraded. so I believe I need a source where I can get these libraries but I see quiet a few successful instalation done here need help for the same. |
July 23, 2010, 05:57 |
#2 | |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Maaz and welcome to the forum!
Wow! By what I can see in your post, you know your way around apt-get and dpkg! But I've got a strange feeling you didn't check one thing - right at the beginning of the page with the instructions for installing in Ubuntu, it has this information: Quote:
lsb_release -a Best regards, Bruno
July 23, 2010, 09:02 |
I experienced this same issue with a new install of Lucid Lynx (Ubuntu 10.04). I think the default install does not enable the "Universe" repositories. These are required to satisfy these dependencies. You can enable these by editing /etc/apt/sources.list and running "apt-get update".
I hope this helps! |
July 24, 2010, 00:32 |
Maaz Ahmed
Thanks wyldckat
And thanks again for a spot on diagnosis, ya I have been using 9.04 and how could I have overlooked the first line :-(. Trying to build from the source now. That reminds me.... I am using a ubuntu 9.04 installation on a virtualBox. Anybody has any idea if the virtual box can handle the graphics. Last edited by maazhmd; July 24, 2010 at 00:40. Reason: Question added |
July 25, 2010, 14:08 |
#5 | |
Bruno Santos
Rep Power: 128 |
Greetings Maaz,
Hopefully this will stop being an issue in the next few months, since Intel has been injecting their own brand of GPU into the new processors, so hopefully they will start providing a VT bit/flag for hardware graphics acceleration in virtual machines! Best regards, Bruno
July 24, 2011, 00:44 |
#6 | |
behzad
"the following packages have unmet dependencies.." you suggested editing the "etc/apt/source.lict" but i dont really get you. how should i edit it? have any one else faced or solved this problem?? thanks to all |
July 24, 2011, 06:38 |
Bruno Santos
Rep Power: 128 |
Greetings Basy,
Just a week ago someone else also got this problem: http://www.cfd-online.com/Forums/ope...lgeria-dz.html Read that thread and you should find the solutions for your questions Best regards, Bruno
July 24, 2011, 11:18 |
#8 | |
behzad
at the moment I'm not sure if it could be the reason or not, because it is my first day ever in ubuntu. if this was not the reason, the only thing i can think of, is a problem in their website or bad internet connection at first times, that interrupted download procedure and files couldn't transfer completely. cheers |
installataion, openfoam 1.7.0 |
How to Install OpenFOAM on 64 Ubuntu 9.04 | hansel | OpenFOAM Installation | 62 | March 19, 2010 14:43 |
install openfoam 1.6 on opensuse 11.0 | andresbh | OpenFOAM Installation | 8 | September 30, 2009 00:48 |
OpenFOAM Install problem | masb | OpenFOAM | 3 | May 25, 2009 11:32 |
[Commercial meshers] ST_Malloc: out of memory.malloc_storage: unable to malloc Velocity SA, | cfdproject | OpenFOAM Meshing & Mesh Conversion | 0 | April 14, 2009 15:45 |
64bitrhel5 OF installation instructions | mirko | OpenFOAM Installation | 2 | August 12, 2008 18:07 |
