March 9, 2010, 17:47 |
paraview installation woes
Anon
Rep Power: 16 |
I've installed OpenFOAM 1.6 on Ubuntu 9.10 but I'm having issues with installing the paraview portion. I've followed the install directions and unpacked it in the thirdparty-1.6 folder. I've configured it according to the instructions provided but I still get errors
When attempting to run makeParaView command I receive: Code:
makeParaView: command not found Code:
>blockMesh >icoFoam >paraFoam Code:
created temporary 'cavity.OpenFOAM' /home/vex/OpenFOAM/OpenFOAM-1.6/bin/paraFoam: 132: paraview: not found |
March 10, 2010, 02:27 |
#2 | |
Mark Olesen
Rep Power: 40 |
$ foam3rdParty # cd $WM_THIRD_PARTY_DIR $ ./makeParaview -help |
March 10, 2010, 12:23 |
#3 | |
Anon
Rep Power: 16 |
*** Error: cannot find qmake either at $QMAKE_PATH or in current $PATH |
March 11, 2010, 02:15 |
#4 | |
Mark Olesen
Rep Power: 40 |
Now you just need to have a Qt development environment installed. I can only send a list of RPM packages for openSUSE11.1 or openSUSE11.2, but other systems you'll have to figure it out somehow else. |
March 11, 2010, 21:32 |
Anon
Rep Power: 16 |
So what do I need to do now? I've tried to install Qt but keep running into problems.
For instance if I go and type in: Code:
sudo apt-get install qt4-qmake Code:
Reading package lists... Done Building dependency tree Reading state information... Done E: Couldn't find package qt4-qmake Code:
~/OpenFOAM/ThirdParty-1.6/qt-x11-opensource-src-4.3.5/bin Code:
qmake -v Code:
QMake version 2.01a Using Qt version 4.3.5 in /usr/local/Trolltech/Qt-4.3.5/lib Code:
. $HOME/OpenFOAM/OpenFOAM-1.6/etc/bashrc PATH=/usr/local/Trolltech/Qt-4.3.5/bin:$PATH export PATH PATH=/home/vex/OpenFOAM/ThirdParty-1.6/qt-x11-opensource-src-4.3.5/bin:$PATH export PATH |
March 12, 2010, 02:08 |
Mark Olesen
Rep Power: 40 |
March 12, 2010, 08:10 |
G B
Rep Power: 16 |
I am getting your same error vex, but with OF-1.6.x (in ubuntu 9.10). I have compiled (successfully... well i did get some warnings when it was building cxx library). paraview in both thirdparty-1.6 and in the thirdparty-1.6.x. I dont get whats going on, everything else is working fine, i also get this critical error when i run the installationtest about gcc.
This is the parafoam error message: Code:
created temporary 'cavity.OpenFOAM' /home/gustavo/OpenFOAM/OpenFOAM-1.6.x/bin/paraFoam: 132: paraview: not found Last edited by Disco_Caine; March 12, 2010 at 08:20. Reason: missing code |
March 12, 2010, 18:04 |
I got a similar error when running the test case:
created temporary 'cavity.OpenFOAM' /home/gkewl/OpenFOAM/OpenFOAM-1.6/bin/paraFoam: line 129: paraview: command not found This occured, even after I installed Qt 4.3.5 as suggested in the OpenFOAM manual and recompiled ParaView and PV3FoamReader module: http://www.openfoam.com/docs/README.php I found a related thread that dealt with this problem: http://www.cfd-online.com/Forums/ope...not-found.html Could someone help me if similar changes need to be made, but with this version of OpenFOAM, as I am new to Linux. Thanks! |
March 13, 2010, 04:25 |
#9 |
G B
Rep Power: 16 |
I am very new myself, but perhaps you need to source the bashrc after compiling paraview and pv3foamreader (that is what i did in my case, and everrything is working, for now). But i recommend waiting for a more expert opinion.
good luck with everything. |
March 13, 2010, 14:51 |
#10 |
Anon
Rep Power: 16 |
Well, I've hit another snag: I've gotten a little farther along, now when I type in 'paraFoam' I get the following:
vex@vex-laptop:~/OpenFOAM/vex-1.6/run/tutorials/incompressible/icoFoam/cavity$ paraFoam created temporary 'cavity.OpenFOAM' paraview: /home/vex/OpenFOAM/ThirdParty-1.6/gcc-4.3.3/platforms/linux64/lib64/libstdc++.so.6: version `GLIBCXX_3.4.11' not found (required by /usr/lib/paraview/libpqComponents.so) paraview: /home/vex/OpenFOAM/ThirdParty-1.6/gcc-4.3.3/platforms/linux64/lib64/libstdc++.so.6: version `GLIBCXX_3.4.11' not found (required by /usr/lib/paraview/libpqCore.so) paraview: /home/vex/OpenFOAM/ThirdParty-1.6/gcc-4.3.3/platforms/linux64/lib64/libstdc++.so.6: version `GLIBCXX_3.4.11' not found (required by /usr/lib/paraview/libQVTK.so.pv3.4) paraview: /home/vex/OpenFOAM/ThirdParty-1.6/gcc-4.3.3/platforms/linux64/lib64/libstdc++.so.6: version `GLIBCXX_3.4.11' not found (required by /usr/lib/paraview/libvtkViews.so.pv3.4) paraview: /home/vex/OpenFOAM/ThirdParty-1.6/gcc-4.3.3/platforms/linux64/lib64/libstdc++.so.6: version `GLIBCXX_3.4.11' not found (required by /usr/lib/paraview/libvtkPVServerManager.so) paraview: /home/vex/OpenFOAM/ThirdParty-1.6/gcc-4.3.3/platforms/linux64/lib64/libstdc++.so.6: version `GLIBCXX_3.4.11' not found (required by /usr/lib/paraview/libvtkPVFilters.so) paraview: /home/vex/OpenFOAM/ThirdParty-1.6/gcc-4.3.3/platforms/linux64/lib64/libstdc++.so.6: version `GLIBCXX_3.4.11' not found (required by /usr/lib/paraview/libvtkVolumeRendering.so.pv3.4) paraview: /home/vex/OpenFOAM/ThirdParty-1.6/gcc-4.3.3/platforms/linux64/lib64/libstdc++.so.6: version `GLIBCXX_3.4.11' not found (required by /usr/lib/paraview/libvtkXdmf.so) paraview: /home/vex/OpenFOAM/ThirdParty-1.6/gcc-4.3.3/platforms/linux64/lib64/libstdc++.so.6: version `GLIBCXX_3.4.11' not found (required by /usr/lib/paraview/libXdmf.so) paraview: /home/vex/OpenFOAM/ThirdParty-1.6/gcc-4.3.3/platforms/linux64/lib64/libstdc++.so.6: version `GLIBCXX_3.4.11' not found (required by /usr/lib/paraview/libvtkPVServerCommon.so) paraview: /home/vex/OpenFOAM/ThirdParty-1.6/gcc-4.3.3/platforms/linux64/lib64/libstdc++.so.6: version `GLIBCXX_3.4.11' not found (required by /usr/lib/paraview/libvtkInfovis.so.pv3.4) paraview: /home/vex/OpenFOAM/ThirdParty-1.6/gcc-4.3.3/platforms/linux64/lib64/libstdc++.so.6: version `GLIBCXX_3.4.11' not found (required by /usr/lib/paraview/libvtkWidgets.so.pv3.4) paraview: /home/vex/OpenFOAM/ThirdParty-1.6/gcc-4.3.3/platforms/linux64/lib64/libstdc++.so.6: version `GLIBCXX_3.4.11' not found (required by /usr/lib/paraview/libKWCommon.so) paraview: /home/vex/OpenFOAM/ThirdParty-1.6/gcc-4.3.3/platforms/linux64/lib64/libstdc++.so.6: version `GLIBCXX_3.4.11' not found (required by /usr/lib/paraview/libvtkPVCommandOptions.so) paraview: /home/vex/OpenFOAM/ThirdParty-1.6/gcc-4.3.3/platforms/linux64/lib64/libstdc++.so.6: version `GLIBCXX_3.4.11' not found (required by /usr/lib/paraview/libvtkGenericFiltering.so.pv3.4) paraview: /home/vex/OpenFOAM/ThirdParty-1.6/gcc-4.3.3/platforms/linux64/lib64/libstdc++.so.6: version `GLIBCXX_3.4.11' not found (required by /usr/lib/paraview/libvtkHybrid.so.pv3.4) paraview: /home/vex/OpenFOAM/ThirdParty-1.6/gcc-4.3.3/platforms/linux64/lib64/libstdc++.so.6: version `GLIBCXX_3.4.11' not found (required by /usr/lib/paraview/libvtkParallel.so.pv3.4) paraview: /home/vex/OpenFOAM/ThirdParty-1.6/gcc-4.3.3/platforms/linux64/lib64/libstdc++.so.6: version `GLIBCXX_3.4.11' not found (required by /usr/lib/paraview/libvtkRendering.so.pv3.4) paraview: /home/vex/OpenFOAM/ThirdParty-1.6/gcc-4.3.3/platforms/linux64/lib64/libstdc++.so.6: version `GLIBCXX_3.4.11' not found (required by /usr/lib/paraview/libvtkGraphics.so.pv3.4) paraview: /home/vex/OpenFOAM/ThirdParty-1.6/gcc-4.3.3/platforms/linux64/lib64/libstdc++.so.6: version `GLIBCXX_3.4.11' not found (required by /usr/lib/paraview/libvtkImaging.so.pv3.4) paraview: /home/vex/OpenFOAM/ThirdParty-1.6/gcc-4.3.3/platforms/linux64/lib64/libstdc++.so.6: version `GLIBCXX_3.4.11' not found (required by /usr/lib/paraview/libvtkIO.so.pv3.4) paraview: /home/vex/OpenFOAM/ThirdParty-1.6/gcc-4.3.3/platforms/linux64/lib64/libstdc++.so.6: version `GLIBCXX_3.4.11' not found (required by /usr/lib/paraview/libvtkFiltering.so.pv3.4) paraview: /home/vex/OpenFOAM/ThirdParty-1.6/gcc-4.3.3/platforms/linux64/lib64/libstdc++.so.6: version `GLIBCXX_3.4.11' not found (required by /usr/lib/paraview/libvtkCommon.so.pv3.4) paraview: /home/vex/OpenFOAM/ThirdParty-1.6/gcc-4.3.3/platforms/linux64/lib64/libstdc++.so.6: version `GLIBCXX_3.4.11' not found (required by /usr/lib/paraview/libvtkDICOMParser.so.pv3.4) paraview: /home/vex/OpenFOAM/ThirdParty-1.6/gcc-4.3.3/platforms/linux64/lib64/libstdc++.so.6: version `GLIBCXX_3.4.11' not found (required by /usr/lib/paraview/libvtkmetaio.so.pv3.4) paraview: /home/vex/OpenFOAM/ThirdParty-1.6/gcc-4.3.3/platforms/linux64/lib64/libstdc++.so.6: version `GLIBCXX_3.4.11' not found (required by /usr/lib/paraview/libvtksys.so.pv3.4) http://www.cfd-online.com/Forums/ope...tml#post234731 |
March 13, 2010, 15:15 |
#11 |
Anon
Rep Power: 16 |
After attempting the tutorial it appears the module for PV3FoamReader wasn't compiled correctly, so while attempting to remedy the situation I have received the following:
could not open file vtkConfigure.h for source file vtkPV3Foam.C Making dependency list for source file vtkPV3FoamFields.C could not open file vtkConfigure.h for source file vtkPV3FoamFields.C Making dependency list for source file vtkPV3FoamMesh.C could not open file vtkConfigure.h for source file vtkPV3FoamMesh.C Making dependency list for source file vtkPV3FoamMeshLagrangian.C could not open file vtkConfigure.h for source file vtkPV3FoamMeshLagrangian.C Making dependency list for source file vtkPV3FoamMeshPatch.C could not open file vtkConfigure.h for source file vtkPV3FoamMeshPatch.C Making dependency list for source file vtkPV3FoamMeshSet.C could not open file vtkConfigure.h for source file vtkPV3FoamMeshSet.C Making dependency list for source file vtkPV3FoamMeshVolume.C could not open file vtkConfigure.h for source file vtkPV3FoamMeshVolume.C Making dependency list for source file vtkPV3FoamMeshZone.C could not open file vtkConfigure.h for source file vtkPV3FoamMeshZone.C Making dependency list for source file vtkPV3FoamUpdateInfo.C could not open file vtkConfigure.h for source file vtkPV3FoamUpdateInfo.C Making dependency list for source file vtkPV3FoamUtilities.C could not open file vtkConfigure.h for source file vtkPV3FoamUtilities.C SOURCE=vtkPV3Foam.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold- style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/home/vex/OpenFOAM/OpenFOAM- 1.6/src/finiteVolume/lnInclude -I/home/vex/OpenFOAM/OpenFOAM-1.6/src/lagrangian/basic/lnInclude - I/home/vex/OpenFOAM/OpenFOAM-1.6/src/meshTools/lnInclude -I/home/vex/OpenFOAM/ThirdParty-1.6/paraview- 3.6.1/platforms/linux64Gcc/VTK -I/home/vex/OpenFOAM/ThirdParty-1.6/paraview-3.6.1 -I/home/vex/OpenFOAM/ThirdParty- 1.6/paraview-3.6.1/VTK -I/home/vex/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/VTK/Common - I/home/vex/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/VTK/Filtering -I/home/vex/OpenFOAM/ThirdParty-1.6/paraview- 3.6.1/VTK/Rendering -I../PV3FoamReader -IlnInclude -I. -I/home/vex/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude - I/home/vex/OpenFOAM/OpenFOAM-1.6/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/vtkPV3Foam.o In file included from /home/vex/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/VTK/Common/vtkSystemIncludes.h:30, from /home/vex/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/VTK/Common/vtkIndent.h:24, from /home/vex/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/VTK/Common/vtkObjectBase.h:43, from /home/vex/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/VTK/Common/vtkObject.h:41, from /home/vex/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/VTK/Filtering/vtkAlgorithm.h:32, from /home/vex/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/VTK/Filtering/vtkMultiBlockDataSetAlgorithm.h:25, from ../PV3FoamReader/vtkPV3FoamReader.h:31, from vtkPV3Foam.C:28: /home/vex/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/VTK/Common/vtkWin32Header.h:27:26: error: vtkConfigure.h: No such file or directory In file included from /home/vex/OpenFOAM/ThirdParty-1.6/paraview- 3.6.1/VTK/Common/vtkSystemIncludes.h:40, from /home/vex/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/VTK/Common/vtkIndent.h:24, from /home/vex/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/VTK/Common/vtkObjectBase.h:43, from /home/vex/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/VTK/Common/vtkObject.h:41, from /home/vex/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/VTK/Filtering/vtkAlgorithm.h:32, from /home/vex/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/VTK/Filtering/vtkMultiBlockDataSetAlgorithm.h:25, from ../PV3FoamReader/vtkPV3FoamReader.h:31, from vtkPV3Foam.C:28: /home/vex/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/VTK/Common/vtkIOStream.h:68:68: error: iostream.h: No such file or directory /home/vex/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/VTK/Common/vtkIOStream.h:69:23: error: iomanip.h: No such file or directory /home/vex/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/VTK/Common/vtkIOStream.h:70:70: error: fstream.h: No such file or directory In file included from /home/vex/OpenFOAM/ThirdParty-1.6/paraview- 3.6.1/VTK/Common/vtkSystemIncludes.h:44, from /home/vex/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/VTK/Common/vtkIndent.h:24, from /home/vex/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/VTK/Common/vtkObjectBase.h:43, from /home/vex/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/VTK/Common/vtkObject.h:41, from /home/vex/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/VTK/Filtering/vtkAlgorithm.h:32, from /home/vex/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/VTK/Filtering/vtkMultiBlockDataSetAlgorithm.h:25, from ../PV3FoamReader/vtkPV3FoamReader.h:31, from vtkPV3Foam.C:28: /home/vex/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/VTK/Common/vtkType.h:165:3: error: #error "No native data type can represent an 8-bit integer." /home/vex/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/VTK/Common/vtkType.h:180:3: error: #error "No native data type can represent a 16-bit integer." /home/vex/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/VTK/Common/vtkType.h:195:3: error: #error "No native data type can represent a 32-bit integer." /home/vex/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/VTK/Common/vtkType.h:215:3: error: #error "No native data type can represent a 64-bit integer." /home/vex/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/VTK/Common/vtkType.h:223:3: error: #error "No native data type can represent a 32-bit floating point value." /home/vex/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/VTK/Common/vtkType.h:231:3: error: #error "No native data type can represent a 64-bit floating point value." make: *** [Make/linux64GccDPOpt/vtkPV3Foam.o] Error 1 + cd PV3FoamReader + mkdir -p Make/linux64GccDPOpt + cd Make/linux64GccDPOpt + cmake ../.. -- The C compiler identification is GNU -- The CXX compiler identification is GNU -- Check for working C compiler: /home/vex/OpenFOAM/ThirdParty-1.6/gcc-4.3.3/platforms/linux64/bin/gcc -- Check for working C compiler: /home/vex/OpenFOAM/ThirdParty-1.6/gcc-4.3.3/platforms/linux64/bin/gcc -- works -- Detecting C compiler ABI info -- Detecting C compiler ABI info - done -- Check for working CXX compiler: /home/vex/OpenFOAM/ThirdParty-1.6/gcc-4.3.3/platforms/linux64/bin/c++ -- Check for working CXX compiler: /home/vex/OpenFOAM/ThirdParty-1.6/gcc-4.3.3/platforms/linux64/bin/c++ -- works -- Detecting CXX compiler ABI info -- Detecting CXX compiler ABI info - done CMake Error at CMakeLists.txt:12 (FIND_PACKAGE): Could not find module FindParaView.cmake or a configuration file for package ParaView. Adjust CMAKE_MODULE_PATH to find FindParaView.cmake or set ParaView_DIR to the directory containing a CMake configuration file for ParaView. The file will have one of the following names: ParaViewConfig.cmake paraview-config.cmake CMake Error at CMakeLists.txt:13 (INCLUDE): include called with wrong number of arguments. Include only takes one file. CMake Error at CMakeLists.txt:37 (ADD_PARAVIEW_PLUGIN): Unknown CMake command "ADD_PARAVIEW_PLUGIN". -- Configuring incomplete, errors occurred! + make make: *** No targets specified and no makefile found. Stop. vex@vex-laptop:~/OpenFOAM/OpenFOAM-1.6/applications/utilities/postProcessing/graphics/PV3FoamReader$ |
March 13, 2010, 15:20 |
#12 |
G B
Rep Power: 16 |
I dont know what to make of that, try updating gcc and cmake, maybe recompile paraview and pv3foamreader?. Resource the bashrc (. ~/.bashrc) and hope for the best. However, i'm very inexperienced, i just recommend what worked for me. But it does look like a fixable error, not a mystical one.
March 13, 2010, 15:49 |
#13 | |
Anon
Rep Power: 16 |
I have switched to the system compiler and attempted to recompile PV3FoamReader Module and paraview. makeParaView was run successfully. However PV3FoamReader terminated prematurely and spouted off this to me: Code:
make[2]: QT_RCC_EXECUTABLE-NOTFOUND: Command not found make[2]: *** [qrc_PV3FoamReader.cxx] Error 127 make[1]: *** [CMakeFiles/PV3FoamReader.dir/all] Error 2 make: *** [all] Error 2 Last edited by vex; March 16, 2010 at 09:12. |
March 15, 2010, 13:54 |
#14 |
In my case, paraview command is not found only when I source from my bashrc openFoam-1.6.x. Everytime I want to use paraFoam utility I need to modify my bashrc to source 1.6 version and parafoam run without problems.
Any idea how to solve this problem? Thanks in advance, R. |
January 29, 2011, 21:32 |
paraFoam_OF1.7.1_Ubuntu11.04
#15 |
Hi, it is a long time since I used OF1.5, now I face a problem and I need your help since I searched all the forum without any good solutions:
1 System Ubuntu 11.04, Qt 4.7.0, cmake2.8.3 2 Results could be found in the attached file after the command "./makeParaView" in the directory ThirdParty-1.7.1 3 This will result in: OpenFOAM/OpenFOAM-1.7.1/bin/paraFoam: 142: paraview: not found when we use paraFoam in the case cavity postprocessing. By the way, Good new year! |
January 30, 2011, 07:11 |
#16 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Zhoubin,
AFAIK, ParaView 3.8.0 doesn't build very well with Qt 4.7. This is why I wrote this blog post: Building ParaView 3.8.0 with custom Qt 4.6.3 As for the log file you posted, it doesn't seem complete. Did you run it like this: Code:
./makeParaView > makeParaView_log.txt 2>&1 Best regards, Bruno
Paraview and Qt installation | maverick | OpenFOAM Installation | 13 | February 7, 2010 07:29 |
paraFoam reader for OpenFOAM 1.6 | smart | OpenFOAM Installation | 13 | November 16, 2009 21:41 |
64bitrhel5 OF installation instructions | mirko | OpenFOAM Installation | 2 | August 12, 2008 18:07 |
Paraview installation troubles | jjhall | OpenFOAM Installation | 3 | April 17, 2008 12:59 |
Paraview installation problem please help | bender | OpenFOAM Installation | 2 | February 27, 2006 05:00 |
